Question about Texas Instruments TI-30 XIIS Calculator
Fx-300es plus calculater. how do i find square root?
Mattimeo310
  • 30 Answers
SOURCE: I need some help please : )
The parenthesis is there so u can put a number under the radicle. Just close the parenththesis once u put the number under the radicle
Posted on Nov 20, 2008
  • 7993 Answers
SOURCE: TI-15 square root Function
You should enter it as follows [SQRT]36 ) [ENTER/=].
If you define some function f of a variable x you write that f(x), where the parentheses enclose the so-called argument (objet on wich the function acts). It seems that on this calculator the opening parenthesis is implicit: the calculator supplies it when you press [SQRT] but does not display it (a design flaw?). However the closing parenthesis must be entered by you to signifie to the function [SQRT] that you have finished entering the argument. Weird but one can live with it.
Hope it helps.
Posted on Sep 07, 2009
  • 102366 Answers
SOURCE: The TI-84 Plus Silver Edition - when dealing with
Press the MATH key to bring up the Math menu. Option 3 gives you cubed, option 4 gives you cube root, option 5 gives you nth root.
For example, 3rd root of 8: MATH 4 8 ENTER gives 2.
4th root of 16: 4 MATH 5 16 ENTER gives 2.
Posted on Apr 01, 2010
Testimonial: "thank you thank you so much!"
SOURCE: square root of more than 2
(5) yx (1/32)
Posted on Dec 14, 2010
  • 102366 Answers
SOURCE: Have TI30xIIS calculator. How
To calculate the square root of 9, press
2nd [square-root] 9 ) =
The square-root is the shifted function of the x-squared key, just to the left of the 7 key. The close-parenthesis is needed to balance the open-parenthesis automatically inserted by the square-root function.
Posted on Feb 16, 2011
Testimonial: "I soooo thank you!!! You were very prompt, very easy to understand and made me SO HAPPY!! Regards"
How do I get my casio fx300es plus to give me square root answers instead of decimal?
To calculate the square root use the square root key, three rows above the "8" key.
If you want to see the result symbolically, press SHIFT MODE 1 to select the MthIO mode. Bear in mind that the calculator can only show some results symbolically.
May 02, 2013 | Casio fx-300ES Calculator
Radical calculation
There are limits to what the calculator can display in symbolic form, and roots beyond the second (square roots) are beyond its capabilities. Even something as simple as the cube root of 2 will be displayed numerically.
Mar 21, 2013 | Casio fx-300ES Calculator
How do I simplify a cubed root of a number on the fx-300ES?
It can handle square root but if result requires too much display space it will be displayed as a decimal.As to higher order roots such as cube , 4th and higher they are displayed as decimal. Sorry, there is nothing you can do about it.
Apr 18, 2012 | Casio fx-300ES Calculator
I dont know how to find the square root on my casio fx-300ES scientific calculator problem it wont let me square root 42 , when i square root 42 , 42 keeps coming and not the answer
To calculate a square root you press the square root key. A radical will be displayed. You type in the positive number whose root you want. Press the EXE key.
Sep 07, 2011 | Casio fx-300ES Calculator
I dont know how to find the square root on my casio fx-300ES. please show me how thanks.
You have a key for it. It is marked with the symbol of a radical. Press the key and type in a positive number thaen press the = sign key.
Sep 24, 2010 | Casio fx-300ES Calculator
How do i use the square root button on my fx-300 ES calculator
Press the square root key, type in a positive number and press [=] to get the result.
Aug 25, 2010 | Casio fx-300ES Calculator
How can I get the square root of a number that a simple calculator can get?
To calculate the square root.
Press the square root key, enter a positive number, close the right parenthesis (may be omitted) and press [=].
Mar 17, 2010 | Casio fx-300ES Calculator
How to use the exponent key on a casio fx 300ES calculator ?
The key to use for the square, and the cube are well marked and they share the same physical key (X to 2) or [SHIFT][X to 2]. Similarly the keys to use for the square root and the cube root share the same physical location (the square root key, to the right of the square key).
For any other exponent, including fractions and negative exponents you use the universal power key labeled [X to ] ( X with a raised square).
  1. You enter the base (the number to be raised to a power).
  2. You press the [X to ] power key.
  3. You close the parenthesis (the right one).
  4. You press [=]
Sometimes the result may not be displayed as a decimal number, but as a radical (if you take a root). To make sure it is displayed as a decimal number, in step 4 above, press [SHIFT][=]
Mar 13, 2010 | Casio FX-300W Plus Calculator
I want to find the square root of a number and the display to tell me as a decimal. For instance square root of 21
if it is a perfct square root then u will get a integer part.....if its not a perfect square root than obviously u will get decimal part........ u just check ur calculater in which mode it is......exit the radian and do it
Oct 15, 2009 | Casio FX-115ES Scientific Calculator
Square root on FX-83ES
make sure you havnt droppend your calculator as this can damage the chip, if so , re solder broken parts and it sshould work, this happened on mine and after i soldered it it is fixed.
online companies can fix it if you send it away
Jun 07, 2008 | Casio fx-300ES Calculator
Texas Instruments TI-30 XIIS Calculator Logo
271 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
