Question about Canon GP-200 All-In-One Printer
Canon Gp200 Error Code E000-001
Replaced Fixing unit and reset code, it didn't fix the problem. I then installed a DC Controller and Fixing Heater Driver pcb and reset code. Still not fixed ... Installed a Composite Power Supply ... Still not fixed. Any suggestions?
  • xvmrc Jan 02, 2009
    I replaced the fuser unit with a new one. (Actually tried 2 New Fusers) The parts in my original thread were all replaced and new.
    Scholar:
  • 81 Answers
I looked up the e000 and it said it's for the fuser using not heating up and 001 error code and it is that the fuser unit is overheating. So seem to me you have a bad fuser unit.
Posted on Jan 02, 2009
  • odiegh
    odiegh Jan 02, 2009
    last thing I can think of is the sensor connecting the fuser or the printers control board itself has gone bad.
Canon ir2520 showing error code 808. What is the solution?
Code
E808-0000
Description
Fixing drive circuit failure
- The heater does not turn on. - A fixing drive motor failure was detected.
Remedy
- Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the fixing drive motor. - Replace the DC controller PCB. - Replace the power supply PCB.
Jul 05, 2016 | Canon Office Equipment & Supplies
How do i solve an error e000-0000 canon ir 2002n please
Description
The main thermistor reading does not reach 40C 14 sec after the fixing heater goes ON (fixing low temperature error)
Remedy
1) Wiring Is the connection of the connector (CN8) on the power supply PCB and the connector (J103) on the DC controller PCB and the wiring to the fixing assembly normal? NO : Correct the connection and wiring. 2) Fixing assembly Try replacing the fixing assembly. Is the fault corrected? YES : End. 3) Power supply PCB, DC controller PCB Try repacking the power supply PCB. Is the fault corrected? YES : End. NO : Replace the DC controller PCB. 4) Error With the power switch ON, clear E000 through E004; then, turn off and then on the power switch.
Aug 05, 2015 | Canon Office Equipment & Supplies
IR2318L CANON COPIER IS SHOWING CODE E000003-0000 AND HAS STOPPED COPYING,WHAT COULD BE THE PROBLEM?
Heater temperature error (abnormal drop; low-temperature detection)
The main thermistor reading is lower than 140°C when paper is moved.
Main cause:
The fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact
or has an open circuit; or, the fixing heater is faulty). The main power
supply PCB is faulty. The DC controller PCB is faulty.
Caution:
To clear the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action:
1. State
Turn on the power switch, and clear E002/E003. Thereafter, turn off and
then on the power switch. Does the fixing heater operate?
NO: See "The fixing heater fails to operate."
2. Wiring
Is the wiring from the DC controller PCB to the fixing film unit normal?
NO: Correct the wiring.
3. Fixing film unit, DC controller PCB
Try replacing the fixing film unit. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Feb 02, 2011 | Canon imageRUNNER 2200
I HAVE A CANON IR 3300 MACHINE I HAVE ERROR E00000-000
WHAT: Either the main thermistor doesn't attain 30?C 1 second after the power switch is activated or it doesn't attain 70?C 2 seconds thereafter.
WHY: It has a faulty fixing film unit, lack of connectivity with the main thermistor, lack of connectivity with the fixing heater, a faulty main power supply PCB, or the DC controller PCB is faulty.
NOTE: You can reset the error by performing the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
CONNECTOR FIX: Make sure that the connector of the fixing assembly is seated.
A. main power supply PCB (J8) relay connector heater
B. DC controller PCB (J320) relay connector thermistor
FIXING FILM UNIT (THERMISTOR) FIX: With a multimeter, check the interval between pin 1 & pin 2 & between pin 3 & pin 4 of the connector (4-pin) of the thermistor for electrical continuity. A result of ?? means that the circuit is open (lack of connectivity). Resolve this by replacing the fixing film unit.
MAIN POWER SUPPLY PCB, DC CONTROLLER PCB FIX: Press the Start key. If the drive voltage of the heater is supplied by the connector J8 of the main power supply PCB, then the main power supply PCB should be replaced. If not, then the thermistor control mechanism is faulty & the DC controller PCB should be replaced. Use the following to ascertain this:
Main heater: between J8-1 (FSR1) & J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) & J8-5 (FSR COM)
Sep 25, 2010 | Office Equipment & Supplies
It is displaying E007, i checked evey thing is ok, please help me and direct me which batton can i press to remove it
The error code E-007 is a fixing film sensor fault, check for paper wrapped around the fixing film, foreign material blocking the film sensor, damage to the fixing film, fixing film sensor failure, or DC controller PCB failure.
