Question about Echo CS400 18" Chain Saw
Need fuel line diagram for Echo CS400 chainsaw
This saw has a gas line or vent line coming from the crankcase into the carburator. I think this has something to do with EPA environmental emissions laws, I'm not sure how to connect all the gas lines from the purge bulb tank and the line from the engine block. Please help.
  • Echo Master
  • 7,482 Answers
Hi
I believe this is what your looking for
Please rate me
Bud
Posted on Oct 25, 2012
steve_lima
  • 181 Answers
SOURCE: Echo 452VL chainsaw won't start
yes it does.the filter is in the fuel tank on the end of fuel line.if it isn't the fuel line needs to be replaced and a new filter installed.there is most likely some of the fuel line in side the carb. there is a small filter inside and it usualy collects the broken fuel line there. take the carb apart oppiset of the diaphram.usualy it's the side with only one screw.carefully blow the **** from it and the saw will get fuel again and start
Posted on Feb 23, 2009
  • 63 Answers
SOURCE: Echo cs-341 stalls out when cutting sideways
Make sure the fuel filter is indeed attached to the fuel line in the tank and pushed down to the bottom of the tank.
Posted on Mar 16, 2009
#1 Taper
  • 1040 Answers
SOURCE: Hard starting Stihl 024 chainsaw
If it's not getting spark with a new plug, then it may be the module ignition (coil). But you really need to get in a dark area and try to see if it's getting spark. If it is getting spark let me know, I should still be able to help you.
Jim
Posted on May 30, 2009
  • 4088 Answers
SOURCE: Chain brake jammed on Echo CS400 chainsaw
You will need to release the brake by applying a very heavy screwdriver to the + shaped part of the brake coupling. Check the action of the brake handle and duplicate it at the the +. Hope this helps!
Posted on Jun 26, 2010
SOURCE: how to replace primer bulb on small echo gas chain saw.
I just replaced the primer bulb on my Echo cs-305.
I didn't find the parts list too helpful.
It's easy. All you have to do is remove the air filter and look at the existing bulb from the bottom-- you can reach in with a screwdriver and pop the 'feet' holding it in place off their catches. When I put the new one in, I attached the tubes using a pair of needlenose pliers.
Posted on Mar 05, 2012
My Echo CS 3400 chain saw has an air vent problem
Most handheld power tools have a tank vent that will hold some pressure, Don't quote me. But If I turn the saw sideways and the vent allowed fuel to drain out THIS WOULD CREATE A FIRE HAZARD. If the fuel is boiling when you open the fuel cap could this be a engine temperature problem? or low octane fuel.
Apr 07, 2014 | Garden
Fuel line routing
small line should be the filtered line and go to the inlet side of the carb... single screw
Nov 12, 2013 | Echo CS400 18" Chain Saw
What happen if fuel gas is filled to bar oil tank?
No real damage will be done, just empty the gas out and re fill with chain oil, thats all you need to do.
May 08, 2013 | Echo CS400 18" Chain Saw
All of a sodden when I give my saw gas it dies. What is the problem???
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for any damage. Make sure the carburetor is not coming loose from the engine. Hope this helps!
Oct 24, 2010 | Echo CS400 18" Chain Saw
To much oil from thechain and bar
http://www.echo-usa.com/pdf/documentation/CS400es1112_111109.pdf
If a CS400 the oiler is adjustable. See page 27 of the above attachment. You can download an OM here:
EchoUSA
http://www.echo-usa.com/documentation.asp
If your saw is not listed type "CS" in the “Model:” window, click "Search" and select your saw from the list provided.
I think the serial number is key to getting the correct one.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Sep 06, 2010 | Echo CS400 18" Chain Saw
Engine dies at full throttle, manual says to clean fuel filter and vent but no clue where they are.. only ran 4 tanks of fuel through it before this started all of a sudden, not gradual loss of power,...
Fuel filter is usually on the end of the "fuel finder" hose inside the tank. The tank vent is USUALLY a small hole in the tank cap.
OFTEN these problems are caused by the diaphram in the fuel pump going bad, or the check valves if it has sat with fuel in it. The diaphram is in the carbureator and works from the vacuum pulses . The check valves are tiny flappers. If you have the problem, a carb rebuild kit is the fix.
Aug 07, 2010 | Echo CS400 18" Chain Saw
Cs 3000 carburator rebuild instructions
Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetors that apply to other brands as well. Make sure that all the external factors have been checked--fuel filter, fuel lines, primer, and carburetor fastener tightness. Check the air cleaner and muffler for plugging. Good luck!
Jun 10, 2010 | Echo CS400 18" Chain Saw
Echo CS400 18" Chain Saw Logo
1,283 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
