Question about Mitsubishi VS-60805 60" Rear Projection Television
Problem with Mitsubishi VS-60805 60 in. Rear Projection Television
The red canon goes out for awhile then turns back on and stays on for awhile. This is been going on for about 2 years. Now in addition to that the blue canon doesn't want to converge. It makes everything in double vision with the top and bottom corners pulling in a U-shape. Can it be repaired???
    Master:
  • 444 Answers
You need new bulbs for it.
Posted on Oct 25, 2012
jmgldsmth
  • 2005 Answers
SOURCE: Mitsubishi Rear Projection makes funny shapes on Green and Blue
Your Green and Blue horizontal video amplifiers have collapsed: try using a freon cold spray on these chips as this occurs when the heatsink grease dries up on the HVA chips and, causes an overheat condition; if you have an oscilloscope monitor the vert drive as well.
Posted on May 20, 2009
MikeNJ1964
  • 398 Answers
SOURCE: Mitsubishi VS 4552A
One of your convergence IC's has either cracked loose or burned out. The IC will have to be resoldered or replaced and then the convergence circuits realigned. If you do not have experience in repairing convergence circuits then have a qualified tech handle it for you. This is by far the most common failure in the projection sets and a good tech can have it fixed in about an hour and a half. I charge $150 for that but shops in your area will vary, so call around.
Posted on Jul 31, 2007
  • 4234 Answers
SOURCE: Screen has double image in red
This is a convergence problem that is either poor solder connections at the convergence ICs or defective ICs. If you can solder, you can fix this yourself. Update this if you wish to attempt the repair and I'll provide additional details and instructions.
Dan
Posted on Mar 24, 2009
  • 126 Answers
SOURCE: I have a Mitsubishi Rear Projection tv (vs-50705).
Well, you did the right first step. However, when the convergence outputs toast up they sometimes cause other problems. First would be the fuses that supply them voltage. These are pico fuses back in the power supply. Second would be open supply resistors that have opened up because of the excessive current draw caused by the whacked out convergence amps. When changing the outputs doesn't solve the problem it takes the repair out of the realm of the do-it-yourselfer. My recommendation is to let a professional take over.
Posted on Jun 06, 2009
SOURCE: blue and red overlap shadowing
ok I have tried to converge the colors many times and even rested the convergance to factory settings and the problem still keeps happening what else could i do?
Posted on Aug 02, 2009
I have a Mitsubishi vs 50501 50. The picture would scramble when turned on and not give a picture unless I bumped it. Now when I turn it on it goes right back off without staying powered up.
there is probably quite a few "dry joints" that needs re soldering in the power supply section.
This should solve your problems rather than buying a new one.
Good luck and Thanks for using fixya.
G.
Jun 14, 2011 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi VS-50111 Tv does not stay on.Turn Tv on and shuts off after a few seconds.
Aug 06, 2010 | Mitsubishi VS-50111 50" Rear Projection...
I need a owners manual for my vs-60707 60 inch. rear
in your web browser type in the brand and model number and than download the manual or you can go to your local library and look in sams photofact and copy it.
Nov 07, 2009 | Mitsubishi VS-60707 60" Rear Projection...
Model VS 50501A TV. Works fine for awhile then screen goes black
most likly its your lamp you just need to get a new one off the internet or you can bring it to a repair shop and they will be able to replace it for alittle bit more then the lamp itself will cost
Mar 14, 2009 | Mitsubishi VS-50501 50" Rear Projection...
VS-45607 Rear Projection Television
Resoldered connector DY on the yokes and check caps C411, 2200uf/35v and C412, 10uf/50v on main pc board.
Bill
May 04, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-50800 on/off problem
It sounds like, and I'm only making an educated guess here, but I'm thinking your television is broken and you should probably get a new one if you want to continue watching television.
Oct 21, 2007 | Mitsubishi VS-50800 50" Rear Projection...
Older rear projection tv
I have the identical model, purchased in early 2000. I had the same issue, and called Mitsubishi service. Turns out there is a known problem with the video power supply. Mine was under warranty when it was repaired (in 2002), but by now yours probably is not. I recall the repair guy did the fix with no parts, just a soldering iron. If you're handy, you can probably get the details from MITS service and try the repair yourself. If not, I suggest the repairman route.
May 31, 2007 | Mitsubishi VS-55705 55" Rear Projection...
Mitsubishi VS-60805 60" Rear Projection Television Logo
112 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
