Heating I have a 7600a presidential 11 coleman furnace it heats fine but the fan goes on and off . The furnace will come on and burn but the fan will come on and then go off and wait a few minutes and come back on again.
  • 61 Answers
If this is an older furnace, it is probably a wearing fan control.
Some can be adjusted, otherwise they need to be replaced.
Posted on Jan 04, 2009
Coleman presidential furnace
bad fan control switch or bad fan motor
Nov 28, 2017 | Coleman Heating & Cooling
Do I need a outside cooling unit for a Coleman 7900 Presidential lll gas heat and cooling unit
Yeah, youd have to look at the model on the Indoor coil box, furnace will be setting on top of it. Youll need the model off that coil box to get the correct tonnage of the outdoor condensing unit, you can go 1/2 ton smaller on outdoor for greater efficiency.
Feb 12, 2015 | Coleman Heating & Cooling
I need the wiring diagram for a colemen presidential. 7700 heating only furnace model 7700B series 856
Try this link:
Nov 10, 2014 | Heating & Cooling
Coleman Presidential Furnace 6806A842 heat switch pops then cool air
Make sure all vents are open and filters are clean. Likely an air flow issue but possibly, though unlikely, both switches are bad.
Jun 05, 2017 | Heating & Cooling
Coleman evcon furnace
Sounds like it isn't getting a call for heat. If you have a digital thermostat it could be the problem. I have seen them look like they are working but burn out. A simple way to check is take the stat off the wall. There is 2 wires. It's low voltage so don't worry about shock. Touch and hold them together. If it fires up change the t stat. On a . 2 wire it makes no difference which goes to W or R
Oct 16, 2013 | Heating & Cooling
Heating sequence failure.
check for flashing trouble codes on mother board
Oct 27, 2017 | Heating & Cooling
Coleman Presidential II Model 7656A Mobilehome Furnace blower p
have you changed t-stat? if so you need to increase the heat anticipator. if you have a fan limit switch, the setting may need adjusting. Thay will change with age
Nov 01, 2009 | Heating & Cooling
I have a Coleman/Evcon Presidential ser# 074878. The plumber says the Heat exchanger is cracked. Is this something I can fix myself or is it less expenxive to buy a new furnace?
The heat exchanger is a bear to change. depending on the age of the unit it might be more practical to replace the unit. However unless you trust this service tech I'd get a second opinion, because it is rare that a heat exchanger will crack, plus by law he or she should have shut the furnace down do to carbonminoxde. Especially rare in Coleman Evcon series units.
Oct 21, 2008 | Heating & Cooling
Heating & Cooling Logo
282 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
