Question about GE JTP48 Electric Double Oven
On my JTP48-30 oven some of the touch control buttons don't always work. Is this a problem in the touch pads or the circuit board in back?
The main problem is when setting the lower oven it will take all the inputs untill you try to press start. At this point nothing happens even after pressing start repeatedly. Sometimes in works but the problem keeps getting worse. Sometimes some of the other buttons don't respond right away also.
  • 10 Answers
SOURCE: Double oven control keeps failing
This is a common problem, try http://www.fixya.com/howto/h155060-dreaded_f7_error
it worked for me.
Posted on Aug 20, 2008
Sea Breeze
  • 4654 Answers
SOURCE: GE Profile JT952 Touch Pad Button Issue
Try this link
Posted on Mar 28, 2009
darjr
  • 378 Answers
SOURCE: Start button not working.
probably your button is dirty had carbon inside. do you hear a click sound when press it? if so , the IC did not received the signal, it need to be check by a technician.
Posted on Jun 30, 2009
  • 523 Answers
SOURCE: Touch pad for the oven does not work
eith touch pad or control board un plug the touch pad if it returns the board is bad if it dont the touch pad is
Posted on May 27, 2010
SOURCE: When trying to start oven for baking. I set the
well, at least your door hinges are still working. Let me guess, this is less than 6 months old. Every review of these ovens shows the door function breaking. I wish I had better news...and good luck!
Posted on Jan 04, 2011
Erroe code f7
F7 means Stuck Button
- Function pad button stuck or
- Bad clock. Try to free stuck button or
- Replace Electronic Range Control (ERC).
Someone mention that intermittent F7 problems are usually caused by poor connections. So I pulled the ribbon connector off the control board and cleaned the copper connectors using a pink pencil eraser.
It's important that you don't skimp the disconnect test because there's a big difference in price between the ERC and touch pad. So, you want to be right on this one. Ok, after you do this test and determine which part you need to replace, come and get it here.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 09, 2011 | Ovens
Part of maytag oven touch pad not working
When certain buttons don't work on the touchpad sometimes it can be resolved by making sure that the ribbon cable of the touchpad fits tight into the control board,and also the end of that ribbon cable could be cleaned with a pencil eraser. If neither of those work the touchpad would need to be replaced.
GENE
Oct 10, 2011 | Ovens
Always show the words "
you could have a problem with the clock assy.and there's also a computer board in with the clock assy. or the touch pad.kill the power to the machine,take it apart and unplug the ribbon that's connected to the touch pad.turn the power back on and if the code comes back you need to replace the clock assy.if the code doesn't come back then you have to replace the touch pad.
May 19, 2011 | Magic Chef Ovens
May 27, 2010 | GE Profile JTP56 Electric Double Oven
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
FO error message. Oven light stuck on. No buttons work.
The F0 is a Function Key Stuck error - Replace touch pad or touch pad and control board if it is one assembly. Refer to F1 Test for more information.
How To Perform A F1 Touch Pad / ERC Test
This test is easy to perform and will help you determine whether the Electronic Range Control (ERC, control board) or touch pad is defective when the F1 code is displayed.
Note: With some models, the ERC and the touch pad are one single unit and therefore this test is not necessary. The entire assembly must be replaced.
Warning: If you have any doubts in your ability or safety of the repair, please contact a qualified appliance repair technician.
1. Disconnect the power to the range by either unplugging the power cord, or turning the power off at the circuit breaker. Always make sure the power as been disconnected properly before beginning this test.
2. Access the control panel.
3. Disconnect the touch pad ribbon from the ERC.
4. Reassemble the control panel. Make sure to check for any additional defects such as frayed or lose wires that could be causing the problem.
5. Turn the power back on.
6. Wait up to an hour for the F1 code to reappear. This could be accompanied by an alert such as a beeping sound.
7. If the F1 code reappears, replace the ERC. If it does not, replace the touch pad.
Nov 06, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
My DACOR + ECS 130 covection oven light relay keeps clicking.....
I have the same problem and sent an e-mail to DACOR. A James Carlos responded and advised that DACOR could not provide DYI info because of liability problems, pure BS in my opinion. I've had problems with a DACOR microwave (manuf. by Sharp), my DACOR wall oven Model ECS103 and my DACOR Raised Vent system and told Mr. Carlos so. I don't know how to fix the blinking oven light other than cutting power at the circuit breaker panel or removing the two light bulbs which other have advised but suspect a new front control panel is required. If you find a fix, please advise me at bsquared37@yahoo.com. I think DACOR products are overpriced and junk.
Thanks, Bill 12/10/2009
Aug 27, 2009 | Dacor ECS130 Epicure Electric Single Oven
Maytag wall oven Model # MEW6530DDS control panel failing
HI, unfortunately, it is not just dirt, this is a faulty touch pad that is combined with the control board. most touch pads are separate parts that are clipped in front of the circuit board but, in this case, the touch pad and control board are one piece. You will need to replace the entire control board in this case. the touch pad is faulty.
Jun 03, 2009 | Maytag 30" Built-In Single Electric Wall...
What does an F1 fault indicate
MAYTAG
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC) * Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
- Disconnect power to the range.
- Gain access to the back of the ERC (electronic range control, or "clock").
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
- Turn the power back on to the range.
- Watch for the F-1 and listen for the beep.
- If you get the F-1 and beep, replace the ERC.
- If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control.
Warning: If you do not feel comfortable doing this test or making this repair please contact a qualified appliance repair technician.
Jun 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Monogram wall oven F9 error
“F— AND A NUMBER • You have a function error code. Press the CLEAR/OFF pad. Allow the OR LETTER” FLASH oven to cool for one hour. Put the oven back into operation. IN THE LOWER OVEN • If the function code repeats, disconnect all power to the oven for at DISPLAY least 30 seconds and then reconnect power. If the function error code repeats, call for service Here is someone that had the exact same problem: intermittent F7 error code. I couldn't even get it to do the F7 error . There's a pretty good tech service sheet inside the control panel. I followed its procedure for testing the keypad (which was nothing more than pressing all the buttons and hearing it go "BEEP!" silly.gif). But the tech sheet did mention that intermittent F7 problems are usually caused by poor connections. So I pulled the ribbon connector off the control board and cleaned the copper connectors using a pink pencil eraser. That whupped that puppy! But then I went out on another service call, same oven, different house. The pink pencil eraser trick didn't work on this one so I had to apply some of that famous Samurai gray matter. To identify the problem on this one, I cut power to the range and disconnected the ribbon connector that connected the touch pad to the electronic range control (ERC) board. Then I re-applied power and let it sit that way for 24 hours after which the customer was instructed to call me and report on the error code status of the oven. If no error code was reported, I knew the touch pad was the problem. If, on the other hand, the F7 error code came back, then I knew the (ERC) was the culprit. In this case, the error code did not come back during the test period and, using my keen, Vulcan-like powers of deduction, concluded that the touch pad was defective. I replaced the touch pad and problem solved! It's important that you don't skimp the disconnect test because there's a big difference in price between the ERC and touch pad. So, you want to be right on this one. Ok, after you do this test and determine which part you need to replace, come and get it here. **** this helps. :]
Dec 14, 2007 | GE Monogram ZET3058SHSS Stainless Steel...
GE JTP48 Electric Double Oven Logo
55 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
