Question about Aiwa AV-D58 Receiver
Poor sound/very low sound controls having no effect
On my av-d58 it plays for about 5-10 mins then gose with a pop across the speakers and the sound goes very quite, the volume control has no effect switch it to anyother setting like video1 or video2 or aux and you can still hear the cd still comming thourgh the speakers but very quitely. turning it off and leaving it alone for a couple of weeks and then it works fine for about 10 mins then it goes pop again back to low sound distorted and realy horrible, i love this unit please help
  • Aiwa Master
  • 5,650 Answers
That sounds like the main amp is failing. I suspect the unit will have one IC as the power amp, which will need replacing. You can have a look inside to see if you can see something like this:
poor sound/very low sound controls having no effec - power ic-ukkvwzzuppijvxoxp10or3yb-2-0.jpg If you do. Make a note of the number on it, it might say something like STK563. Then put your number into Google and it will give you a clue to how much it will cost and if it is obtainable. You can then either fix it yourself if you have the skills or take it to the repair shop.
Posted on Jun 21, 2017
techman
  • 3130 Answers
SOURCE: Center, surround speakers not working. "Can't Use" message for DSP.
Sounds like the old stuck button thing after a move??? What i mean it go over all the push buttons and maybe you will find one that is not pushing in and returning??? If alls ok then you should check the obvious like bent shafts or balance controls ect. ay have jogged something inside and you will need to see a pro to assit you unless you know how to trouble shoot solid state electronics?? These units have no real serviceable parts inside. Check with your owners manual for the sevicer nearest you. If they are not listed call the service # or try 1-800-289-AIWA . good luck
Posted on Jun 06, 2006
techman
  • 3130 Answers
SOURCE: no remote control
Nope sorry you will need to get a remote for this unit. i found you one from an original remote replacement place. it is just like the remote you do not have. Go to http://www.remotes.com/remotes/servlet/rs?a=gmi&uid=11741955727330&smodel=AVD58&brand_pn=AIWA_AVD58 To order a replacement remote. Sorry this is all that can be done in your case. Good Luck
Posted on Mar 18, 2007
dsom
  • 56 Answers
SOURCE: AV-DV75 center speaker works surround speakers do not
If all others had been fine before this problem arose, and you are sure that you haven't changed anything in your amplifier's channel selection menus, the problem might be deeper to solve! Try these out; 1-If the amplifier has a test menu to check out all channels plugged in, activate it. You must be able to get sound, which is like rustle, from each speaker. 2- Check your plugs, cables etc. be sure that there isn't any short circuit 3- Grab your amplifier's remote control and find the "channel selection menu" that allows you to increase and decrease volume levels for each speaker independently.
Posted on Apr 15, 2007
snakehead
  • 1074 Answers
SOURCE: AV-DV75 volume control not working
Hi Deebo check the following website www.dalsani.com www.repairworld.com good luck open the set and you will find the part number printed on the body of the component. NB.but i am in the belief that it IS your IC that is damaged.
Posted on Apr 26, 2007
  • 4234 Answers
SOURCE: I have a Aiwa Stereo Receiver Av-D58. The sound
If I remember this model correctly, there is only 1 direct input. The remainder of the inputs are bufferred through a switching IC. It is likely that this IC is defective. Are there any other symptoms at all?
Thanks,
Dan
Posted on Mar 13, 2009
AIWA AV-D58 receiver ECO problem
Hi, I've found the problem. There was a closure in the Sorround Amlifier, and the protect circuit stopped the whole receiver. Br., csdombi
Jan 05, 2010 | Aiwa AV-D58 Receiver
Model AV-D58 red light on but unit not turning on no display not sound
I had the same problem, there was a closure by the Q335 transistor in the sorround amplifier. You have to abolish this. Br., csdombi
Jan 02, 2010 | Aiwa AV-D58 Receiver
What kind of wire do I need to connect the subwoofer to the av-d58? The subwoofer is the same that came with the receiver but I have somehow misplaced the connection wire.
Without knowing more about the subwoofer (powered, passive, what kind(s) of input it takes, I have to take a wild guess. Most powered subwoofers use the old standard RCA cable. I there are two jacks on the sub for Left and Right input you just get an adapter to make the cable plug into two jacks.
Dec 01, 2009 | Aiwa AV-D58 Receiver
Popping sound at random times out of my AV Reciever/Surround sound system when video is playing.
Clean and tighten all connections. Get a can of spray tuner and contact cleaner from Radio Shack to clean the volume and tone controls if you have access to the body of those controls. Some disassembly required. If this doesn't help, suspect a bad variable resistor in the amplifier circuit.
May 29, 2009 | Sony STR-V444ES Receiver
Thanks,
Dan
Mar 13, 2009 | Aiwa AV-D58 Receiver
Sound problem
Make sure all speakers that are hooked up sound ok. If any of them sound lower then the others or sound distorted you may have a speaker with a partially shorted voice coil. If speaker or speakers pop when power is first applied you may have a grounded speaker that should not be grounded. Each speaker wire rides on 6vdc and if any speaker sees a ground you will have 6v across voice coil which would explain any popping noise when first turned on and radio may play for awhile then overheat. be sure speakers are 4 ohm min per ch otherwise amp will run to hot. Just a few Guesses
Jan 13, 2008 | Denon AVR-1708 Receiver
No remote control
Mar 18, 2007 | Aiwa AV-D58 Receiver
AIWA AV-D58 RECEIVER
On 5.1 receivers, some inputs can be switched to Digital/Optical/Coaxial instead of Analog (RCA cables) - look for an Input Mode button. If this doesn't help, turn the unit off, then power it on. If you don't hear a click 3 to 7 seconds after turning it on, it may be in Protect mode, and simply be a coincedence that it failed after installing the new cables. This can be caused by several things, most of which require in-shop service.
Jul 11, 2006 | Aiwa AV-D58 Receiver
Aiwa AV-D58 Receiver Logo
85 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
