Furnace will not turn on in Auto mode thermostat
My furnace will not turn on while the thermostat is in Auto fan mode. I replaced the sequencer in the furnace and still have the same problem. The furnace will operate properly while in ''ON'' mode.
  • 37 Answers
It sounds like you T-Stat is messed up. Look in your manual to see if there is set up instructions. If not I would change the T-Stat.
Posted on Jan 03, 2009
Amana Air Command 80 with fan mode is on, the furnace is running and blowing heat. Why the furnace did not do any thing when I set it on auto mode? Then I replaced a new thermostat, but nothing change
Try setting the temperature higher. It could be that the room temperature is not getting cold enough for the automatic controls to activate the heater.
Nov 02, 2014 | Heating & Cooling
My central electric furnace eb15b heats up up but the blowers not turning on?
Most likely it is the sequencer that is bad. Try turning the fan on with the thermostat. If it runs in "on" and not in "auto", most likely it is a bad sequencer.
Mar 14, 2014 | Heating & Cooling
Honeywell thermostat will not work when put on automatic
Depends on what type of heat you have...if it is electric, it could be your thermostat (some electric heaters use contactors & rely on the thermostat to switch the fan on). Heat pumps also use the thermostat to switch the fan on in heat & cool mode. Most electric furnaces use a sequencer to switch the low speed of the fan whenever there is a call for heat. Gas furnaces use either a fan/limit controller (if the unit is older) OR a circuit board based on time (after the thermostat calls for heat). SO depending on the type of system you have, it could be a bad sequencer, controller, relay, thermostat, or control board. Hope that helps.
Dec 17, 2013 | Heating & Cooling
My honeywell thermostat will not let the fan blow if it's on automatic
I have a coleman evcon electric furnace. The blower fan runs constantly, the switch is in auto and the fans runs even when the thermostat is shut off.
Most likely on that particular electric furnace you have a fan sequencer that is closed (stuck shut). It is the black relay that you are looking at when you take off the furnace cover to access your heat strips. You should have a red wire coming from the blower motor that plugs into the side of it. If you have a ohm meter turn power off and remove wire. Check resistance across the sequencer and it should read OL. If you have resistance across it, the relay is bad. Replace it.
Nov 28, 2013 | Heating & Cooling
The furnace send signal to the fan in about 30 seconds, now this fan is set in auto from my termostat, my problem is the fan is starting slowly and some time it don't start, but if I use the option manual...
Depending on the model of the furnace, the blower is either a 2 or 3 speed. When the furnace operates in heating mode with the thermostat in the auto position, the furnace starts the fan when the furnace reaches a specific temperature or after a set time delay, but it operates the fan in low or med low speed on heat mode, when you put the thermostat fan switch in the "ON" position, the furnace operates the fan in "HI" speed, the same speed used for cooling mode. You may have a blower moter that is starting to short. I would recommend having a professional replace the motor before now before it becomes an emergency in the middle of the night during a cold spell.
Oct 10, 2009 | Heating & Cooling
Sometimes the furnace doesn't come on when it should
OK so its an all electric furnace no gas? I cant think of anything clicking on an electric furnace except the sequencers or the safety switches.
If this is whats your hearing then the fan should definitely be running.
Feel carefully around the fan motor (I assume this is in a mobile home). See if you detect any heat coming around the blower area close to the fan motor. If so the fan motor may be at fault or one sequencer may be out (the main one of course...) the thing is can you get the fan to come on by turning the auto switch on the thermostat (or if older model the Auto On switch on the furnace) to ON? If so you can "limp by and have heat til someone either checks it or you can go on deeper into it. but to go deeper you'll have to let me know you know where the elements are and that you have a volt meter. and feel comfortable using it especially on HOT wires.
Mar 03, 2009 | Heating & Cooling
Bad sequencer or fan relay?
does ANYTHING come on when set to heat?
Feb 28, 2009 | Heating & Cooling
Auto fan does not turn my furnace fan on-I have to use manual on
with the fan in the auto position, the fan only comes on during a demand for heat.  does it not come on during a demand for heat?
Nov 24, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
206 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
