Question about Pyle Pro P1501ATU 1500 Watts Hybrid Pre Amplifier with AM/FM Tuner/USB
No sound from p1501atu
When trying to play music thru cd player,there's no sound at all
    New Friend:
Just bought it yesterday & my function display went out only it shows nothing is it anyway I can fix it or do you know the problem
Posted on Nov 16, 2012
Denon CD deck
This unit needs a service visit. It may be a common problem with that model but to me it sound like a power supply issue as when you play a disc more power is used to rotate motors and move the sled. This is indicating to you that it is in a weakened condition and will soon fail more significantly. The problem may be as little as a solder joint or a defective Filter capacitor which is common in some models of equipment.
Dec 11, 2012 | Audio Players & Recorders
CD player makes crazy, loud sound while playing. Is this fixable?
Yes, it is probably fixable but not within the cost structure of the Crosley product. On the unit I worked on, the item looks pretty much throw away by it's construction. I just worked on one recently for my aunt. I am sure the cost to repait one of these would exceed it's value.
If you are in Chicago and want me to look at it- skywavebe@sbcglobal.net
Dec 05, 2012 | Crosley Audio Players & Recorders
My NAD C326BEE amp goes into protection mode at moderate volume
The protection only should come on, when the power amplifier has to give more current than it can deliver. (electronic fuse)
If in the music is a lot of subsonic, sound, so low you can't hear and your speakers can't produce, this could cause the problem. Normal CD players will cut of all frequencies beneath 20 Hz, but it could be your PC is giving everything from 1 Hz and above.
I would certainly try to play some music over a CD player and check if that would solve your problem. Not sure if that works, what you could do to suppress the sub sonic in the computer music.
Aug 22, 2012 | NAD C326BEE Amplifier
Nakamichi cd cassette player 1 not spinning discs
There's a Music Bank 7-disc player in use in my bedroom these days. Nice unit, but they used to come in for service once in a while- from what I could tell, these units don't 'park' the CD drawers on a soft power off- they simply shut down. When powered up again, they sometimes let the disc last in play slide off the tray & jam the machine. I've had no issues, as long as I always hit stop, wait for it to park, and then shut off. The analog output's sound has been very good (has a coax out as well).
Jul 28, 2012 | Nakamichi Audio Players & Recorders
I have a sony ta-fe370 amplifier. I bought it 5 years ago. 4 years ago it stopped working. I would now like to repair it. The problem is that it turns on and the power light comes on and so does the...
The problem is hard to track down, but fixable. You need to determine if the pre-amp has failed or the power amp. To determine which try this: Connect a device which plays music and turn the volume control fully up! You can sometimes hear the sound better via a pair of headphones. If you can hear any signal or music breaking through, then the pre-amp section is OK. If you can't it might not be. If you can hear faint music then it will be the main power amp to blame. Now because you have lost both channels you must only investigate devices (such as IC's) which have both channels running to them. Some amps have one big power amp IC that does the work. So if that goes it takes the sound with it. Have a look at whatever is on the big heat sink first, that will determine a lot of your future actions.
Jul 06, 2011 | Sony TA-FE370 2-Channel Amplifier
How to tune properly
make sure your speakers are wired to the amp with correct ohm load, turn gain, bass boost all the way down on amp, zero out your equilizer on the cd player and turn it all the way down then start raising volume on cd player., when u can start hearing music thru the subwoofers adjust the cd player volume till the sound from your subs is at its peak without any distortion. then start raising the gain on your amp till you are happy with the sound. It gives you the optimal signal strength coming from the cd player and the smoothest sound.
Jan 13, 2011 | Performance Teknique ICBM-774 Car Audio...
My Bose Wave radio/cd won`t play cd`s anymore. The radio works great. The cd player worked tonite, the would stick in a certain part of a song. Very intermittent. Now tries to read the disc, then says disc...
"I`ve used an aerosol air can to clean thru the cd slot"What type? not an "empty" can of paint, hairspray, chemical of some sort i hope. Compressed air at most I hope. If not, that's your Bose out the window!
The lense sounds like it needs a clean, you can buy these in disc for with tiny brushes on. Made by BIB and Allsop amongst many brands
Aug 30, 2010 | Bose Wave Music System CD Shelf System
No sound thru cd player
are you using any separate amp?- if you are the blue wire on the back of the radio is probably turning off when you use a cd(the blue wire is for a power antenna, the blue with a white stripe is for an amp)
Feb 29, 2008 | Kenwood KDC-519 CD Player
Pyle Pro P1501ATU 1500 Watts Hybrid Pre Amplifier with AM/FM Tuner/USB Logo
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
