Question about Cub Cadet Garden
Cub cadet 1110 hydro no forward or reverse
Hydro seemed to be slowly dying over the last couple of years. worked better when warmed up. now won't run at all
  • 62 Answers
SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
Posted on Apr 18, 2009
  • 10865 Answers
SOURCE: cub cadet 7254 with a 25 hp kawasaki running rough when hot
your carb needs to be either rebuilt or replaced. it is crudded up with lacquer.
Posted on May 10, 2009
SOURCE: hydrostat pump leak,cub cadet garden tractor
One... these are pressure relif valves. There are O rings that probably need replacing is all, the valve can go bad but since both are leaking it will probably be just O rings from heat that went bad.
Remove the valves and replace O rings. Use a 'good' pipe thread dope on threads when re-installing.
Two... never use teflon tape on hydralic systems.
Three... boscia is no guro for sure.... lmao
Posted on May 21, 2009
kel1guy2002
  • 3740 Answers
SOURCE: lawn mower has hydro gear transaxle reverse was
Most of the time when this happens the reverse shift linkage is too short. It is usually cause by either a bent linkage or worn linkage bushings.
The internal shifting fork can be bent inside the transmission which is rare but does occasionally happen... most of the time it is a linkage problem. Also check on the side of the transmission to make sure the shifting lever has not moved from the original position on the Yoke shaft.
Thanks for using FixYa.
Kelly
Posted on Mar 29, 2010
  • 3 Answers
SOURCE: I have a cub cadet model 1420 with hydrostatic
i had exmark hydros i was told to never wash them, the water does more damage than good. have you checked or changed your hydostatic oil and filter latley? if you have, when doing that you have to be very careful not to get any foriegn objects in the oil resevoir, dirt, grass clipings, anything will ruin the hydro pump.
Posted on Sep 28, 2010
Cub Cadet 1045 hydro. Transmission not working. Bypass rod in. PTO and belt fine. Jacked up wheels spin in opposite directions. Forward and reverse pedal when pushed makes loud grinding noise.
This actually sounds like the top pulley on the transmission may be loose and the center hole worn out.
Depending on the actual sound though it may be a bad transmission - sorry. I suggest having a dealer mechanic inspect it.
Mar 04, 2017 | Cub Cadet Garden
Cub cadet 1110 hydro Won't go up hills forward at all. But will in reverse.
Valve is bad, needs to be serviced. Might check fluid level as well
Sep 29, 2014 | Garden
I have a LT1042 hdrostatic drive and it won't go forward or reverse what is wrong
can only guess
Low on cub cadet hydro fluid?
other hydro filter other and cub cadet?
linkage came unhooked from drive mechanism
your engage disengage lever at the back of the mower is set so it can be pushed,engage lever to allow hydro pump not to be bypassed
Jul 28, 2014 | Cub Cadet Garden
Have you check the fluid leval in it at all, It could be right down if you never check it ,End everry thing in it siezed up.
Oct 25, 2012 | Cub Cadet Garden
Can anyone help? My Cub Cadet LT1045 won't move (foward/backward).
Hi, check that the drive belt, pulleys and shafts are all ok and that they are actually driving the transmission, hopefully you will see the problem. If the transmission is driving ok and the fwd and reverse lever is functioning as you said, the transmission may have failed. Also check the hydro release lever is functioning. Regards Phil.
Jun 25, 2012 | Cub Cadet Garden
Cub Cadet 2166 tractor, changed transission filter and oil
did you check to see if your belt was in good shape and if the hydro relef was in
Apr 14, 2012 | Cub Cadet Garden
Cub cadet 2160 PTO problem
How do you disconnect the reverse safety switch on a cub cadet 2160... where is it located?
Jun 01, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
