Question about Acer Aspire One Netbook 8.9" Notebook
Whats wrong with my Acer Laptop when i turn on its black with white letters saying PXE-E63:Error while initializing can someone help me step by step please
When i turn on its black with white letters saying PXE-E63:Error while initializing can someone help me step by step please
  • leeann Oct 25, 2012
    It's saying No bootable device
  • Acer Master
  • 27,725 Answers
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
also check ram modules are clean and secure in sockets even reseat them
hope this helps
Posted on Oct 25, 2012
4 Suggested Answers
  • 104 Answers
SOURCE: When I turn on my Acer minilaptop it say: Check
Your BIOS setting or boot order was changed to enable network booting (Intel's PXE).
reboot,tap F2 to enter BIOS and navigate menu to disable network booting.
Posted on Mar 28, 2010
  • 629 Answers
SOURCE: this is regarding an acer
this can mean that your syste, is not detecting your hard drive. A reinstall of the operating system may be necessary, or a replacement hard drive is needed. Try to restart the notebook and tap F12 a few times as the system restarts until you reach the One Time Boot Menu, then if the hard drive islisted, select it and press Enter and see how it goes. Feel free to rate how helpful this may be to you.
Posted on Oct 28, 2010
  • 236 Answers
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery which will erase all user data and restore the operating system to its factory default when you purchased the netbook.
Posted on Feb 14, 2011
Emachines e525 says no bootable drive
Boot to recovery mode and do a startup repair, if it doesn't help, you can either do clean install or talk to a specialist
Apr 19, 2014 | eMachines 15.6" E525-901g16mi Laptop Lcd...
When I boot my Acer Aspire One, I get a black screen that says: (line 1) check cable connection...! (line 2) pxe-e63: error while initializing the NIC (line 3) pxe-m0f: exiting Intel PXE ROM. (line
Seems your graphic card is fry.But you cant do a test to confirm it.Just plug anohter monitor to the VGA slot and powerup the PC.Test if still no screen that will confirm the problem.
Apr 12, 2013 | Computers & Internet
Whats wrong with my Acer Laptop when i turn on its black with white letters saying PXE-E63:Error while initializing its saying no bootable device can someone help me step by step please
If you want to pay a tech for help End willing to pay for step buy step instructions $70 per hour ,End in total for about 6 or more hours to get it working again.
Oct 25, 2012 | Acer Aspire One Netbook 8.9" Notebook
Aspire One PC Notebook Your question about Aspire One PC Notebook has been posted. Whats wrong with my Acer Laptop when i turn on its black with white letters saying PXE-E63:Error while initializing
Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Oct 15, 2012 | Acer Aspire One Netbook 8.9" Notebook
Pxe e63 error while initializing nic no bootable
here we go >
power on your netbook press delete to go to bios setting goto boot or boot device priority then set it to harddisk(your current setting is pxe or network boot) then press f10 to save enjoy
thanks for using Fixya
Jun 01, 2011 | Acer Aspire One Netbook
When I turn on my Acer minilaptop it say: Check cable connection..! PXE-E63: Error while initializing the NIC PXE-M0F: Exiting Intel PXE ROM No bootable device--insert boot disk and press any key
Mar 20, 2010 | Acer Aspire One PC Notebook
Acer aspire one after starting my laptop it goes to a black screen and says check cable connection..! PXE-E63: Error while initializing the NIC PXE-MOF: Exiting Intel PXE ROM. No bootable device-- insert...
The computer can't see the hard drive for one of many reasons.
1. Hard drive failure
2. Bad connection between hard drive and motherboard.
3. BIOS corrupted
4. Motherboard failure of HDD control.
Press F2 when the ACER splash screen appears and go into BIOS set up.
The first page should show the hard drive name and ID number.
This may be missing or have corrupted characters in it.
Go along to the 'save and exit' and allow a restart. This sometimes kicks it into life.
Replace the hard drive with a known good one and check to see if this is recognised in the BIOS.
Clean the contacts of the hard drive.
ACER fitted both types of hard drive to this model, either PATA (IDE) or SATA.
Dec 28, 2009 | Acer Aspire 5100 Notebook
AA1 will not boot- PXE-E63 error- help!
It happens when no boot device is selected, the default is network boot first, you must select CDROM/DVDROM or HD as your first startup device.
Oct 21, 2009 | Computers & Internet
Acer Aspire One Netbook 8.9" Notebook Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
