Question about Aiwa HS-TX426 Personal Cassette Player
I have a Aiwa Model #CSD-FD79U AND THE CASSETTE DOOR WILL NOT OPEN
I THINK THE TAPE IS BROKEN AND CAN'T GET THE DOOR TO OPEN.How can I get the tape out . THANK'S
Kimi
  • 277 Answers
SOURCE: cassette door stuck closed
Firstly: do not think about forcing the cassette door! Look inside the unit. You need to hand rotate the capstan flywheel a bit,( a large-ish metal disc attached to the motor via a rubber drive belt.)That should release the powered deck mechanism and allow ejection. Then buy a new drive belt , so that problem does not recurr. Good Luck
Posted on Nov 03, 2005
  • 120 Answers
SOURCE: AIWA VCR model HV-MX1problem
with the unit unplugged take the case off and look on both sides of where the front of the tape would set, you will see two towers, one is a light and the other a receiver,check to see they are plugged in and not obstructed.Also there is a switch that the tape pushes when its all the way in which might be stuck,click it a couple times with your finger.This might help, there are other more complicated things which could cause this problem but mechanical problems are more likely.
Posted on Jan 15, 2009
  • 63 Answers
SOURCE: Have Aiwa NSX-V9090 Stereo with jammed cassette. I
Check with a small torch, to ensure that there is no tape broken arround the pinch roller or head, if there was no tape broken away, between the pinch roller and the cassette head there is a white cassette bar, this may have become bent.
Posted on Aug 19, 2009
mark24354
  • 776 Answers
SOURCE: NEED TO REPLACE POWER CORD FOR AN AIWA CSD-ED87 BUT CAN'T FIND IT
Try a local Goodwill store or any second-hand store. Seems they are popping up everywhere these days.
These stores have plenty of electronics and power cords and transformers. If you have a simple power cord like most boom boxes (no transformer) they are easy to find at these stores.
Otherwise, go to www.alliedelec.com
you will pay about 15 with shipping.
Posted on Nov 18, 2009
SOURCE: I have an AIWA CD3
where can i buy an aiwa cd 3 deck?
Posted on Jan 06, 2011
I have an Aiwa Surround Sound Theatre system Model #cx-nmt720. Has a 3 disc player, am/fm, and 2 cassette decks (one on right allows recording/dubbing) Everything works great except cassette...
The unit may be damaged or may just need adjustment- only a tape deck technician will be able to answer the question after seeing the unit. To answer it remotely like this, is really an impossible task.
Nov 03, 2012 | Audio Players & Recorders
How do i present radio stations on aiwa csd-td69
retrevo.com type in model# on search field........can view as pdf in adobe reader....good success......meder's tv service
Oct 25, 2012 | Aiwa CSD-TD69 Cassette/CD Boombox
My power cord is lost to my aiwa csd-td49 boombox. where can i get a replacement and how much would it run me?
There's probably nothing special about the original power cord, so I'd go to Radio Shack or any common electrical supply store and get it for around $8
http://www.radioshack.com/product/index.jsp?productId=3875429
Or you may have an unused one from other device lying around the house.
Jul 18, 2011 | Aiwa CSD-TD49 Cassette/CD Boombox
Aiwa AD-F810 when a tape is place and I try to close the door it won't but it will close and open with out any tape ? the deck is mint
i had the same type deck years ago, some decks have a two part door, make sure the outer door is clipped on to the inner mechanism correctly, may just have to be popped off. then re pop back on to inner door. jim d
Apr 26, 2011 | Samson Audio Players & Recorders
Have Aiwa NSX-V9090 Stereo with jammed cassette. I removed the cassette; however the system still thinks it's in there? When I power up the system it tries to play the tape the stops. I am not able to load...
Aug 08, 2009 | Aiwa HS-TX426 Personal Cassette Player
Tape players do not operate
Sounds like the belt is slipping or broken. You should first listen with your ear near the cassette door to see if the motor trys to work. Many units use the main belt to work the lift mech. for the heads, If that doesnt have enough grip the motor will spin(Which you can hear lightly) and the unit does nothing.
Jul 20, 2009 | Aiwa NSX-A777 Shelf System
Aiwa NSX-V70 Cassette Deck Belt Replacement
Mark
try www.partstore.com I think you can get what you need there!
Please rate my response!Thanks!
Jan 15, 2009 | Audio Players & Recorders
Problem with AIWA TP-M130 micro cassette recorder can't get tape out
Following 2 pics of exploded view will help you to solve problem with Aiwa tape.
Need further help. let me know.
Oct 22, 2008 | Audio Players & Recorders
Cassette door stuck closed
Nov 02, 2005 | Aiwa NSX-A115 Shelf System
Aiwa HS-TX426 Personal Cassette Player Logo
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