Jun 22, 2010 | Canon iR 2016i Black and White Copier
Error 001, error 808
the e001 code is something is going with the fixing assembly. one of the thermistors could be going bad.
E808 is a Zero Cross error. We most commonly see power supplies or bad wall voltage cause this code.
The following information is coppied from the IR2016 Service Manual.
E808-0000 DRIVE CIRCUIT FAILURE
A zero crossing signal cannot be detected.
A fixing drive motor failure has been detected.
E808 0000 Fixing drive circuit failure
  • The heater does not turn on.
  • A fixing drive motor failure was detected.
  • Check the connector of the fixing film unit.
  • Replace the fixing film unit.
  • Replace the fixing drive motor.
  • Replace the DC controller PCB.
  • Replace the power supply PCB.
M201 - Fixing Drive Motor - FK2-1067 - J202 on the DC controller PCB - E007, E808
Power Supply - FK2-1074
Jun 14, 2010 | Canon iR 2016i Black and White Copier
I have error code e000003-0000. How do I get it working again
This is a Heater temperature error, caused by an abnormal drop, or low temperature detection.
It is most likely a blown heater element.
Main cause can be the fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact or has an open circuit; or, the fixing heater is faulty). or,
The main power supply PCB is faulty. or,
Caution: The following steps should only be carried out by qualified people...
CAUTION
Do not clear the error until the fault is repaired. If you clear the error, and there is still an electrical fault it may result in a fire!
Turn on the power switch, and clear E003. (Service mode) Thereafter, turn off and then on the power switch. Does the fixing heater operate?
No? Try checking...
2. Wiring
YES: End.
Good luck
Apr 29, 2010 | Canon imageRUNNER 2200
Error E000 on Canon NP 6317.
IX. SELF DIAGNOSIS The DC controller PCB has a microprocessor that diagnoses the functions of the copier (particularly the sensors) at appropriate intervals. If this microprocessor detects an abnormality, it will display the type of the abnormality on the indicator on the control panel. The table below shows the various fault codes, their meaning, and the corresponding detection timing. Example of E000 code indication: Eó000 light alternately. Fault criteria • If the temperature difference between the thermistors 1 and 2 is 60°C or higher. • If the fixing asssembly temperature is lower than 50°C after 15 sec from the power-on. If the tempereture remains 220°C or higher for 0.1 sec or longer. If warm-up is not over after 60 sec from when the temperature reached 50°C. If fixing unit temperature drops below 50°C when the copier is in stand by or copying. If the C HEAT CHECK signal is on while the HEAT ON signal is off. If the main motor speed feedback signal does not appear after 2 sec from the main motor. If the break signals is generated continuously for 0.1 sec or more when the counter is not being driven. Code displayed Main cause Fixing roller heater (LA1) low temperature error Thermistor1 (TH1), Power supply assembly, Fixing roller heater (LA1), or DC controller PCB Fixing roller heater (LA1) low temperature error: Thermistor, fixing roller heater, AC driver, power supply assembly, DC controller PCB, thermoswitch (F1), auxiliary thermistor (TH2) Fixing roller heater (LA1) low temperature error: Thermistor (TH1), fixing roller heater, power supply assembly, DC controller PCB, thermoswitch (F1), auxiliary thermistor (TH2) Fixing heater ON timing error: Triac (U104) on power supply assembly Main motor error: Main motor (M1), DC controller PCB Counter (CNT1), DC controller PCB E000 E001 E002 E003 E004 E010 E030
Jan 05, 2010 | Canon Office Equipment & Supplies
System Error E000 and E003
E002 Error code details Heater temperature error (fails to reachspecific level; inadequate increase)
0000 The temperature of the fixing film is as follows:
1. has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
2. has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
3. has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact, or the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
 To clear the error, execute the following in service mode: COPIER>FUNCTION>FCLEAR>ERR.
Action
 See the description for E003. E003 Error code details Heater temperature error (abnormal drop; low-temperature detection)
0000 The main thermistor reading is lower than 140°C when paper is moved.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact or has an open circuit; or, the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
 To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
Action
1. State
 Turn on the power switch, and clear E002/E003. Thereafter, turn off and then on the power switch. Does the fixing heater operate?
2. Wiring
 YES: End.
Jul 28, 2009 | Canon imageRUNNER 2000 Copier
752 people viewed this question
old marine
old marine
