Question about Car Audio & Video
My Amplifier 900.2sl does not turn on. Could you please tell me how can i check it?
    Master:
  • 444 Answers
Have you check if a fuse has (Blowin) On it?
Posted on Oct 25, 2012
Amplifier will not come on and when i hook the amplifier up the the radio comes on without the car being on
did you check to see if your remote wire for the amp as connected to the ignition wire thats the most common mistake. the ignition wire is the one to tell the radio and amp when to turn on and off it sounds like you have it hooked up to a constant 12 volt which is the battery wire. the ignition wire is the one that is 12 volts only when the car is turned on.
Jul 29, 2010 | Rockford Fosgate Punch P5002 Car Audio...
The two 5 amp fuse inside the amplifier keeps blowing
That must be the inrush current.
Maybe you are using the wrong fuses.
Please check if those are fast or slow types.
You need slow types.
Good luck,
Gerard
Jan 17, 2010 | Audio Players & Recorders
Turn tv on - no sound?
have u check the menu??? where u can move the audio optons, panasonic has 3 options:
speakers on
speaker off variable pre out (u can connect and amplifier and when u up the volume in ur tv then u turn up the volume in the amplifier)
speaker off continues out (u turn on and down the volumen directly on the amplifier)
try to connect an amplifier to the tv an see if u have sound.
i u dont have sound neither the amplifier the audio in the tv must be damaged.
good luck
Jan 12, 2009 | Televison & Video
Sound cuts when volume is turned up
check that power amplifier rating(how many watt)must be more than total speaker rating by 20% at least..
exampel:if speakers watts are 100 watt-amplifier watt must be 120 watt.
Mar 14, 2008 | Technics SUV500 2-Channel Amplifier
Reset button
Without owning one , I checked the manual and, sure enough, there's no circuit breaker shown. I mailed tech support. Meantime check where the AC comes in and the fuse holder ( unplugged) and see if you can find anything.
Jan 03, 2008 | Pyle PZR-1000 Amplifier
Help please
Check your power cable, for bad connections.
Make sure voltage dont drop below 10.8v.
Nov 30, 2007 | Kicker IX404 Car Audio Amplifier
Amplifier Not powering on.
Amplifier power problems are generally pretty easy to troubleshoot as long as you have access to a digital multimeter. You need to check the DC volts on the power terminal and on the remote terminal. For the amplifier to turn on, each terminal needs to show around 12 volts. From the sound of it, I suspect a problem with your main power wire, but the multimeter will make certain. If you show voltage on both terminals (with the black probe on the ground terminal) and the amp still doesn't turn on, then there's a defect in the amplifier.
Jun 25, 2007 | Alpine PDX-4.100 Car Audio Amplifier
Aiwa amplifier doesn't work
the amplifier circuit is not working trying repacing the ic
Jun 04, 2006 | Aiwa HT-D780 System
Car Audio & Video Logo
15 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
