Question about Texas Instruments TI-Nspire Graphic Calculator
Is there a way to show commas in large numbers
How to add comma in spreadsheet? thanks
To add commas to your spreadsheet you need the format the numbers. If you want your whole spreadsheet to use commas, click on the area to the left of column A and above number 1. This should highlight the whole spreadsheet. Click on the "," icon in the "number" area, and your spreadsheet will be formatted to put commas in.
Good luck,
Paul
May 06, 2016 | Casio Office Equipment & Supplies
I want 1000000 to appear as 1,000,000 in fx82es plus
I am afraid there is a misunderstanding. The sequence you describe changes the decimal marker from a dot to a comma. It does not insert a thousands separator.
May 13, 2014 | Casio FX-300MS Calculator
The calculator is showing a decimal point when there should be a comma. Ex. The number six hundred thousand is showing up as 600.000. I need help to change the decimal point to a comma.
don't know exactly what operation system u have.
On windows xp go to:
start, control panel, Regional and Language Options and at Standards and formats u should select English (United States)
On windows 7:
start -> control panel -> Clock, Language and Region -> Region and Language and at Format: select English (United States)
Sep 13, 2011 | Computers & Internet
HOW,AFTER DIALING A NUMBER,DOYOU ENTER A PIN #?
using a comma ',' for evey three second delay you need until the PIN needs to be keyed.
so for example:
8005551212,,1234 will dial the number 8005551212 wait 6 seconds then dial 1234
you can key in a comma by holding down the * key until it changes to a comma
Sep 26, 2010 | Apple iPhone 3G
I just replaced the batteries in my HP 12C calculator and when I turned it back on the display looks like this 0,000. How do I get the display to show decimals instead of a comma?
Here is what the manual for the HP 12C Platimum financial calculator says on page 17 of 275
Digit Separators
As a number is keyed in, each group of three digits to the left of the decimal point is automatically separated in the display. When the calculator is first turned on after coming from the factory — or after Continuous Memory is reset — the decimal point in displayed numbers is a dot, and the separator between each group of three digits is a comma. If you wish, you can set the calculator to display a comma for the decimal point and a dot for the three-digit separator. To do so,
turn the calculator off, then press and hold down the [ . ] key while you press [ON] Doing so again sets the calculator to use the original digit separators in the display.
Hope it helps.
Oct 06, 2009 | HP 12c Calculator
Where do I find the comma button on the TI-84 siver edition?
The comma is located on top of number 7 key.
See page 5 on teh user manual to learn how to operate the keyboard on a TI 84 Plus:
TI-84 Plus TI-84 Plus Silver Edition Guidebook
Mar 16, 2009 | Texas Instruments TI-84 Plus Silver...
How to set commas for 1000s display?
Sorry, but this calculator doesn't give you digit separators.
Jan 09, 2009 | Texas Instruments TI-30XA Calculator
Wrong format for numbers displayed in HP 12C
It's been awhile since I used one of these but there should be a decimal function on the keys. Make sure you put a 2 in there before pressing it and it should display the format using 200.00
Nov 30, 2008 | HP 12c Calculator
Display shows comma in place of decimal point?
To change the ´comma´, make sure the calculator is switched to off, press (.) key and maintain, switch the calculator ON. This operation changes dot to comma and vice-versa.
Jul 18, 2008 | HP 12c Calculator
Texas Instruments TI-Nspire Graphic Calculator Logo
107 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
