Question about Axial Syma 9086 Helicopter
Need spare part for double horse 9086 helicopter part, main rotor
Part num 9086-02 main rotor blade A
  • Anonymous Mar 31, 2014
    I have a tracerjet RC helicopter. I keep breaking the tail rotor. I have found a replacement kit that includes all rotor blades is there some place one can buy a package of tail rotors only.
Hi, you can get all the parts you need for this model from Hobby-Field.com.They come from Australia but it is quick and a lot cheaper than anything you can get here if you're lucky.
good luck johna4941
Posted on Jan 10, 2009
IF THE ROTOR POINTS TO NUM 1 CYL DOES IT ALSO POINT TO THE NUM 1 PLUG TOWER ON CAP
Don't worry about actually pointing toward # 1 cylinder, just the tab under cap that goes to # 1 spark plug wire. # 1 cylinder needs to be at TDC on compression stroke, and rotor pointing at # 1 wire tab under cap.
Jan 15, 2014 | Dodge Ram 1500 Cars & Trucks
I recently purchased a Fast Lane Hawk 4 rc helicopter. After a few small "crashes", it shakes and doesnt fly well. Does the top rotor need replacing, and if so, can I get the parts for it?
I have the same one, i have searched long and hard for parts for this without much sucsess, allthough i have found this on ebay, the blades and rotor look very simular
http://www.ebay.co.uk/itm/Metal-3-Ch-RC-Mini-Helicopter-Main-Tail-Blade-SET-G-/140315300745
Its slightly diffrent but i think the blades should fit the hawk 4. In the mean time i shall keep looking.
Sep 20, 2011 | Toys
Top blade wont spin help.
the top blade should not spin unless the main rotors are turning as this gives the copter forward and sideways movment it should be secured with a small grub screw to the main shaft
hope this helps
Aug 08, 2011 | RC Remote Control Rc Helicopter
Exceed Rc 2.4 Ghz WarHawk 300 RTF Co-Axial Airwolf replacement of main rotor gear. Do I drop motor out of fuselage by removing bottom blades?
In order to get at the main rotor gears, you'll have to remove both sets of rotor blades and drop the chassis. After removing the battery cage you should be able to access the two main gears. You don't need to remove the motors, but if you need to access the main gear for the lower-rotor, further dis-assembly is required. I think there's a link to a dis-assembly video for the Exceed models on rcdiscuss
Sep 20, 2010 | Exceed-RC Toys
Replace tail rudder blade on walkera cb 180d
yea cut it off longways down the shaft with large parrot nose plyers finish with little ones back up shaft and drive on rotor with small deep well socket simple!,
Apr 01, 2010 | Walkera #35C: Main Rotor Blade (Fiber...
How do you remove and replace the main rotor on the Havoc Stinger? I wasn't able to find a replacement blade for this specific model. Will the replacement blade for the Havoc heli work. Mine is clear not...
I just experience breaking my 1st main rotor and replaced it.
What you need are a pair of needle nose pliers and a hair dryer.
Put the hair dryer on "HOT" and blow on the rotor plastic shaft for
about 1 minute. Then take the needle nose pliers, lightly clamp
them on the plastic shaft and lift. It should slide off the metal shaft.
Next I took the hair dryer again and heated the replacement rotor
shaft for about 1 minute and pushed in on the metal shaft with my fingers.
Hope this helps.
Dec 25, 2009 | Air Hogs Glow In Dark Havoc Stinger Rc ...
Blade 400 i have no rudder response at all
I have a Blade 400 myself. If there is no rudder response, of which you mean the tail rotor is not rotating, it could be that the belt has snapped. Unless you had a crash, could you make it more clearly on the subject on how did you mean by the rudder not responding? Have you crashed it, have you checked if the tail rotor rotates when the main rotor is also rotated by hand? And have you checked if the tail rotor rotates freely? If so, No 1 culprit is the belt leading to the rotor. The belt is supposed to last a very long time. I wonder if this is a rare occasion that the belt could have caused this problem. Check it out and come back here. ;)
Sep 18, 2009 | E-Flite Blade 400 3D RTF Electric Mini...
Axial Syma 9086 Helicopter Logo
473 people viewed this question
Top Axial Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Axial Toy Expert? Answer questions, earn points and help others
