Question about John Deere Garden
I was mowing in thick grass and my ride on mower stopped. If I try to restart I can hear and feel the motor trying but it just wont get going.
14.5hp 38 inch cut
  • 430 Answers
You probably hit something unseen. First check under you deck to be sure a stick or something isnt wedged in there. Check your belt and pulleys on top of the deck.
Im tempted to say check the flywheel key or adjust the valve lash.
Posted on Oct 25, 2012
  • 52 Answers
SOURCE: craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Posted on Mar 11, 2009
  • 71 Answers
SOURCE: Craftsman 42 inch riding mower. Runs great
how old is your plug? try cleaning and regapping it or replacing it at any rate make sure it is gapped correctly also make sure there is no rust dust or debris is on flywheel or coil also the flywheel keyway does more than hold the flywheel in place it servs as a timing pin and sometimes the slightest wear on it can cause the machine to start hard but otherwise run great good luck hope you find the problem.
Posted on May 02, 2009
  • 125 Answers
SOURCE: A row of uncut grass left between blaces when mowing
Mowing too fast for the blade speed. Use higher engine speed or lower gear.
One or both blades too short?
Posted on Jun 16, 2009
  • 32 Answers
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
perpetually
  • 360 Answers
SOURCE: uneven grass cutting
I have seen dull blades, blades not installed right and an un-level deck cause that.
Hope this helps.
Posted on Sep 21, 2009
Procedure for adjusting valves on series 100 lawn mower
if you think it is a valve problem briggs and stratton website has a page that gives all the specs. for intake and exhaust vale setting. you will need to know your engine size and model number.
May 29, 2016 | Garden
John deere instructions
Your mower doesn't have enough power to handle very thick grass at high speed. You need to go slower across the lawn. That's easy to do if this is a push mower (just don't walk so fast) or if it's a self-propelled model with a speed control. But if it's a single-speed model you'll have to mow the lawn in fits and starts: squeeze the lever to move it forward; release it when you hear it bogging down; wait for the motor to reach full speed; squeeze the lever to move it forward again; repeat. Also, is the grass very high? If so, try setting the cutting height higher on the first pass, then lower it for a second pass. Finally, make sure the blade is sharp.
Aug 06, 2014 | Briggs & Stratton 190cc 875 Series OHV...
Why does my toro model 74301 keeps dieing
There are many reason a lawn mower dies in gear. Buildup of grass on the underside of the deck, mowing in too deep or thick lawn causing too much load on the blade, or the air filter needs cleaning.
Jul 19, 2014 | Toro Garden
The riding mower does not mow small strips in the middle of the row being cut. It almost looks like a bad haircut? This happens when I am going fast or slow. It is not a mulcher. This problem is...
Sounds like it is time to replace your blades, I have 2 scotts mowers made by john deere both machines are 9 years old I mow comercially and get 4 to 5 sharpenings the they need replacing.
Oct 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
B & D mulcher mower stop while mowing
electric & battery operation mower are not suppose to be use when grass are too long & wet, it draws lot of power that appear to runs slow.when you see try to restart i think the brake is trying to kick in.
Jun 15, 2008 | Black & Decker 19" Electric Lawnhog...
Mower won't start
13 to 15 amps electric or battery operated mower may runs slow when cutting thick grass. also recommended not to cut grass when it's wet & need very sharp blade to do the lawn. may overloading it, cutting grass too thick also draws too much power. check house breaker first.
Jun 11, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
101 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
