Question about Acer AL2216WBD LCD Monitor
I have 2 Acer AL2216W Monitors. The light is on but no display.
Both monitors have the same problem. when I disconect the monitors I dont see the test message. The light is blue but I dont get any image on the screen.
SOURCE: Acer Monitor Display of text and image is not sharp
This might seem obvious, but is your video card output set to the native resolution on the monitor? If not, it will look fuzzy. Try 1680x1050, if you don't know the monitors native resolution.
No need to use anything higher than a 60hz refresh rate either.
Posted on Apr 05, 2008
JULIANFIX
  • 975 Answers
SOURCE: AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
Posted on May 06, 2008
  • 10865 Answers
SOURCE: HOW CAN I TAKE OUT THE MONITOR BASE FROM THE MONITOR ACER
remove the hinge cover, then remove the six screws you see there. Then the base slides out.
Posted on Feb 10, 2009
skotkolr
  • 558 Answers
SOURCE: My monitor displays images in stetched full screen format
the description you gave was the long way right click on my computer, select properties then device manager, you will be in the same place but lots faster, plug and play does not identify the monitor or its compatible display resolutions, right click on the desktop select properties then display settings, go into advanced tab and look at the monitor, and the adapter, you can play with the setting until you find one that works, 1400 x 900 may not be supported by the video card(adapter) so that may be why your loosing the video settings.
hope this helps.
Posted on Apr 05, 2009
paulbtorrent
  • 34 Answers
SOURCE: ACER AL1914 LCD Monitor goes black but green light stays on
The monitor is doing a self test a finding an error.
The lcd has three parts, the screen plate(windows)/the logic(vga)/the inverter(power plug). Parts that go are the backlight ccfl's, behind the plate, and parts of the inverter, ie capacitors, all three take a bit of power from the inverter. The self test check that all the lights are ok and the inverter is ok, else it switchs off, ie if 3/4 light work it will switch off(my own case), hence the on chech error then off, However sometime there are stages of on/off ie on/ but no screen display, if that is the case the following may be of help...if you put bright light at an angle close to lcd can you see a windows shadow, text icons etc, ie still logic power passing,then .... (from a.n. other) after two weeks searching I finally find doctor living stone http://www.aplusperfect.com/articles/lcd_capacitor_repair more fun with paulbtorrent
the takening the case bit off is like opening your wallet a second time after buying a new LCD, but you must! smallest two screw driver's flat headed, practice using two pennies stuck together()with your fingers after, one little () move and inch and {} again, with the case , it does not break, just need to lever open
[once open you realize they somehow put that old briefcase clip inside!] also note the bright light test to do first to see if can see a windows screen , and that capacitors are one for a number of things that a make a inverter work! there a transistors as well, given that however, to replace all the capacitors on my inverter, was 11 capacitors, cost me $11 (uk ebay) and already had the iron and solder. So only cost me me $11 to try and see but no luck , still fun and I still can see the screen for 2 sec' at a time plus I have a spare set of caps now in the event that the new one do go burst! you have to laugh really, what next , a new on/off button, as you work though the whole inverter mmmMMMMmmmMMMMmmmMMMMTim Berners-leeMMMMMmmmmMMMMMmmmmcome back all is not wellMMMMMMMMMMnnnnnnweek later land sight mmmmmMMMMMMMMMmmmmgggggggg(from
another a.n other)Generally, if the screen went out quickly, it was the inverter. If it went out over a slow period of time (flickering etc..) I would bet it is the lamp.replaceing the lamp should be pretty challenging. as that requires complete breakdown of your LCD, extraction of your dead lamp, and soldering in your new lamp... but I would like to say that I it did this after realizing it's 2 x kitchen strips inside [========] with wires that can connect back to the inverter with out any desoldering(ie kit assembly/dis) with the outter case remove (glass plate safe away) I could reconnect and see that 3/4 were working (i!i hardcard ) cause the inverter to switch off after a secound ! order bult and replace and going
to cheap and see if I can get away with fitting a 15" in my 19' as it a 1/3 of the price ! the market as drop out there, hope the inverter does not miss the length, or the screen out put.http://www.lcdparts.net/howto/troubleshooting/LaptopCCFL1.aspx OR MONITOR
Posted on Feb 08, 2010
I have an Acer Monitor AL2216W and it will come on, the Acer name appears, then no signal and then the green light goes to orange. Is this the power supply or what?
It will go into sleep mode if it does not detect the signal from the PC. Try is with other PC first, also make sure the cable is seated properly.Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Here is the inside of your monitor:
http://s807.photobucket.com/albums/yy352/budm/ACER/Acer%20AL2216W/
Dec 22, 2011 | Acer AL2216W LCD Monitor
I have acer lcd al2216w on the lcd there is a green line comes between my screen it cant be remove i dont not how he comes please tel me what i do change a new lcd or what it can repairable or not
Hi there reinstall the display driver & then give a look. If you face same problem then its may problem with your display driver or in the monitor.
Jan 18, 2011 | Acer AL2216W LCD Monitor
Monitor turns on flickers twice then stays at a black screen
Test that your memory chips are fully inseted in their sockets as this can some times prevent displays from working.
Sep 07, 2010 | Acer AL2216W LCD Monitor
Acer al2216w problem
wronge connection check it
May 01, 2010 | Acer AL2216W LCD Monitor
I have a acer AL2216w. it randomly shuts itself off
Replace the following capacitors:
3 pcs. - 220 microFarad - 25v
2 pcs. - 1000 microFarad - 25v
1 pc. - 2200 microFarad - 25v
Resolder the 2 inverter transformer's legs.
Roan
Triangle Tech Whiz
Jun 11, 2009 | Acer AL2216W LCD Monitor
Same problem, acer sucks imo
I think I may have fixed it but I haven't rebooted my computer yet. I uninstalled the latest ATI driver version 9.3 and then installed an older driver version 7.3. Monitor now turns on and off and gets signal every time so far. I'll post back if it the problem comes back after I reboot.
Apr 08, 2009 | Acer AL1916W 19" LCD Monitor
Native resolution suddenly scrolls.
The native resolution for the Acer AL2216W is 1600X1200. It is acting correctly for the resolution you have set it to.
Apr 05, 2009 | Acer AL2216W LCD Monitor
Monitor works during boot-up but not in Windows
Did you install the ATI catalyst software?  You will have to check a box that says active monitor on your graphics console for the appropriate monitors.
srich
May 27, 2008 | Acer AL2216W LCD Monitor
May 06, 2008 | Acer AL2216W LCD Monitor
Acer AL2216WBD LCD Monitor Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
