Question about Ricoh Aficio CL2000N Laser Printer
Error message says reset PCU correctly
Does anyone know how to correctly reset the PCU in Ricoh Aficio CL2000N? Thanks for your help.
  • 1 more comment
  • Patty Schwartz May 13, 2007
    Lolita,
    You are a genius!My printer is up and running.Thanks for your help and for sharing your knowledge!
    Patty
  • Anonymous Feb 10, 2009
    reset PCU, how can I reset my printer? Please help
  • Anonymous Mar 13, 2014
    how to reset the PCU message on a Ricoh MP171
  • 385 Answers
You get this message because the PCU isn't seated properly. This is a link for the user manual for this printer: http://www.ricoh-usa.com/downloads/manuals/printers/cl2000.pdf On page 13 shows a diagram that indicates the photoconductor unit on the printer. Page 60 shows you different error messages, what they mean and how to fix it. It means you have to take out the pcu and reseat it into the printer, it is not in correctly. Page 29 shows you how to do this. It has pictures of how to take out the pcu and put it in correctly. I hope you get it fixed.
Posted on May 12, 2007
    New Friend:
On my new PCU the little white plastic spring-loaded pin on the front of the unit wasn't popping out like the rest of the PCUs.
If you have this problem, with a small blade or tiny screw-driver, pop out either side of the small clip that holds the white pin in place and check that the spring is free to push it out.
I was just about to throw the whole printer away but this sorted it!Error message says reset PCU correctly - 1_9_2013_7_05_35_pm.jpg
Posted on Jan 09, 2013
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
Nov 05, 2015 | Ricoh Aficio SP C811DN Laser Printer
How to clear the pcu code
The printer is set to display the "replace PCU" message after a set number of copies. The only way to clear the message is to replace the color PCU that the message mentions.
Apr 17, 2010 | Ricoh Aficio CL2000N Laser Printer
Ricoh Afiicio CL2000 Color register error.
You can try to reseat the color PCU, but you may have to replace it. Also, make sure all of your color toners are seated properly.
Jun 28, 2009 | Ricoh Aficio CL2000N Laser Printer
Error code sc440
Black drum motor error. These machines are bad about the waste toner building up in the drum unit. You could try and take the auger out of the drum unit(very messy) and clean it out or try replacing the black pcu.
Mar 17, 2009 | Ricoh Aficio CL2000N Laser Printer
Thin lines along left side of Ricoh CL2000N laser printer
Printing B&W? Colour? or both?
Depending on your answer, replace the applicable Photoconductor.
Mar 02, 2009 | Ricoh Aficio CL2000N Laser Printer
Error message on Ricoh Aficio BP 20 PCL 6 printer
Flashing orange means low toner.....solid red should be a paper jam
Feb 20, 2009 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000N Error SC441
It means the PCU (CMY) motor error.
Try removing and reinserting properly the CMY PCU drum or replace it with a new one.
Jan 08, 2009 | Ricoh Aficio CL2000N Laser Printer
You may have to replace the transfer belt or the drum. I would start with the drum first
http://www.websitetoolbox.com/mb/copierquestions
Sep 02, 2008 | Ricoh Aficio CL2000N Laser Printer
My printer's nuts!
you need to replace the black cpu, if you go to their website it will tell you how to replace it step by step
Sep 05, 2007 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio CL2000N Laser Printer Logo
4,959 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Inky Fingers
Inky Fingers
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
