Question about DBX Driverack-Pa Eq/Speaker Control System System
We have a dbx Driverack PA unit with a Crown CDi1000 amp in our church. Recently, we starting having problems with the output to our main speakers dropping out. We found (by accident) that if we unplugged a microphone while it was hot, causing a "pop" in the system, the sound came back. Any ideas?
    Scholar:
  • 32 Answers
Check the speaker wires coming out of your amp. Chances are you have a problem with a speaker wire and this is just a coincidence. I say this because the same thing happened to me during a live show and I about had a heart attack. We lost the front of house for about 15 minutes while I tried to troubleshoot the Driverack, the board, and everything but the speakers and speaker wires. The cables were a recent purchase and were premium grade with light wear so I mistakenly ruled them out. It was intermittant so it took me a while to figure out. Now I understand that that's the weakest link in the chain and from now on I start there and work backward through the chain (that is, if all sound is cutting out).
Do you use banana plugs (two metal pegs sticking out of a plastic rectagle) coming out of the back of your amp? There are little screws inside the holes on the back of the banana plugs. Those can vibrate loose, especially if they're just factory tight. Get a little standard screwdriver and tighten them down. That will probably solve your problem.
Okay, wait a minute -- could be one more thing. You mention that the loud popping can be heard. Do you have any gates turned on? Most compressors have gates. Check your compressors to see if you have your gates turned up too high. A gate set too high would allow the loud pop to go through to the PA but would cut off everything low to mid-volume.
I guess you can see that I don't think it's a problem with the Driverack. I don't work for dbx or anything, I just think these other things are far more likely than a problem with the unit.
Posted on Feb 06, 2010
Good day..The common problem in a closed pa system setup is feedback.It limits the capacity of unit to give a higher intensity of volume..With this I just want to ask if DBX Driverack pa+ will work well...
The DBX driveracks work well with about any PA. The only PAs you might encounter a problem with would be one of the newer line array and digital processing PAs. Let your audio person get creative, the presets for multiple PAs are just a guide. If your sound person is confident and is qualified, let him/her experiment and/or rehearse - you'll be amazed at what that system is capable of.
Mar 10, 2011 | DBX Driverack-Pa Eq/Speaker Control System...
DBX PA+ no settings for Yorkville EF500P and LS801P
yeah that is because Harmon makes JBL speakers and Crown amps..for Yorkville Speakers use the VTC DLMS4080 Speaker processor, it blows the Drive PA away...
May 05, 2010 | DBX DriveRack 480 Processing Unit Home...
White screen on the dbx driverack pa? how to fix?
You can adjust the LCD contrast by pressing the Utility button and turning the dial one way or the other. Pressing the Utility button toggles back and forth between LCD contrast and Compressor/Limiter Threshold Meters, so since you can't see anything in the window you may have to press Utility twice, though I think LCD contrast is the first option.
Jan 17, 2010 | DBX Driverack-Pa Eq/Speaker Control System...
When going through the driverack pa setup wizard, where is the "custom" speaker setting?
You should be able to spin the dial all the way to the end of the list of speakers and there you should see custom.
Jul 15, 2009 | DBX Driverack-Pa Eq/Speaker Control System...
Honduras Church Mahanaim
check out the makers web site for all your equipment manuals
when starting up never make loud always check things working ok at low level
Mar 04, 2009 | DBX 1231 Home Equalizer
DBX DriveRack PA power failure
repair the transformers,,,using a digital voltmeter when both transfrormer are good the measure like 56 ohms, if one is good and the other is bad is gonna measure like 120 ohms , if both are damage it will measure nothing, all this with the switch in its on stage.
If you dont find anyone that can repair the transformers buy them.
Jan 28, 2008 | DBX DriveRack 480 Processing Unit Home...
DBX Driverack-Pa Eq/Speaker Control System System Logo
258 people viewed this question
Top DBX Audio Players & Recorders Experts
Philip Rowney
Philip Rowney
Vito Vacirca Jr.
Are you a DBX Audio Player and Recorder Expert? Answer questions, earn points and help others
