Question about Microwave Ovens
My microwave is always running
My microwave runs whenever the door is closed. In addition the display only shows a semicolon. Help me, please.
  • Microwave Ovens Master
  • 9,047 Answers
It looks like your model is "GH4184XS##" If so, this sort of symptom is common in cases where the cooktop lights blow.
Several components on the control circuit board can be damaged, and other strange symptoms can occur.
But we see (and repair) this a lot. The problem is on the control board, which we regularly repair for $39.95.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This failure often occurs when a cooktop bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
If you prefer, you can purchase a new control circuit board from the Pros here, our favorite supplier.
You can look up part number based on your full model number here.
Posted on Oct 26, 2012
SOURCE: Fan runs when door is closed - no heat
This is normally 1 of the interlock door micro-switches not working.
Posted on Jun 20, 2007
SOURCE: WST3501 Problem
I would like to know if you still have the instruction book for your WST3501? And if so is there anyway you could email me a copy of them I have lost mine. Please and Thank you mndutch@yahoo.com
Posted on Oct 02, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp microwave runs when door closed
This is usually caused by either a bad door switch, a loose door switch mount, or sometimes a problem on the control panel.
I would suspect the door switch mount has a broken tab allowing the switch to swing down when the door is closed, not allowing it to really be activated.
Also, even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 02, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave oven runs with door open
This is usually caused by either a bad door switch, a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Profile Spacemaker 2.0 Microwave
If it goes dead or blows the breaker or GFI when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
Unit starts automatically when door is closed
please review this and fix it. God bless you
  1. Interlock switchIf your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  2. Main control boardIf your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replaced.
Nov 18, 2013 | GE PSA2200RBB Microwave Oven
I have a Whirlpool GMC305PDS07 Oven Microwave combo. The microwave display shows "Door" and it won't start. The door looks fine and closes properly. Is there anything I can check or do before...
Sorry to read about your problem, I hope this helps you out.
sound like you have a defective door closed switch
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 20, 2010 | Whirlpool GH7145XF Microwave Oven
Turntable and Fan won't stop running when door is open.
With the model number, we can offer more specific advice or an estimate.
But since FixYa does not notify us of follow-ups, you will need to post a new help request.
May 31, 2010 | GE JE1640 Microwave Oven
Display screen shows an F-6 and it quit working
F6 usually means that the cook relay is stuck on the control board.
So it probably is running whenever the door is closed. This can be dangerous, and can cause a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
prototech@usa.net
May 18, 2009 | Microwave Ovens
Fans runs when door closed, light always off
The first thing to replace is your technician. *grin*
You have a shorted main relay (lamp relay) on the control circuit board and a burned out light bulb.
You do not need a new board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Page 24 of your owner's manual shows you how to replace the light bulb. Be sure to unplug it first.
If you don't have your manual, you can download it here.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Dec 13, 2008 | Maytag MMV1153A Microwave Oven
Runs whenever door is shut, displays "8 lo code", can't cancel
This is usually a shorted keypad or a problem on the control board.
We regularly repair these for customer nationwide for only $39.95, plus parts cost if a keypad is needed.
prototech@usa.net
Jun 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp Microwave oven controls do not work
You mean the turntable motor turns whenever the door is shut, even if you're not cooking?
If that's the case, then the problem would probably be a stuck relay (RY3) on the control circuit board, which we regularly repair nationwide for $39.95 postpaid.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
If you have a different problem than I described, please reply back with details before you give us your rating.
Feb 18, 2008 | Sharp R-1460 Microwave Oven
WST3501 Problem
We have had problems like this before. Most likely the smartboard is defective.Check with manufacture to see if there is a recall.You should be able to find them on the web.
Nov 02, 2007 | Microwave Ovens
Error code of F-3.
F3H —Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
The microwave oven may be provided with a self diagnostic routine that can be operated through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "—" is displayed.
If you want to try to fix it your self, Always remember Electricity is dangerous and should be treated with respect.
Microwaves are very dangerous, they can still shock you even unplugged!!
Use a metal ( not the shiny chrome type ) screw driver with a insulated handle to short across ( touch both at the same time ) the terminals of the high voltage capacitor to discharge it. With the microwave unplugged.
If my attachment made it, it shows a common way to do this....
Good Luck!
Microwaves are very dangerous, they can still shock you even unplugged!! These pages are to help give you indications of what might be wrong and some safe "how to check" or repair help.
Oct 29, 2007 | Kenmore 62702 Microwave Oven
WST3501 Problem
Oct 15, 2006 | Westinghouse WST3501 Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
