Question about Nintendo DSi Red Console
Where can i have my nintendo ds repaired here in cebu city?
Something is wrong with the battery. said battery is brand new..i changed it last august 2012..battery bought in maplin sote in suffolk, englaNd...it will charge for hours and when played it will work for less than an hour
  • noemi576
    noemi576 Oct 27, 2012
    need someone to repair it here in cebu city.....as mentioned earlier it takes several hours to charge and once i use it to play games, its good for only less thanan hour......
SOURCE: Nintendo DS Lite - does not charge
i would suggest trying to find what the issue is, if you know anyone who has a different charger, try it on your daughter's ds. if it still doesn't work, it's a DS problem...if it's under warranty, go to whatever store you bought it at and have them fix or replace it. If you try the different charger and it DOES work, then the only problem is the charger...so then all you have to do is go buy a new charger...hope this helps.
Posted on Feb 05, 2009
xedcom
  • 127 Answers
SOURCE: Nintendo Ds Sound Problem
This option is only suitable for out of warranty devices as opening it violates the warranty.
Open the device and look for loosen or unplugged cables in the main bottom board. Usually this dont happen though opening and closing the unit whe it was not assembled correctly may cause the wires and conductors to loosen or even worst to get cut by the moving parts. So as you say nothing else was done with the unit between plays that is the only explanation I can guess from it.
The headset plug is in the bottom main board so no cables are required to get the audio there, though as the speakers are in the top, these require some flexible cables and conductors running throught the hinges to the top part.
Hope to this info to be helpful: How to dismantle an Original Nintendo DS.
If yours is the NDS Lite, just find this video in youtube:
"Disassembling Nintendo DS Lite"
Good Luck...
Posted on Dec 01, 2007
SOURCE: ds nintendo will not charge light flashing and think it is the connection on the ds as i have tried other chargers in it
After a bit of trial and error I found that one of two internal fuses had blown. You can bridge the fuse with a bit of solder to fix it but this means if the same thing happens again there will be no fuse to protect your DS. My own solution is to get a friend to charge my battery on their DS while I wait for a desktop battery charger to arrive from Hong Kong. I found the battery charger on ebay. I suggest you charge your battery in a friend's DS and put it back in your own to see if you DS works. If it does then you have the same problem as me.
Hope this helps.
Posted on Jan 14, 2008
  • 26 Answers
SOURCE: My nintendo ds lite will not come on
some batteries take a while to adjust, you might have water damage.
Posted on Jul 13, 2009
frankgant
  • 250 Answers
SOURCE: hoe do i change my nintendo ds game slot
You must remove the bottom of the DS. There are security screws that need to be removed. It takes a special screw driver to remove them. There are also 3 or 4 regular small phillips head screws that must be removed. Then the bottom can be removed. Be careful not to break the power switch off when removing the buttom. Once the bottom is off you can see the slot and unsolder it. You will need really good desoldering and soldering skills and the pins that will need to be removed and resoldered are small. You'll need a very small tipped solering iron. You won't find one small enough at radioshack. You'll have to order one special from a store online. Once you have the new slot put in you then just put it all back together in reverse.
Posted on Feb 11, 2010
I just bought my so nintendo ds lite last night and new gam it says card not in and its in and both are brand new
maby its the wrong game maby its for ds3d u dont now but it always happen to me and that was my problem
Jul 07, 2011 | Nintendo DS Lite Console
I just bought a new dsi action replay from walmart i inserted the action replay into the dsi it went to the push code list but it went to all the codes not the game I inserted which does have the codes for...
is the ds a dsi and is it new or did you update it anytime after august last year
nintendo released an update which mentioned it was something to do with ds shop when actually it stopped the cheat cards working
May 30, 2011 | Datel Action Replay for Nintendo DS
I have been charging my ds for 5 hrs and red light still on
When you "Charge" the ds is the orange light on? if not buy a new charger
Nov 25, 2009 | Nintendo DS Lite Console
Where authorized ipod apple parts and repair center here in Cebu?
1 - this a link for ipod hard drives batteries http://www.ipodbatterydepot.com/
you can change the battery yourself
2 - sorry i dont know of any Apple (authorized) repair stores in Cebu
3 - unistall the itunes totally...download the very latest version of itunes from http://www.apple.com/
and you should be able to access your nano
Jun 19, 2009 | Apple iPod nano
My son's nintendo ds has been charging for a day now, but it
The battery is probably completely drained. Rechargeable batteries have a certain lifetime in which they can be charged to. The charge limit for a Nintendo DS is approx. 500 charges. When you pass this limit the battery will no longer work. Your best option is to buy a replacement battery at http://www.nintendo.com/consumer/
After a year or more a rechargeable battery won't last as long as it did when it was new.
Apr 07, 2009 | Nintendo DS Console
Power gone on nintendo ds lite
Hey if you have a warranty nintendo might repair or raplace the Ds.I thought about replacing the charger or place the charger in another power outlet.I hope I helped.
Dec 30, 2008 | Nintendo DS Lite Console
Nintendo ds not charging
. go to ebay or even gamestop and purchase a new battery. sounds like the battery might have gave up. these kind of things happen, rare but happen
oither things it could be is a cold solder. the female power jack might not be fully soldered on the board. causing the battery not to be able to charge.
i think if you change the battery it will work. make sure you get the correct model/brand u dont want no knock off batterys
May 20, 2008 | Nintendo DS Lite Console
Is it a costly repair job or buy a new one?
could be you need a new battery...wotrh a try. Always go for the cheapest option first.
Jan 07, 2008 | Nintendo DS Lite Console
Nintendo DSi Red Console Logo
60 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
