Question about NetGear WNR1000 Router
How do you find the internal ip for a router?
  • 2,878 Answers
Connect the router and go to Start > Search (run in XP) and type cmd ENTER. In the command prompt type ipconfig /all ENTER.
For your true IP from your ISP disconnect the router, and do the same.
Posted on Oct 25, 2012
Hello, i setup a IP cam. Create an account on dyndns.org for the IP. But now when i type the given url i am linked to the setup of my Thomson router TG585 v8 What can I do? There is nothing else except...
Hi Sten -- There are several non-intuitive things you have to setup with any router and Dyndns to make this work.
On Dyndns you can setup your static or hardly every changing dynamic Internet (external - provided by your ISP) IP address in your Dyndns account settings (Not the internal NAT IP - 192.168.x.x address of the cam). if it changes more often you need a dyndns client.
On the router you have to setup port forwarding to the internal (NAT address ex:192.168.x.x) address of the camera including the port number -- or you could just create a DMZ (feature of many but not all routers) for the internal IP of the cam.
If you've done the above correctly you might want to check the troubleshooting sections at Dyndns.org located HERE and HERE.
Happy Networking and Thanks for using Fix Ya.
Mikeywaf
Apr 15, 2011 | Computers & Internet
Tip
How to find your Router's IP address
The easiest way to know your Routers Internal IP address is by using a little command line tool called ipconfig. This command line is built in with Windows Operating System and is being used for various networking solutions. To use this, you need to click Start and find the run command. Click the Run command and you should see a little run dialog box after.
In the run dialog box, type in cmd and either press ENTER or click the Ok button. You should see a black window with white text and this is referred to as the command prompt.
At the command prompt type in ipconfig and press enter. That should display three major information. The IP Address, Subnet Mask and Default Gateway. The IP address in line with Default Gateway is your router's Internal IP address.
Each Router has Internal and External IP address. The internal IP address is what you use to talk to your router. Use this IP address to login to your router setup page and configure it for things like port forwarding. External IP address is what the rest of the world uses to find you on the Internet.
Hope this helps.
on Apr 20, 2011 | Computers & Internet
What IP address should I use for my internal network? Some routers have it as 192.168.0.x and some have 192.168.1.x. I don't know what the difference is. Thanks!
There's really no difference at all. The internal IP scheme is totally arbitrary. You can even have it 10.1.1.x if you feel like it. The internal IPs get translated when communicating with the outside (the Web) and this is done by the router so all you need to pay attention is that the internal IP scheme is consistent on all PCs.
Please vote with a Thumb up if this was helpful. Thanks.
Feb 09, 2011 | Linksys Wireless-G WRT54G Router
Port forwarding for model number F7D5301
To setup port forwarding on this router your computer needs to have a static ip address. Or you can take alook at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below. Open a web browser like Internet Explorer or Firefox. Enter the internal IP address of your router in the address bar of your browser. If you do not know your routers internal IP address please read our How To Find Your Routers IP Address guide.
The address bar has http://www.fixya.com/AnswerQuestions.aspx#top in it. Just replace all of that with the internal IP address of your router. By default the IP address should be set to 10.1.1.1.
We do not currently know the default username and password for your router.
Click the NAT button near the left of the page.
You should now see a new menu. In this new menu, click Port Forwarding.
Enter the name of the program into the Description box. It doesn't really matter what you put into this box, but something that will remind you why these ports are being forwarded would be a good idea.
Enter the port to forward into the Public Port and the LAN Port boxes.
Use the Protocol Type drop down box to select the protocol type of the ports you are forwarding.
Enter the ip address to forward these ports to into the LAN IP Address box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box.
Put a checkmark in the Enable checkbox.
When you're finished, click Save Setting near the top of the screen to save your changes.
And that's it! You're done!
Feb 05, 2011 | Belkin Basic Wireless Router
How can i find my wep key code for my router
Follow Step # 1 in this guide here. Look for Security settings somewhere in the router menu and you should be able to find the WEP key under there.
Without information on your model of router, we can't be more specific.
If you are still having problems, follow Step # 10, or even 10.5!
Jan 18, 2011 | Computers & Internet
My computer beyond ISA server and also have note book, when cable wire not attach with router then my wire note book connect easily, when i put my cable connection in router, wireless indication light stop...
First of all, routers come with static ips... (the default is usually 192.168.1.1). So I am going to assume you mean your internet ip is a dynamic ip. Now Im not an ISA expert, so I may be wrong... but ISA should work with a dynamic external IP. And lastly if you cant get it to work, a quick call to your ISP will get you a static IP.
or
Try to configure the IP address of the external NIC in the same network as your router with the default gateway pointing to your router´s IP address.
In the internal NIC, configure the IP address of the internal network in the same subnet as your internal clients, set no default gateway and set an internal DNS.
In the internal network definition, you should put only the networks behind ISA trust interface.
Create access rules according to your needs.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | D-Link DIR-300 Wireless Router
I cannot access my modem. When I type in the IP address 192.168.100.1 it says windows cannot find the address, even though I have an ethernet connection
Linksys routers, for example, use 192.168.1.1 for their internal IP address. D-Link and Netgear routers typically use 192.168.0.1. Some US Robotics routers use 192.168.123.254, and some SMC routers use 192.168.2.1. No matter the brand of router, its default internal IP address should be provided in documentation.
Jun 15, 2010 | Arris SURFboard SBG900 (49402201900) Modem
Netopia NAT
I know that most Netopia's I've worked with have been able to port forward single or ranges of ports to numerous internals from numerous externals.
Address Translation needs to be on.
IP Passthrough has to be off.
Then in NAT Easy Servers, setup port forwards and specify the external IP, internal IP, and ports (can forward all).
Dec 21, 2009 | Netopia ADSL2+ 11G WIIRELESS ROUTER 400MW...
How to set up for internet use with muliple pc's
I assume you router came with a configuration manual or CD. Its very easy. Once by following the instructions, go into the router like:
http://192.168.x.x (whatever IP is suggested by the manufacturer) and make sure the internet connection type. Mostly the ISP's use 'Dynamic IP' (if you scroll other ones will be like PPPoE, PPTP etc). Select Dynamic IP and restart your router and you will see after few seconds that your router has started to offer IP's to the internal Lan Pool. connect your ethernet cables from the computers to the router (behind the router you will find the ports to connect them)
In your Network settings in the router assign an internal IP to the router like '192.168.x.x' subnet mask 255.255.255.0, enable DHCP server and assign the internal LAN ip pool like 192.168.x.20 to 192.168.x.100 and you are all set.
Very important:
Security settings Always make sure your router (if in case its wireless router as well) assign and use an authentic security feature like 'WPA, PSK or WPA2, PSK' you could also use WEP (but WEP its getting old) I recommend WPA higly for wireless clients. If you have NONE wireless connections to offer than do not worry about it.
OR
simply put the CD inside your system connect it with router and it will guide you through for configuring it.
I hope it helped
Dec 16, 2007 | Linksys EtherFast Cable/DSL Router
What is the difference between the internal IP and the real IP from my ISP?
Internal IPs are sometimes referred to as virtual IPs. They are a group of up to 255 IPs that are used and recognized internally on the local area network. They are not intended to be recognized on the Internet. The real IP from ISP, instead, can be recognized or pinged by another real IP. The Prestige 310 Internet Access Sharing Router works like an intelligent router that routes between the virtual IP and the real IP.
Feb 19, 2006 | Zyxel Prestige 310 (AM406100) Router
NetGear WNR1000 Router Logo
32 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
