Question about HP P2055DN LaserJet Monochrome Printer
False jam in output bin hp 2055 - HP P2055DN LaserJet Monochrome Printer
EPIJAB
  • 89 Answers
SOURCE: paper jam
That part is the fuser unit and is hot if the printer is on. Here are instructions for you. Good Luck!
http://www.laserpros.com/pdf/HP%202600-2605%20fuser-etb.pdf
Posted on Aug 03, 2008
SOURCE: jam in output bin
Make absolutely sure there actually is no paper jammed in there.
I came to this page with the same warning, convinced I had a software glitch. Turned out there was a page accordion-folded down to the size of a pencil lead. I didn't know paper could be folded that small.
Of course, everyone here may be a lot brighter than I am, in which case sorry to waste your time. But for me, the obvious first fix needed to be thoroughly explored before cursing HP and their machine.
Posted on Sep 03, 2008
  • 24 Answers
SOURCE: how to clear paper jam in output bin
The printed page comes through the hot fuser at the top of the printer, through the exit rollers an end up in the exit bin.
We cleared a massive paper jam out of the fuser, by removing the grey surround on top of the printer. The plastic hooks that hold it in place get broken in the process, then you will the jammed paper between the fuser rollers, and the exit rollers. A technician can do it for you, but is unessersarly costly.
Posted on Dec 23, 2008
SmartFix
  • 89 Answers
SOURCE: My printer says there is a jam in the output bin
Just try the steps
Jam in output bin - fuser area Error messageJam in output binalternates withOpen door and clear jam DescriptionA paper jam has occurred in the output bin near the fuser area. Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.
Jam in output bin - duplex area Error messageJam in output binalternates withOpen door and clear jam DescriptionPaper jam in duplex reversing area Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.Please Rate my response!!!Thanks, SF
Posted on Jan 28, 2010
  • 224 Answers
SOURCE: Getting the error on my HP 4345mfp - TOP OUTPUT
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Posted on Mar 31, 2010
Output bin is full for hp laserjet 2055
Check the flag that hangs down as the paper is exiting printer.... sometimes the flag gets stuck in the up position..(causing the printer to think there's a big stack of paper needed to be taken off the machine...found this from another fixya member.
Dec 07, 2016 | HP Office Equipment & Supplies
Paper Jam errror
Error message
Jam in output bin
alternates with
Description
Action
  1. Clear the jam.
  2. Press the (SELECT) button on the control panel.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Error message
Jam in output bin
alternates with
Description
Action
  1. Clear the jam.
Goodluck..
May 14, 2008 | HP Color LaserJet 2600n Printer
Hp laser jet printer 2055 problem output bin in full?
If you have already removed the paper from the output bin, check the delivery flaps to make sure they move freely. If they do, remove the top and make sure the sensor flag isn't broken and that the sensor is connected and undamaged. If it is connected and undamaged, check connector J213 on the engine controller is seated correctly. If it is, you probably need to replace the output bin sensor. See attached video
Nov 18, 2015 | HP LaserJet Office Equipment & Supplies
How to fix error printer 2055 laser jet has massege output bin is full
there is a small flag sensor in the output tray over the roller that deliver the printed paper , its not return down after paper get out. so the the printer scene the tray is full , check it may lost if not try to lubricate the support pour it hasn't spring it move to its weight. or it may
Nov 12, 2014 | HP laserjet 2055 series 500 sheet paper...
Hp 9050 laser jet stacker error
Probably just a bad sensor or dirty sensor causing the issue.
Stacker or stacker/stapler output bins
For the 3,000-sheet stacker or 3,000-sheet stacker/stapler, the output bins are the upper bin (face-up) and the lower bin (face-down).
The upper bin (face-up) is the top bin on the stacker or stacker/stapler. This bin holds up to 100 sheets of paper in face-up order as they exit the printer. A sensor causes the product to stop when the bin is full. Product operation continues when you empty or reduce the amount of paper in the bin.
Lower bin (face-down) is the lower bin on the stacker or stacker/stapler. This bin holds up to 500 sheets of paper and can stack or staple jobs. This bin is the default output bin.
Aug 19, 2014 | HP Stacker For LaserJet 9040/9050/9500...
Display reads - " jam in output bin " jam was
look at the output area, make sure that the paper lever is working. Sometimes they come loose after a jam.
Nov 21, 2010 | HP Laserjet CM 1312NFI Color Printer
Paper Jam at HP LaserJet P2055d
There is output sensor where the papers come out, make sure its lowered down, be VERY CAREFUL not to break it.
Jun 11, 2010 | HP LaserJet P2055d Printer
My printer says there is a jam in the output bin but there is no visable jam. HP color laserjet 2600n
Just try the steps
  1. Clear the jam.
  1. Clear the jam.
Jan 28, 2010 | HP Color LaserJet 2600n Printer
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
Jam in output bin
Jul 08, 2008 | HP Color LaserJet 2600n Printer
HP P2055DN LaserJet Monochrome Printer Logo
101 people viewed this question
Seeker5211
Seeker5211
