Question about Black & Decker Refrigerators
Toploading bottle water dispenser push button is sticking
SolutionGuy
  • 331 Answers
SOURCE: Ice/water dispenser sticks
Something kinda frozen treat probably melted and worked it's way into you dispenser area... seen it before. That's where the "sticky" is coming from. UNPLUG THE FRIDGE! MAKE A NOTE OF HOW EVERYTHING COMES APART! Remove the drip tray (if any)and remove any screws you may find there. Now get a small flat blade screwdriver, and pry the fascia panel off the door from the BOTTOM FIRST (you may see notches under there for a screwdriver to fit into) and work your way around it gently until it comes off. Now remove the screws that are facing you to pull the control panel out. When it's out, it'll see be hooked up to the wiring harness. Look for a small brown micro-switch with either 2 or 3 terminals on it. The switch is brown, about an inch long and 3/8" thick... this is the culprit. From here you can do a couple of things. 1.) replace the sticky switch. 2.) Take the wires off of it and remove the switch completely. Then, using a moistened towel, clean it real well and let it dry completely. Then reinstall it and rebuild the dispenser area. Sounds tough, but it should take no more than 45 minutes to do.
Posted on Jul 30, 2007
Maytag317
  • 1136 Answers
SOURCE: Water dispenser won't shut off
Hi, You will need to replace the inlet valve located under the refrigerator in the back. Get me a model # and I can assist you further.
Vic
Posted on May 23, 2009
SOURCE: My maytag MSD2556ae side by side refrigerator water/ice dispenser
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Posted on Mar 11, 2010
RyanFanMan
  • 342 Answers
SOURCE: When the water button is pushed on the in-door
there seems to be a problem with the switching panel that changes the ice to water and may need to be replaced you may want to contact Sub-Zero and see what they can do for you because i do not specalize in that kind
Posted on Jan 02, 2011
reyjoshua07
  • 1157 Answers
SOURCE: I have a LG LRSC26922TTside-by-side
Hi gener72,
If the lever on you ice dispenser keeps getting stuck when dispensing ice or water, it is often caused by the button attached to the back of the boot has been removed. The easiest way to resolved this is to get the rubber boot in place. Please follow the following steps below on how to disassemble the dispenser.
1. Lock the dispenser using panel button to preclude undesired water/ice while working.
--> Note: the outer bezel (edge of panel) is secured by screws and should not be messed with.
2. The main panel has tabs on all four sides. You can use screwdrivers to pry the panel off ( you can use small to average size).
3. Pry the main panel working through the seam between the bezel and panel.
4. Work your way around starting from the lower left or upper left corner. Each side of the panel has 3 or 4 tabs. Please use a moderate force to pop the tabs loose.
5. Once the panel is loose, you'll need to disconnect the electrical connector at the upper left.
6. The plug comes off and reattaches easily, don't pull on the wires, use the plastic connector itself. Wiggle the panel free.
7. Now, you can get to the back of the boot retention bezel. Carefully push the bezel's securing tabs (x3) through the panel and reattach the rubber boot.
8. You can use needle nose pliers to carefully pull each rubber nib through their applicable hole on the bezel. Now leave the boot/bezel assembly to the side-it's the last step to reassembly. Note how the main panel tabs fit into their receiving slots/flanges.
9. Reattach the electrical connector, snaps right on, and maneuver center of panel into recessed area, around ice chute/water nozzle.
10. Slide the right and bottom sides on first-flanges, not slots for tabs-then align remainder of panel. Using moderate force, pop (punch) the remaining tabs back into their respective slots. The main panel will seat over the bezel. Now align and snap boot/bezel back into place.
Hope it helps.
Thank you for using FixYa.
Posted on Apr 16, 2011
How do i winterize a primo water dispenser #601118
get a gallon of RV antifreeze (it is not toxic)
put it in cabinet where the water bottle goes, connect the intake hose to the antifreeze bottle.. Then use the dispenser as normal till the antifreeze comes out both dispensors. When you go use it next time take the antifreeze bottle out, put in a regular water bottle and run the water till the antifreeze is gone.
Jan 16, 2016 | Cars & Trucks
Ed5shaxmt10 water dispensing won't shut off
One of two problems could be causing this problem...... First problem can be that the switch that you push on to dispense water or ice is sticking. The second problem that could be is the water solenoid that comes on and should close off fully is sticking open and allowing water to drip and not shut off completely. This is usually caused when the plunger in the solenoid starts to stick due to calcium deposits that has built up on it after time and if the water dispense system is not used that often. If you're not technically inclined, make sure that the repair person does not tell you anything that does not fit the descriptions that I have mentioned above. Hope this helps.
Mar 14, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Primo water cooler red light blinking
What do I do with my Primo water dispenser whenever the red light keeps flashing I have a full bottle of water in there but it just keeps flashing I can turn it off and turn it back on or I can push the button in the door and it'll go off within the next 20 minutes it will come back on and the water's cold and then the water goes to lukewarm
Nov 25, 2013 | Unknown Primo Deluxe Stainless Steel...
The water dispenser does not work properly. The light does not come off of the cubed ice button. To get water, I push the water button and without pushing the lever, water starts coming out. To stop it, I...
You have a bad main control board . The new pt # WR55X10656 . The dispensor board is not communicating with the control board . However , check this site to see if it can be replaced under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
Nov 15, 2009 | GE GSH25JFR Side by Side Refrigerator
Fabric softener dispenser
Have u made sure that the dispenser is click in properly
Oct 26, 2009 | Washing Machines
In the last 2-3 months I have purchased 2 of the Sunbeam Combo Water Dispensers and both of them overflow. After setting the bottle in the ''no spill receptacle'' after awhile they will overflow around the...
I would say that the dispenser is at fault. These water dispensers use gravity to release the water and won't allow overflow. The air pressure in the bottle comes up through the dispenser as water flows out. Your dispenser is not seating against the bottle correctly. Look inside at the gasket material that the top of the bottle rests on when it is in the inverted position. That's where the problem lies. The leak is happening right there where the bottle rests down in the reservoir. Look at that seal, it's damaged. Leaking...
Sep 22, 2009 | Kitchen Appliances - Others
Vic
May 23, 2009 | Refrigerators
WAter dispenser stopped working
Change the filter in the refrigerator. ..just change it..
Is there something wrong with the kitchen faucet?..
drinking bottled water..??.. are you drinking ACID RAIN??.... think not...??
read this:
Acid Rain Students Site PH Scale
now read this..
Analyzing Comparing Brands of Bottled Water
Oct 11, 2017 | GE CleanSteel GSL25JFTBS
Ice and water in the door
sounds like the water valve is sticking replace the water vavle
Nov 29, 2008 | Whirlpool Refrigerators
Refrigerators Logo
Top Black & Decker Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Black & Decker Refrigerator Expert? Answer questions, earn points and help others
