Question about Garden
Replace belts on tecumseh snow king snow blower
REPLACING AUGER DRIVE BELT
ToolBoxHero
  • 171 Answers
SOURCE: changing auger belt on snow blower
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
I am going to assume you have a Craftsman snow blower. If you don't have a copy you can get the manual through managemyhome.com
You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side)
The model number looks like 247.123456.
The belt closest to the blower assembly drive the auger/blower and the belt closest to the engine drive the transmission.
With the engine not running, have someone depress the drive lever and check the belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
Your Craftsman manual will show you step by step how to change th belt.
You can get parts for you Craftsman and most MTD made models through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
If you are unfamiliar with repairing machines you can get your snow blower repaired by taking it to your local Sears.
They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Posted on Jan 13, 2011
SOURCE: on my two stage snow blower--main auger stops turning .
Hi, I figured out the problem. The gear transfer case between the augers must be broke. The auger spins slowly until it hits snow and then stops-- The discharge fan continues to spin fast. I will try to get a local handyman to fix it or else but a new machine, this one must be at least 15-16 years old.
I thank you for your help, it is a great service. ojohn
Posted on Dec 12, 2008
  • 70 Answers
SOURCE: where is toro 31820 auger shear bolt?
Shearbolt is located at #54 in this diagram.
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=19462&control=SetCommunity&CommunityID=214&PageID=238#drawingDiagramPage
part#322-9
It may be hard to spot on the auger shaft as it may have sheared flush with the holes so look close. You may also need to remove the part of the bolt remaning inside the shaft.
Posted on Dec 22, 2008
trippssmengi
  • 76 Answers
SOURCE: auger on my snow blower won't turn.
First take a look at the shear pins they will be located on the augers going thru the auger and auger shaft, if they look ok then you need to take the belt off, with the belt off try to turn the im peller by hand. If the impeller does not turn then you need to look to see if something is stuck in the impeller or in the auger. If nothing is stuck in between anything then I would have to say it's going to be the gear box. If the impeller turns then look to see if the auger is turning also while turning the impeller. If the auger doesn't turn then it's probably the gear box. If it does turn then you have an issue at the pulleys
Posted on Jan 07, 2009
  • 636 Answers
SOURCE: mtd ranch king lawn mower drive belt
Try this site it is called manuals online, should be able download a manual for it for free, also for future reference would be nice.
Posted on Jul 11, 2009
Auger does not stay engaged when the lever is released to turn the chute, even though the traction drive is still engaged. Very annoying when trying to clear snow. How can I remedy this? Thanks
Either two things come to mind, first I would check the shear pins. When a shear pin is broken, the auger turns but stops as soon as it hits a load (snow). The shaft is turning, but there's no mechanical connection between the shaft and the auger.
The second thing is the belt either needs adjusting or replaced. Belt adjustments should be checked before every winter and are simple to preform. When checking the drive and auger belts, look for glazed running surfaces, and cracking. Either sign means the belt(s) need replacing. Also if the belt(s) have streched beyond their normal adjustment.
Sep 18, 2016 | Garden
Tecumseh lh318sa auger does not work
If you are asking about the pull cord and when you pull it the engine does not turn and the cord pulls super easy it generally means that the dogs inside the cove assembly are not engaging. This may be caused by a broken spring or dog inside the pull cord assembly. You would need to carefully remove the assembly cover from the engine and pull the cord to see if the dogs are protruding from the assembly if not you would need to repair or replace the parts as needed if so then you would have to check if the will still extend under strain, if not then repair if they still protrude under strain you would have to examine the engine where the unit was removed and look for damage or wear and replace parts accordingly. If you are in fact asking about the front or snow auger on the snow blower itself then the most likely answer would be that you have sheared a pin which holds the auger to the shaft that rotates it. The shear pins (as they are called) are designed with softer metal to break if you hit a large piece of ice, stick or rock that may damage more important and expensive parts of the blower if they stayed intact during the incident. To fix this merely find the hole in the auger along the shaft that is no longer pinned (the auger should spin freely) spin it to line up with the hole n the shaft (which may still have a broken piece of the shear pin in it) drive out any remaining pin with a punch and replace with the appropriate pin for your machine. If the pins are intact you may have a bad belt, pulley, or tensioner and you would have to move further into the repair process.
Feb 16, 2015 | Tecumseh Snowblower Snow Blower Starter...
I have a snow king 5hp snow blower. while clearing snow, the snow only oozes out the shoot.
IT SOUNDS LIKE YOU HAVE A TWO STAGE SNOWBLOWER WITH ONLY ONE STAGE WORKING. I BET THAT YOUR PROBLEM IS THE AUGER IS TURNING BUT THE IMPELLER BLADE THAT IS BEHIND THE AUGER HAS PROBABLY JAMMED UP WITH SOMETHING AND IS SPINNING ON THE SHAFT. YOU WILL HAVE TO REACH BACK AND GRAB IT AND TRY TO TURN IT ON THE SHAFT BY HAND.MAKE SURE THE BLOWER IF OFF!!!! . IF YOU CAN TURN IT BY HAND EASILY IT HAS EITHER BROKE A SHEAR PIN OR BOLT OR SOME TIMES THEY WILL TACK WELD THEM TO THEM TO THE SHAFT. GOOD LUCK
Jan 17, 2011 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Snowblower doesn't throw the snow very far, and every time I stop it, it takes a while for the auger to start turning fast enough to blow the snow. Feels like the torque isn't there. This is a Husqvarna...
The belt closest to the blower assembly drives the auger/blower and the belt closest to the engine drives the transmission.
With the engine not running, have someone depress the drive lever and check the blower belt.
You can get parts for you Craftsman and most Husqvarana, MTD made models through searspartsdirect.com. You can also get parts through jackssmallengines.com or your local dealer.
If you are unfamiliar with repairing machines take it to your local dealer. They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions to troubleshoot this problem farther. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Garden
My auger stops rotating with heavy snow loads. It sounds as tho a clutch is slipping. I tried to tighten up on the spring in the control cable, but that did not help.What do I adjust next?
The most common cause of this is the drive belt is worn. If you remove the cover in the middle of the snow thrower and look at the belt farthest from the motor. This is the auger/blower drive belt.
With the engine not running, have someone depress the auger lever and check the belt. You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced. On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
I didn't see what make and model this blower was but:
If this is a craftsman you can get parts through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
Feel free to ask any other questions. I know Craftsman Snow Blowers. Please remember to rate this answer!
Jan 01, 2011 | Garden
Auger belt on snow blower keeps coming off
if shop just repaired it, go back. Right belt? Tensioned enough?
Jan 28, 2009 | Toro Blowers Rake and Vac - Electric...
Snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Dec 13, 2008 | Toro Blowers Rake and Vac - Electric...
Transmission on snow blower-sears
most snow blowers are belt driven instead of hydraulic drive. it sound like the belt needs replaced.
Nov 10, 2008 | Garden
Garden Logo
1,301 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
