Question about Gateway NV5214u Notebook
Should my fan constantly run when my gateway ms2274 powers on
  • sgfd Oct 25, 2012
    Does it stay on really high all the time or does it just come on loud when you turn it on and go back to a normal level?
  • 2,878 Answers
The fan normally runs in sync with high CPU usage. So, I would say normal. Go ahead and blow out the system with canned air it has become noisier than usual.
Posted on Oct 25, 2012
2 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: ggateway ms2274 shutting down wont start up
onehugo, has the inside of the laptop been cleaned out?
The Gateway MS2274, is also known as part of the Gateway NV52 series of Notebook PC's.
Look on the bottom of the laptop, and post the Model Number.
(Examples, NV5207U, NV5211U, NV5212U, and so on)
http://support.gateway.com/us/en/s/notebook/2009/gateway/nv/nv52/NV52nv.shtml
(Clicking on Product Views, then on the different product views given, will show you the ms2274 is part of the NV52 series )
The laptop uses the same cooling system as most laptops.
1) Cooling Tube:
Slightly flattened copper tube, sealed on both ends, and filled with Nitrogen.
At one end of the Cooling Tube there are two small metal plates. One plate sits on top of the Processor. The other plate sits on top of the graphics chipset.
At the other end of the Cooling Tube a Heatsink is mounted.
2) Heatsink:
For this series it is a rectangular finned object. Small strip of metal with Tall, Thin fins protruding from it.
3) Fan Assembly:
Fan set inside a backwards D shaped shroud. (Surrounding cage)
The Fan Assembly draws air up from the bottom, then exhausts the heated air out of the side of the laptop.
Operation:
The two small metal plates absorb heat from the Processor, and graphics chipset.
The heat is then absorbed by the Cooling Tube.
The Cooling Tube transfers the heat along it, up to the Heatsink
The Heatsink absorbs the heat, then radiates it away with the Tall, Thin fins.
Air flow from the Fan Assembly, helps carry heat away from the fins of the Heatsink.
This is an up close example of the cooling system used, on the Gateway NV52 series of Notebook PC's,
http://www.laptopneeds.com/parts/show/120817549354/
Scroll the page down to the photos.
The bottom photo shows the cooling system, as it looks removed from the laptop, and the side that contacts the Processor, and graphics chipset.
Here I am able to show you the metal plate surface, that contacts the Processor, and graphics chipset.
With this design there is only one large metal plate to do both jobs, instead of two small separate metal plates.
Coming from the end of the copper Cooling Tube, and going to the Left;
1) You will see a small square, covered partway with a gray Thermal Paste.
(Thermal Paste makes a triangle shape)
This pad sits on top of the Processor/
2) Coming to the left a little further you will see a rectangular copper pad, with gray Thermal Paste smeared on it. This pad sits on top of the graphics chipset.
[ The Processor and graphics chipset, are the two hardware components inside a computer, that give off the most heat ]
Also here you will see at the side of the (Black) Fan Assemblies shroud, is the finned Heatsink.
Point of this long 'dissertation'?
Want you to see the cooling system, and especially the fins of the Heatsink.
Air is drawn up by that fan, and pushed through the fins of the Heatsink.
ANYTHING the fan draws up with the air, is pushed through the fins of the Heatsink
Dust, dirt, hair, food crumbs, lint, ...you name it, is drawn in.
This coats the fan blades, fan's center hub, and surrounding cage. (Shroud)
Also clogs the fins of the Heatsink.
This drops the cooling capacity of the cooling system, tremendously.
The Processor, and graphics chipset overheats.
When a Processor overheats it turns off. (BIOS turns it off)
No Processor operating, no computer.
After a few times of this error codes are logged in. BIOS won't turn the Processor on, until the problem is fixed, and error codes are cleared.
Solution is to clean the inside of the laptop out.
Laptop partially disassembled;
Use an ESD wrist strap, ($3 to $6), and connect it's alligator clip to a good ground source.
Use compressed air for computers, a soft small brush, (Makeup brush?). and Q-tips.
No sir/ma'am.
Using compressed air at the Fan Assemblies opening, at the bottom of the laptop, (Air Intake Duct) WILL NOT DO THE JOB CORRECTLY.
It will just shove the gunk further into the fins of the Heatsink.
Use compressed air at the side of the laptop, and the exhaust port?
Even WORSE!
Also;
You see I mentioned Thermal Paste.
The bottom of the two pads on the large metal plate, on the Cooling Tube, (Whew!), is not perfectly smooth.
Neither is the top of the Processor, and graphics chipset.
