Konica minolta 7030 drum replacment
Is replacing the drum on the Konica 7030 something that a user can do with instructions? If so do you know where we can find instructions?
  • 81 Answers
Is this a photocopier? If so then you will need a technician to fit this for you
Posted on Jan 03, 2009
Konica 7020
Did you blow it up, probably not.
Click this link for the everything.
http://www.kmbs.konicaminolta.us/content/support/supporthome.html
  1. Choose the Category "Office Systems"
  2. Choose the model "7020"
  3. Click the error next to the Model dropdown box.
  4. Choose the 1876KB user manual called "User Manual for 7020, 7025, 7030 and 7035"
Or click on this link for the specific manual.
The error codes you seek are not in the manual, you'll have to call Konica to tell you what they are ... call Konica at (860) 683-2222.
Hope this helps. Rate a fixya!
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
I have a konica 7020 machine, the first copy comes with horizontal black lines but not the others (when copying e.g more than one copy)
1 look to the drum surface for scratch if their is replaced it. 2 the write unit might already defective. Damage drum will cause sparks to charging unit and Horizontal lines produce.
Dec 02, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Code F- 43-1, always pop out whenever i open the power
Your Exposure lamp (Halogen lamp) L1 is busted or the Optic fuse F1 is open---continuity test use tester. Replace it.
Sep 26, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Hooper assembly is not working in coping but working in 47 mode
remove the drum assy. and have the the drum and developer replaced along with having the drum and developer assy. cleaned and the senors that are on the assy, then have the proper procedures run after the developer and drum are installed, ALSO have the counters reset to let the copier know that new developer and drum have been replaced
Apr 10, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Copy of konica 7135 is unclear while running. at first is copy is clear, later the copy is not clear... blurred
try to make some copies from your pc if the results is ok that simply means something with your scanner unit, for exaple the pnnel needs to be lubricated and the ccd unit needs to be cleaned.
Mar 20, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Error code c3905 in konica minolta bizhub 950
When C-35**,C-38** or C-39**(fusing temperature related
abnormality) occurs, be sure to repair defective parts before
setting DIPSW3-1 to 0. Setting DIPSW3-1 to 0 with defective
parts not repaired results in a fire.
Dec 21, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
I've replaced all neccesary ink colors and now my 2530DL Konica Minolta wants me to replace my Drum Cartridge... I don't know what that is or how to do it!
Open the Front Cover and remove the OPC drum cartridge by pulling up from the green lever. I'm sure you'll find all these instructions on the box the new drum is comming.
May 14, 2009 | Konica Minolta Magicolor 2530 DL Laser...
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
Konica 1400 page pro
Toner Cart is combined with Drum Cart in what's called an "Image cartridge" did you followed user manual instruction to change it?
Let me know if you have the instruction from User manual: I can send it.
Nov 24, 2008 | Konica Minolta PagePro 1400 Laser Printer
102 people viewed this question
k24674
