Question about Dell Latitude E6520 Notebook
Loose hinges loose hinge
5 Suggested Answers
SOURCE: loose hinges
Posted on Jun 03, 2008
SOURCE: THE LID IS LOOSE AND THERE ARE NO SCREWS TO TIGHTEN ON THE HINGES
You do not need to replace the hinges, however your need to remove the font panels of the screen and laptop to remove the hinges. You will see that the pin that connects the top part of the hinge to the bottom part of the hinges has over time moved out of alignment. With pliers and a hammer manipulate the hinge pin so that it is now flush with the hinge itself. You will see that the hinge will then become tight. Then just reinstall the hinge. I just did this and I know it works.
Posted on Nov 07, 2009
technolust
  • 340 Answers
SOURCE: loose hinges on dell insperon 1318
Hi There,
Loose hinges ultimately need replacing, as tightening them is impossible. To get to the hinges in order to replace them, You'll need to remove the screen. This is a fairly daunting task for anyone without previous laptop repair experience, and can get frustrating pretty quickly. Your local repair shop should be able to do this for under $50.
Here is a link to a repair guide if you do decide to take it on yourself -
http://support.dell.com/support/edocs/systems/ins1318/en/sm/display.htm#wp1109848
Posted on Jun 06, 2012
Miele classic h 383 b-cat Oven door will not seal properly. Checked seals and cleaned around hinges. No obvious signs Help Thank you
SPRAY HINGE WITH WD-40 AND SEE F THERE ARE ANY SCREWS OR BOLTS AT HINGE THAT ARE LOOSE OR THE HINGE IS BAD,GRAB IT BY THE HINGE AND SHAKE TO SEE IF IT IS LOOSE.THE HINGE PART THAT GOES INTO OVEN THAT YOU CAN NOT SEE COULD BE LOOSE OR ENLARGED TO MAKE IT NOT LINE UP.
Nov 17, 2012 | Ovens
How to tighten loose display hinges on toshiba pro a10
There ares no adjustments to tighten the hinges, they need to be replaced.
Replacing a hinge, or both of them, isn't very tough. Check out this WEB site.
http://www.insidemylaptop.com/replace-br...
Jul 20, 2012 | Toshiba Satellite Computers & Internet
Loose display hinges
There is no adjustments to tighten the hinges, they need to be replaced.
Jul 20, 2012 | Toshiba Satellite Pro A10 Notebook
Loose hing on Gateway c140xl
Faulty hinges cannot be adjusted or tightened. If the the mounting screws are loose then these can be tightened.
These WEB site hace detailed instructions on replacing faulty hinges.
Hinges for Gateway laptops on the 'net,
http://www.laptoprepairco.com/Search/hinges/hinges.asp
http://www.insidemylaptop.com/replace-br...Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Feb 16, 2012 | Gateway Computers & Internet
Loose case round himges
The screws that secure the hinges to the body of the laptop may be loose. In this case tighten the screws.
If the hinges are faulty, they are not adjustable and they need to be replaced.
These WEB site can assist you to replace the hinges.
Feb 15, 2012 | Computers & Internet
Case loose round hinges
If the screws securing the hinges to the base of the laptop is loose then tighten these screws.
Hinges have no tightening adjustments and loose/faulty hinges need to be replaced.
These WEB sites can assist you to replace these hinges.
Feb 15, 2012 | Packard Bell Computers & Internet
Fixint the swivel hinge
The following website should help you out - if the problem is just a loose hinge.  Maybe you've already seen this webpage, but here it is again anyway.
http://www.insidemylaptop.com/tighten-loose-display-hinges-toshiba-tecra-m4-satellite-r15-tablet-pc/
Your problem may be just a couplI used the directions to take off my screen and then found out my hinge was broken.
Good Luck
Apr 30, 2009 | Toshiba Satellite R15-S822 Tablet PC
Hinge on binoculars is too loose
there is a hinge nut at the bottom of the hinge..sometimes you have to turn of the cover or peel back the rubber to get at it
Feb 19, 2009 | Nikon Sporter I Binoculars
Terca M1 Loose Display Hinge
The hinge can't be repaired, but it can be replaced. It's feasible to do it yourself if you're tech savy. Just look online for guides that show you how to replace the hinge on any laptop and you should get an idea how to do the replacement step by step for this specific model. Most hinge mechanisms use the same system. I work for Computer Repair NYC and i have to fix this problem a lot, you can get the hinge on ebay.
Mar 03, 2008 | Toshiba Tecra M1 PC Laptops
Dell Latitude E6520 Notebook Logo
501 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
