Question about Kohler 17RESL 17 kW Generator with 200 Amp ATS
My 17 k natural gas generator will start but emedatly shuts down. Even when i start it manualy it starts but shuts off within 4 seconds
    Prodigy:
    An expert who has answered 500 questions.
  • Kohler Expert
  • 573 Answers
Check oil, oil pressure, rotor rings for cleanliness and brushes, then rotor and stator for shorts
Posted on Nov 27, 2013
4 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: kohler 12kw generator starts but shuts down after 3sec
Your gas pressure is too low and you may not have a large enough supply pipe. You need at least 10 inches of water column with the engine running to operate an LP vapor fueled engine. Because the engine is starving for fuel, its governor opens the throttle to WOT (so it goes to high revs) but there isn't any fuel to make horsepower with so the output voltage falls and the undervoltage alarm trips.
Carl
Posted on Dec 03, 2008
SOURCE: kohler lp shuts down
What you need to know is there enough fuel going to the regulator. It should be 7 to 11 inches Water Column. If not your problem may be not enough fuel. That includes when the heater in your house kicks on and what ever gas appliance you may have. Once you verify that you need to figure out if you have the proper pressure coming out of the regular on the inside of the generator. Next I would look at compression of the cylinders. It may need new piston rings.
Posted on Oct 09, 2009
consaka
  • 661 Answers
SOURCE: Kohler Model 12RES LP gas generator starts
Sounds like a short in one of the windings to me. Can you verify that the engine rpm is not exceeding specs? If you can modify the engine speed Id say slow it down and see what the voltage read is.
Posted on Jul 22, 2010
I am getting an error code ags
AGS - Auto Gas Shutoff = Because of a problem sensed, the gas valve is closing, stopping gas supply and hence heater shutoff.
Improper water flow through heater! Check filter, pump, water supply lines, anything that will reduce water flow into heater.
A faulty Pressure Switch may cause this problem as well.
or...
In coming water to heater is over 104°
If all is good with the above, replace the AGS Switch.
May 31, 2015 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Generator is two yrs old only had a couple of outages maybe totaling thirty hrs Generator ran great and also ran every wk for its exerciser cycle. The generator didn't start on this cycle and the system...
Is this a natural gas fueled generator? Sounds like a fuel problem, i would go through the fuel system and find out whats wrong. If its a natural gas/propane unit its most likely a bad regulator or low pressure.
May 04, 2017 | Eaton Electrical Supplies
Kohler Generator won't start
If you have a drip leg near generator open that up for a sec and then try it again.
Nov 16, 2012 | Kohler Electrical Supplies
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
Nov 07, 2012 | Caterpillar Electrical Supplies
Generator starts up and then cuts out after 7-10 seconds. The cut out appears to be from a "shut down" switch as opposed to carburetor oriented (it's natural gas).
I don't recall, does your generator have oil monitoring, did you say you checked the oil. If it's a protection shutdown there may actually be an oil change timer as well.
Jun 24, 2010 | Briggs & Stratton Standby Generator 12 Kw...
Onda generator engine starts and then 3 or 4 seconds later stall
Oil pressure switch. Check it and make sure oil level is correct. The oil switch will cause this
Aug 31, 2009 | Electrical Supplies
Kohler 17RESL 17 kW Generator with 200 Amp ATS Logo
181 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
