Question about Haier HRF10 Top Freezer Refrigerator
Would the defrost timer cause the fridge not to cool
Would the potential relay or defrost timer cause the fridge not to cool
  • Haier Master
  • 4,654 Answers
In one post you saud the fans run but not the compressor. I believe that either the compressor sart relay, overload and run capacitor are the most likely problem causing the compressor to not run. You also could have a defective compressor so until you check the compressor I would wait before buying a lot of parts. Unplug the refrigerator and remove the back panel that covers the compressor. There should be 3 wires going inside the cover of the compressor. Mark all 3 and mark their location so if compressor is OK you can put them back in same order. The plastic cover may snap on and you may need to squeeze the sides to unlock the cover and sometimes there is a metal clip holding the cover in place. Remove the cover. May look hard but it's simple. There will be three connections under the cover and 2 will go through the start relay. Unplug them leaving the three prongs exposed. They may be marked R =Run, S=Start and C=Common. Set your meter on continuity and then begin by testing 2 at a time until you have checked S to R and R to C an C to S and S to R again. You should get a reading all the way around. If no reading between any of the pairs as you go around you should get no reading between any two the compressor has an open winding and is defective. Then if it passes that test then touch one probe to R and the other to the copper pipes or clean metal on outside of compressor, then S to metal outside and C to metal outside. If you get a reading this way even just a little. The compressor is a burnout. Then let me know what you find. Thanks, Sea Breeze
Posted on Oct 25, 2012
  • John Tripp
    John Tripp Oct 25, 2012
    In one post you said the fans run but not the compressor. I believe that either the compressor start relay, overload and run capacitor are the most likely problem causing the compressor to not run. You also could have a defective compressor so until you check the compressor. Sorry about the misspellings....JT
Whirlpool ffw400wh cools nicely for 3 days then form ice on the freezer & does not cool at the fridge compartment
Sounds like your defrost timer is not functioning , it will need to be replaced. Some times the frost free fan can also cause this but I think it will be the defrost timer.
Located under the fridge usually on one of the rear corners.
Pit has like I white round dial on it .
Jan 09, 2014 | Whirlpool Refrigerators
The fridge dont work properly, the the temperature of the freezer and fridge seems to be the same and it switches off for a long time and goes on again causing the food to defrost and go bad.
Usually that is caused by the defrost timer/control sticking on...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 03, 2010 | Refrigerators
Hotpoint HSS25GFP freezer side keeps thawing completely and refreezing causing freezer burnt food. what would cause this
Defrost timer/control is sticking...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 15, 2010 | Hotpoint HSS25GFP Side by Side...
Where is the hotpoint HSS251FMD WW defrost timer located?
Hi, I think Your model number is HSS25IFMDCC . There is no defrost timer on your refrigerator, main relay board controls defrost cycles in this fridge. main board p/n WR55X10942 But I suggest to check on heater and defrost switch first - more common problem on this refrigerators. here is my video. hope it helps.
Aug 24, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
My fridge stops working about once a day you can unplug it and plug it back in after about ten minutes and the freezer goes back to working what s the problem
The defrost timer or board(relay) is sticking...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 19, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have lights and power but no cooling in the fridge or freezer
The themostat could be stuck open, the defrost timer could be stuck in defrost or the compressor start relay/overload could be bad. All are worth fixing.
Bump the thermostat with the heal of your hand. If the fridge starts, the termostat is bad. The defrost timer is in the same housing as the thermostat. There is a dime sized hole in the bottom of the housing that will show a white or black "screw". Use a screwdriver to turn it 1/4 turn. If the fridge starts, timer is bad. You need a tech for the relay/overload.
Mar 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer is cold but refrigerator side isnt cooling.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
heatman101
Nov 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore side by side Refrigirator
Sounds like you have a defrost problem. The timer could be playing up and taking too long to defrost, which causes the evaporator to ice up, hence no cold air to the fridge and the water line freezes up, hence no water dispensed. When the timer does eventually defrost the fridge then everything returns to normal. This could also be caused by a faulty defrost terminator or bad connection on the defrost element.
Sep 15, 2007 | Kenmore 50522 / 50524 Side by Side...
My LG LRBN20514ST Fridge is not cooling
where to look for the defrost timer on the LG top freezer modle
GR-S392GCA
Aug 26, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Haier HRF10 Top Freezer Refrigerator Logo
153 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
