Question about IBM Lenovo ThinkPad T400s Notebook - Core 2 Duo SP9400 2.4GHz - 14.1" - Black (2808DHU)
Screen reads ThinkPad to interrupt normal startup press blue thinkvantage button - does not startup
5 Suggested Answers
  • 177 Answers
SOURCE: IBM Lenovo Thinkpad R61 gets 1 long & 2 short beeps on startup
Try this:
Open two RAMs, clean them properly and connect only one RAM then try. If nothing changes, then remove the RAM and insert the other one. And try again.
If this fails too, then there is a good chance that you have motherboard related problem
Posted on Nov 26, 2008
sijudoniston
  • 134 Answers
SOURCE: IBM ThinkPad R50 restore factory settings
You might have deleted the Hidden partition within the drive .So you will not get the restore factory setting option
Posted on Aug 27, 2009
  • 3278 Answers
SOURCE: Instructions say to use the Acess IBM button when
Hello, Salvador.
For most IBM system, select F11 at bootup to start the Product Recovery program.
Hope this helps.
Posted on Jul 18, 2010
hunter19_46m
  • 7482 Answers
SOURCE: laptop can't start after the
Hi...haommo...
Here are a few things to try
Start your computer in the Safe Mode.
To start in Safe Mode
Turn your computer on
Keep tapping F8 while the computer is starting up
When the computer starts select Safe Mode
1. Uninstall any softwear you may have put on the computer before the problem started.
2. Do a complete System Restore: Start>All Programs>Accessories>System Tools>System Restore.
This will bring your system back to a time before you installed the softwear or Microsoft installed drivers,etc.
Note: Just be sure to use a date in a darkened box before your trouble start date.
When you have done the above, restart the computer and if your still getting the blue screen of death, the installed drivers,softwear,etc might have
corrupted the Operating System.
If that happened then that means either repair or reinstall the operating system.
You will need to do the following:
1...Repairing the Operating System...
A...You will have to have the Operating Dics that came with the computer.
Note...If you do not have the disks that came with your computer or the ones you should have made when you first got your computer...then you will have to go to the manufacture's webpage and see if they have a recovery disk available for your computer, if they do not a recovery disks available then you can also try ebay to locate the recovery disks.
The original disks will have your product key number that came with the computer, you can also find it on the tower, or under the bottom of your laptop, or maybe the piece of paper that the CD orginally came in may have the number on it.
You can also download a small program and it will tell you your product key number.
Go to the following webpage to download your FREE key finder.
http://www.magicaljellybean.com/keyfinder/
B...You will now insert the disc into the CD/DVD player
C...Restart the computer
D...When the window opens that tells you to press "Any" key, you will press any key you want to press.
E...If you do not receive a message that says "press any key to boot from CD", then then the computer is not ready to boot from a cd.
To correct this problem you will have to go into your computer's Bios and change the computer to boot from a CD.
To get into the Bios, shut the computer off,restart, while the computer is starting up keep tapping F1 as the computer is starting up.
When you are in the Bios, select to boot by CD by moving the cursor with the direction arrows on the keyboard.
Once you have selected to boot by cd the exit and restart the computer...the disc is already in the cd/dvd player.
Your system will then boot from the cd.
F...After a minute or less it should ask you if you want to Quit Repair, or Continue.
You will select Repair this time, but you may have to come back here and select Install if the repair does not work.
It will ok the agreement document if it asks you too.
Tap F8 on your keyboard to pass it when ready.
It will ask you if you want to Install, Repair, Delete Partition, or Quit.
Select Repair
Inside the box there will be one or two partitions.
Choose the largest partition.
After you have chosen the largest partition, you will then press the "r" key to start the repair
After the repair is complete, then you will need to restart your computer.
G...Computer Restart
After the repair is complete, shut the computer down (the computer will shut down a few times during the installation of the operating system
that is normal).
Then restart your computer, when the computer restarts it will have a box to put your product key...put the product key in the box and click.
The computer should start up and run as if it was a new computer.
You do not need to re-register
You can now remove the disc.
If this fails to clear your blue screen of death then you have a hardware problem.
It could be faulty ram
If you still get the BS (Blue Screen), then you have two choices.
1.Reinstall the entire Operating System and you may have to update some drivers.
This will require you to go back to the start of the repair info and select Install instead of Repair.
2..Take your machine in to have the hardware tested.
Keep in mind that if you do a complete reinstall of the Operating System you will lose all the information on the computer,such as pictures, programs, videos, everything you installed will be gone.
Please take time to rate me four thumbs up
Posted on Sep 09, 2011
Screen is blank when the computer is turned on
The IBM ThinkPad is a brand of laptop computer developed by IBM. In 2005, Lenovo bought out IBM's laptop division. ThinkPads are like most laptops in that their screens are one of their most delicate features. If a screen is exhibiting problems, knowing how to troubleshoot the issue can save you a headful of worries and get you to the source of the problem.
