Question about Cub Cadet Garden
Cub cadet 1110 hydro no forward or reverse
Hydro seemed to be slowly dying over the last couple of years. worked better when warmed up. now won't run at all
  • sam armstrong Oct 29, 2012
    It is full of oil and the levers are in their proper position.
    Master:
  • 444 Answers
Have you check the fluid leval in it at all, It could be right down if you never check it ,End everry thing in it siezed up.
Posted on Oct 25, 2012
  • 2 more comments
  • sam armstrong Oct 25, 2012
    hyd. fluid is full. The dump valve position seems ok but i noticed that i can now push
    can now push the tractor forward or back without using dump valve
  • Rocky Degelman Oct 25, 2012
    Is there any clunking noise when you try to put it in gear? Allso is the fluid clean ? Put a bit of the fluid on one of your fingers .end smell if it has a burn,t smell to it.If it smells burn,t .The gears are slipping,End not engageing,Hope this helps you out.
  • Rocky Degelman Oct 29, 2012
    Does the oil look dirty at all,Or have a burn,t smell to it,If it smells burn,t at all the gears are probaly (Slipping)
SOURCE: 1320 cadet mower wont move good in reverse
**** u **** ur self
Posted on Mar 19, 2009
  • 62 Answers
SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
Posted on Apr 18, 2009
  • 10865 Answers
SOURCE: cub cadet 7254 with a 25 hp kawasaki running rough when hot
your carb needs to be either rebuilt or replaced. it is crudded up with lacquer.
Posted on May 10, 2009
kel1guy2002
  • 3740 Answers
SOURCE: lawn mower has hydro gear transaxle reverse was
Most of the time when this happens the reverse shift linkage is too short. It is usually cause by either a bent linkage or worn linkage bushings.
The internal shifting fork can be bent inside the transmission which is rare but does occasionally happen... most of the time it is a linkage problem. Also check on the side of the transmission to make sure the shifting lever has not moved from the original position on the Yoke shaft.
Thanks for using FixYa.
Kelly
Posted on Mar 29, 2010
  • 3074 Answers
SOURCE: Cub cadet 42" ltx 1040
http://www.ehow.com/how_6808091_change-cub-cadet_s-drive-belt.html
Posted on May 04, 2011
Cub Cadet 1045 hydro. Transmission not working. Bypass rod in. PTO and belt fine. Jacked up wheels spin in opposite directions. Forward and reverse pedal when pushed makes loud grinding noise.
This actually sounds like the top pulley on the transmission may be loose and the center hole worn out.
Depending on the actual sound though it may be a bad transmission - sorry. I suggest having a dealer mechanic inspect it.
Mar 04, 2017 | Cub Cadet Garden
Cub cadet 1110 hydro Won't go up hills forward at all. But will in reverse.
Valve is bad, needs to be serviced. Might check fluid level as well
Sep 29, 2014 | Garden
I have a LT1042 hdrostatic drive and it won't go forward or reverse what is wrong
can only guess
Low on cub cadet hydro fluid?
other hydro filter other and cub cadet?
linkage came unhooked from drive mechanism
your engage disengage lever at the back of the mower is set so it can be pushed,engage lever to allow hydro pump not to be bypassed
Jul 28, 2014 | Cub Cadet Garden
Cub Cadet 2166 tractor, changed transission filter and oil
did you check to see if your belt was in good shape and if the hydro relef was in
Apr 14, 2012 | Cub Cadet Garden
Cadet LT 2042 worked fine changed hydro filter by lifting front with hoist to vertical. Lowered and topped off fluid. Now wont go forward or reverse. Makes no noise when pedal is engaged to move either...
You will have air in the system and will need purged. To do that you jack up the wheels to where they will turn freely then disengage the hydro and at an idle alternate forward and reverse for a for about 4 or 5 minutes. Recheck the fluid level and top off. Now engage the hydro and do the same forward and reverse for 3 or 4 minutes. You should have axle movement at this point. Hope this will help.
May 20, 2017 | Cub Cadet Street Sign- tractor lawn riding...
I have a cub cadet model 1420 with hydrostatic drive that will not go forward or reverse. The drive belt is moving and the hydrostatic unit was replaced 3 years ago. I still have to engage the lever to...
i had exmark hydros i was told to never wash them, the water does more damage than good. have you checked or changed your hydostatic oil and filter latley? if you have, when doing that you have to be very careful not to get any foriegn objects in the oil resevoir, dirt, grass clipings, anything will ruin the hydro pump.
Sep 28, 2010 | Cub Cadet 46" Lawnmower Deck Drive Belt...
Cub cadet 2160 PTO problem
How do you disconnect the reverse safety switch on a cub cadet 2160... where is it located?
Jun 01, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
294 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
