Question about Panasonic NN-T774SF Microwave Oven
I have a Panasonic microwave. It is Model NN-T774SF. It has an inverter. The latch on the door will not close. Is it worth the cost of repair?
  • Panasonic Master
  • 9,047 Answers
This is usually a pretty simple fix.
The spring has probably become disconnected from the door latch head assembly or inner door panel.
If so, you can either order a replacement for the broken part, or install a small screw into the broken part, reinforce it with epoxy, and then reassemble everything.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the parts involved.
Or you can watch a
YouTube video (not a video I made) that demonstrates how it's done.
Posted on Oct 26, 2012
Help! I have a Panasonic model NN-T695. The door was stuck closed. A tiny part of the door lever was broken off.
I hired a repairman to fix it. He disassembed the microwave from the back panel to get accress to the door latch. He took out the dorr lever, and put in a small screw into the plastic door lever, to replace the bit of plastic that came off.
Now I have a NEW PROBLEM. He tried to re-assemble the microwave...Now when it's turned on, it shuts off after exactly 2 seconds. The microwave in inoperable now. What can the problem be?
Posted on Feb 22, 2013
2 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: I have a Panasonic Inverter Model NN-T664.It acts
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Oct 11, 2009
Testimonial: "THIS SOUNDS LIKE EXACTLY WHAT THE MICROWAVE IS DOING.. I BELIEVE NOW IT MAY BE WORTH REPAIRING. THANKS"
Panasonic microwave convection oven model NN-CD997S works normal but stop heating
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
Jul 03, 2017 | Panasonic Microwave Ovens
Panasonic nnt774sf door will not remain closed. It appears the top plastic piece on the microwave itself (not on door)that the hooks latch on to is broken. Is there a way to fix this?
You can purchase parts for Panasonic microwaves but home repair is not recommended due to them being lethal if you do something wrong. I would find a good local repair shop and they should be able to find the part and repair. It might not however be cost effective, depends on the part price.
Mar 11, 2010 | Panasonic NN-T774SF Microwave Oven
NN-T774 INVERTER STOPPED WORKING AFTER 4 WEEKS
Check to make sure one of the plastic hooks on the door was not broken off. If both door hook latches are functional then the most likely cause of your problem is one of the latch switches located behind the control panel. These switches will fail if the oven user opens the door frequently BEFORE the cook cycle ends. Always push STOP/RESET before opening any microwave oven door.
Dec 30, 2009 | Panasonic Microwave Ovens
Oct 11, 2009 | Panasonic Microwave Ovens
Door does not secure when closed
Hi , Either you have a faulty door interlock switch(es), or the door latches (on the door) have been damaged and will not activate the interlocks. either way, you have to be conversant with adjusting microwave latch assemblies once the repair has been effected AND THE USE OF AN OVEN LEAK DETECTOR IS IMPERATIVE for final testing or the end user will be subjected to harmful levels of microwave radiation.
Jan 05, 2009 | Panasonic NN-S753 Microwave Oven
Door will not latch
The door switch mechanism is broken. Microwave doors have a special arraingement of double switches to ensure it is not open during cooking. Because everything is made from plastic nowadays, stuff like this breaks easily. The switches are commona nd cheap but the mounting parts may not be.
Dec 28, 2007 | Panasonic NN-T774SF Microwave Oven
Microwave door won't latch
Waveless, You're going to have to determine which side of the latch is the problem. Generally, you can do this with the mark 1 finger probe... See which half is 'sloppy' and get in there and tighten it. Note that if you are taking the door apart that you must replace everything as you found it...and don't mess with the hinges. Loose door seals can let microwaves escape. If anything looks like it needs adjustment: stop and call in a pro with the right tools.
Dec 16, 2007 | Panasonic NN-T774SF Microwave Oven
On for 2-3 seconds and shuts down with slight wire burning odor.
http://froogle.google.com is showing this model selling for as little as $100. But as a technician, I have never cared for the inverter models. As complexity increases...
Mar 21, 2007 | Panasonic NN-T774SF Microwave Oven
Panasonic NN-T774SF Microwave Oven Logo
729 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