No Video If you are experiencing no video from your display, make sure the laptop is powered on. The ThinkPad has a power status indicator on the body and will be illuminated if the computer is turned on. Once you verify that there is power, check that the laptop is not in sleep mode by holding down the "Fn" key for 10 seconds. If you are not in sleep mode, try to toggle the ThinkPad between external display and internal display mode. You can do this by pressing down the "Fn" button with the "F7" key. b> Verify Working Internal Display If you are not receiving any video when your computer is on, there is still a chance it could be a software issue. Turn off your computer. On the ThinkPad A, G, R, T, X and Z series computers, you can boot up in a basic level of the computers operation called BIOS to verify that the screen works. When you restart the computer, press and hold the button according to your model to turn on BIOS. This will either be "Press F1 for BIOS Setup Utility," "To interrupt normal startup, press the blue Access IBM button," or "To interrupt normal startup, press the blue ThinkVantage button." You can find out how to access BIOS for your particular ThinkPad model by referring to your owner's manual. Removing the Screen If you have a picture on your screen, but it is faint as a result of lack of light, adjust your brightness settings by holding down the "Fn" key as well as the "Home" button. If you do not get an adjustment in brightness, you may have a faulty backlight or inverter. If it is the backlight of the screen, you may need to change the inverter board. This is a small circuit board that controls the brightness of your LCD. If your computer is under warranty, take it in to Lenovo and have it repaired. If it is not under warranty, you can attempt to take it out yourself by removing the screen. For this job, you will need a screwdriver as well as a knife. Remove the screws around the screen housing and remove the small plastic covers with your knife to get at hidden screws. Use your knife to pry off the front bezel of the screen. The bezel is a plastic piece that frames your LCD. Remove any screws from around the LCD screen to remove it. At this time, you can replace the inverter board, the LCD panel or the LVDS cable--the low-voltage differential signaling cable that that sends graphics from your computer's graphics card to your screen.
Feb 26, 2013 | IBM ThinkPad T60 Notebook
Would like to reset my ibm laptop it says my mircosoft online service is temporarily unavailable and my laptop is slower than ever
Hi and welcome to Fixya1
To reset the machine back to the factory settings, just follow these steps:
    • 1 Shutdown your machine and make sure that the charger is plugged in before doing the reset. Turn on the machine.
    • 2 Press the blue Access IBM button on your ThinkPad keyboard at the screen prompt. The screen prompt reads "To interrupt normal startup, press the blue Access IBM button." This interrupts the Windows reboot process.
    • 3 Double click "Recover to Factory Contents" at the Access IBM predesktop menu.
    • 4 Follow the recovery wizard prompts to initiate the factory restoration process. Your ThinkPad will automatically reboot upon completion.
Hope this helps!
Takasashi
Jul 19, 2011 | IBM ThinkPad R40 2722 Notebook
I want to repeat my question again as follow: I turned on my Lenovo T60 it can not log in to Window because it show the check date and time message after that it show the Key's picture then I restart...
according to the levono support page at this link: http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=YAST-3JWKJX
below is taken from the web site for a T60
Press the blue ThinkVantage button when the message "To interrupt normal startup, press the blue ThinkVantage button " is displayed to enter the ThinkVantage Productivity Center, then select Start setup utility to open the BIOS Setup Utility.
May 15, 2011 | IBM Computers & Internet
When I boot up my t61 it starts to spin up then halts. The AC power and battery power indicators are green as is the power indicator. I thought it might be overheating so blew out the fan with...
Most likely the hard disk has just died - try to access the BIOS and see if it's still recognized. For that ress the blue ThinkVantage button when the message "To interrupt normal startup, press the blue ThinkVantage button " is displayed and then select Start setup utility .
If nothing appears on the screen then the defect is in the motherboard - you will need to take it to a service center to determine if the board must be replaced.
Apr 02, 2011 | Lenovo ThinkPad T61 Notebook
Forgot cmos password after cearing cmos not able to boot from harddisk. Pls assist me how to remove cmos password of ibm T60 laptop
I just helped a friend out with this exact issue on the same notebook. Here is the instructions (step by step...well 4 steps) that worked perfectly. What you are doing is using a backdoor password set up by IBM/Lenovo.
Turn on your Thinkpad T60 computer.
  • Watch for the status message "To interrupt normal startup, press the blue ThinkVantage button" to appear on the screen. The only time you have the ability to access your BIOS is while this message is on your monitor. If this message disappears, you will have to restart your T60 and try again.
  • Press the "ThinkVantage" button on your T60. From the list of options that appears, select "Start setup utility." You will be prompted to enter your BIOS password. Type "merlin" and hit "Enter" to bypass the password prompt using your backdoor password and enter your main BIOS utility.
  • Select "Security." In this window, select "Set Password." Type the new password you want to use for your BIOS. Press "Enter" to finish resetting your T60 BIOS password.
  • Hope this helps...
    Jan 03, 2011 | IBM ThinkPad T60 Notebook
    My laptop will not boot - Operating System Not Found, cannot enter BIOS system - nothing at all. When I try to access the BIOS, the key keeps beeping. It is a Type 2373. Thank You -- IMCND
    How are you attempting to enter the setup (BIOS)? Here are the steps:
    Press the blue Access IBM button when the message "To interrupt normal startup, press the blue Access IBM button" is displayed to enter the ThinkVantage Productivity Center, then select Start setup utility to open the BIOS Setup Utility.
    Feb 18, 2010 | IBM ThinkPad T42 Notebook
    My T23 IBM enters splash screen,but will not enter the bios page.
    While the "To interrupt normal startup, press the blue Access IBM button" message is displayed at the lower-left area of the screen, press the F1 key. The BIOS Setup Utility menu will be displayed.
    Jan 22, 2010 | IBM ThinkPad T23 2647 Notebook
    Lenovo thinkpad R51e , when i power on the laptop it show error code 271
    You need to set time and date in BIOS.
    Aug 10, 2009 | Lenovo ThinkPad R51e Notebook
    Help cannot get into my thinkpad labtop lenovo t61
    Turn the computer on and then wait for the startup ThinkPad screen. then press the blue ThinkVantage button on the upper left of the keyboard. This should bring you to the rescue and recovery applications on the computer and help you diagnose and hopefully recover your system.
    Mar 02, 2009 | Lenovo ThinkPad T61 Notebook
    IBM Lenovo ThinkPad T400s Notebook - Core 2 Duo SP9400 2.4GHz - 14.1" - Black (2808DHU) Logo
    123 people viewed this question
    Top IBM Computers & Internet Experts
    Computer Links
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
