Question about Sharp AL-1551CS Copier
Reset drum AL1551cs sharp copier - Sharp AL-1551CS Copier
  • 67 Answers
SOURCE: Need reset code for Sharp AL1631 copier drum
USING ONE FINGER PRESS CLEAR, AUTO(EXPOSURE SETTING), CLEAR & AUTO YOUR DISPLAY WILL GO BLANK, IF IT DOESN'T GO BLANK TRY IT AGAINSOME MACHINES ARE TEMPERMENTALWHEN YOU GET IT GO BLANK PUNCH IN 24 THEN PRESS THE START KEY THEN PUNCH IN 07 AND THEN PRESS THE START KEY AGAIN. THAT WILL RESET THE DRUM COUNT. TO GET OUT OF THAT MODE PRESS CLEAR A COUPLE TIMES OR TURN IT OFF & BACK ON
Posted on Apr 10, 2009
  • 413 Answers
SOURCE: Printing blank pages on my Sharp AL-1631 copier
Is there any tone in the printer?
Posted on Apr 24, 2009
Sharp Tech
  • 63 Answers
SOURCE: how can i reset the drum on al 800 sharpgrayscale
You should have on the right side of the display panel a "C" key and on the far left side your "light" exposure key.
Press c-exposure-c-exposure the scree should go blank. using your key pad make the display show 24 then press your copy key. then make it show 7 the press your copy key. Press the C or CA key until the copier resets. The light should have gone off.
Posted on Oct 15, 2009
Sharp Tech
  • 63 Answers
SOURCE: Fixya: Sharp AL-1631 copier doesn't recognize new drum?
press the following keys in this order:
  1. Clear Key (far right key on panel)
  2. Exposure Key (far left key on panel)
  3. Clear Key (far right key on panel)
  4. Exposure Key (far left key on panel)
once the panel goes blank make your display show
  • 24 then press your start key
  • then 7 press start
  • press C one time
  • 20 press start
  • 1 press start
Then press C until the copier restarts.
Posted on Oct 16, 2009
Testimonial: "Wow! A solution to my problem with a copier was posted within a couple of hours, and the procedure worked perfectly! Thanks. OB "
wheatlandsvc
  • 1110 Answers
SOURCE: sharp al-1631 copier. drum error code
You can reset this indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
Posted on Nov 16, 2009
Testimonial: "Ok sorry thank u. I am new sorry i will be better in the future."
Office Equipment Copier Sharp AR-153E need to
Have you done simulation 24-7 to reset the drum? Do SIM 24-7 and the unit will start to copy
Mar 26, 2010 | Sharp Office Equipment & Supplies
Tip
Sharp AL Series Copier L1 L-1 Error Code Cause and Solution
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
This works in the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Mar 20, 2010 | Office Equipment & Supplies
Tip
Sharp AL Series Copier H3 H-3 code reset procedure
To reset the H3 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This works on the following models:
SHARP AL-2040CS Drum reset code
c - auto - c - auto - (machine is off) 24 - start - 07 - start (000 blink) - 4x botton c . Finish ok.
Apr 28, 2009 | Sharp AL 1631 Copier
Tip
Sharp AL Series Copier L3 L 3 code meaning and solution
Good Luck and thank you for using Fixya
on Mar 16, 2010 | Office Equipment & Supplies
Tip
Sharp AL Series Copier H4 H-4 service code reset
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
on Jan 04, 2010 | Office Equipment & Supplies
Drum cartridge - generic
Sharpe are correct there is no known button sequence I know about as the drum normally has a resistor that blows when installed resetting the drum count.
Thanks J
Dec 26, 2007 | Sharp AL-1661CS All-In-One Laser Printer
Tip
Sharp AL Series Copier Drum Light Cartridge Counter Reset
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
24 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