A magnified view would show imperfections.
'Pitholes, Valleys, and Hills'.
When the two surfaces are mated together, (Pads on top of Processor, and graphics chipset), they create Air Pockets.
Air is an Insulator. Not a Conductor.
Thermal paste fills these imperfections, and is an excellent Conductor of heat. Transfers the heat well.
After time the Thermal Paste dries up. Caused by age, and the heat of the Processor, and graphics chipset.
Fresh, new Thermal Paste should be used.
The top of the Processor, and graphics chipset, plus the bottom of those two pads on the metal plates, should be cleaned THOROUGHLY!
Then fresh, new thermal paste is PROPERLY applied.
Software problem? Windows is messing up?
NO
You stated the laptop is shutting off, BEFORE the operating system is started.
[ You press the Power On button. This is tun presses against a momentary contact switch. The Power On switch.
The first chipset to receive power is the BIOS chipset.
BIOS looks to see what devices are connected, does a Ram Memory count, turns the Processor on, then hands the computer over to the O/S.
The Processor isn't turning on, or isn't staying on ]
I can post links to the NV53 series of Notebook PC's, for a Service Manual, and pictorial guide, for disassembly.
With this info you can crossover easily to your NV52 series.
If you wish to clean out the inside of your laptop yourself.
There is ALSO other needed information I will state along with them.
Post back in a Comment.
Regards,
joecoolvette
(Apologizes for the long solution )
Posted on May 17, 2012
My Gateway ms2274 screen wont come on
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Aug 04, 2012 | Computers & Internet
Ggateway ms2274 shutting down wont start up
1) Cooling Tube:
2) Heatsink:
3) Fan Assembly:
Operation:
No sir/ma'am.
Even WORSE!
Also;
NO
Regards,
joecoolvette
May 17, 2012 | Gateway Computers & Internet
Cooling fan constantly runs
The fan is supposed to run all the time whenever power to the computer is on.
Feb 26, 2011 | Gateway GT5014 PC Desktop
My Gateway MS2274 won't turn on. What do I do?
I had the same problem on the same laptop. I took it to a local computer repair shop and it was a problem in the power switch/button. They ordered a replacement part and installed for like $40. Good luck!
Oct 05, 2010 | Gateway Computers & Internet
I am looking for a power cord for a gateway laptop ms2274 19 volt
If you have one in your area, go to Microcenter and get a Kensington K33404 universal power supply. they come with multiple tips for all laptop makers and also have variable power setting. I use one with my HP and my brother with his Toshiba. They are only $25 at Microcenter. Or go to www.microcenter.com and order one on-line.
Jun 11, 2010 | Computers & Internet
Trying to disassemble MS2274 Gateway laptop--
you need to replace the DC Jack it will involve soldering a new part. most time the whole laptop need to be taking a part to get the it, so unless you are ready for a big challenge take it a tech.
May 08, 2010 | Gateway Computers & Internet
My gateway laptop keeps shutting down. it is brand new
How long have you had it on. If you are not venting the heat out away from the processor, it will shut down to protect it. I suggest either take a small fan and blowing towards the computer. Or they make a chill pads for laptops about thrity dollars.
Oct 12, 2009 | Gateway (MS-6946) Modem
Gateway m685 freezes after it runs for awhile, then more quickly
It is probably being caused from over heating.
Are the cooling fans running? If so, get a can of air from an electronic store, and blow the cooling system out from the exhaust in to the fan. Stop the fan from turning with a paperclip or something.
Mar 20, 2009 | Gateway M685-E Notebook
High speed fan
the thermo switch determine how high and how long the fan need to run to obtain the proper temperature, it will be a consern if the fan doesn't run.
as far as the upgrade of your machine. do you have enough RAM (2GB minimum) and how is the CPU?(1.6GHz or better) can the CPU handle the operating system. Since you didn't mention that, and by reading what you say, I believe the machine is not able to handle the Vista, that is why the fan is running at high speed and non-stop. The CPU is getting hot, and the power supply is pulling lots power.
Vista loading takes approximately 1-2 minutes, dependent on how many applications you have installed and what you have on the desktop.
roll back to XP from Vista is no possible, the only way is to reformat and reinstall XP.
Dec 01, 2008 | Computers & Internet
High speed fan
Well it may just be a program has set it and hasn't set it back... You can use a program called SpeedFan to "Control" ya Fans here ----> www.almico.com/sfdownload.php
Aug 20, 2007 | Gateway 830GM (RB830GM) PC Desktop
Gateway NV5214u Notebook Logo
197 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
