Question about Sony Handycam CCD-TR516 Camcorder
My Sony CCD-TR516e comes up with error code C:31:23 when I play a tape for longer than 4 seconds. Any help would be great
  • 169 Answers
SOURCE: Sony DCR-TRV140 CODE
the reel sensor is the problem of your camera...in my job as a technician i always encounter that..it is a poor connection of the sensor to the mainboard..try to clean the contact using only a pencil eraser..
Posted on Apr 13, 2008
welcomejee
  • 10594 Answers
SOURCE: SONY HANDYCAM MODEL CCD-FX730V
Its arround 1993 model camera and part supply has an end by Sony. Problem is Capacitors mounted on boards. If you can change them, go ahead.
Posted on Aug 03, 2008
SOURCE: Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Posted on Oct 21, 2008
SOURCE: handycam won't play tape
i have thi problem to it is the x700 sony one :/
let me know if you have sorted the problem and tell me the soluvtion as i haven't yet :/
thankyou
Posted on Feb 24, 2010
SOURCE: Sony Handycam Vision ccd-trv308
I have the DCR-HC32. I got the c:31:22 error with a message to reload the tape. I could load another tape and saw a post that if a tape is at the end and the tension is tight the camera has a sensor that won't load the tape so that it does not break it. I loosened the tape after a few tries and it loaded fine...no more errors.
Posted on Jun 09, 2010
I have an older (1996) Sony Handycam CCD-TRV211. I am using the player to transfer my old 8mm tapes to my computer. The player will play for about 4 seconds then stop. I get a blinking triangle with a...
How are you powering the camcorder ? Many will not transfer videos if battery powered, since the battery may fail. Try again with the camcorder mains powered, see if that helps. Have you cleaned the heads with a cotton bud and a little IPA ?
Mar 01, 2017 | Cameras
I Can not see picture and also hear the sound when i play back my recorded ...
try running a head cleaning tape for about 5 to 10 seconds and then try to play your tape again. If it improves, but is not yet right, repeat process. We use a Sony 8mm Head Cleaner in our repair shop (for minor cleaning issues) and it works great....lasts a really long time too.
Hope this helps you
www.austintelstarservices.com
Oct 03, 2010 | Sony Handycam CCD-TRV318 Camcorder
Sony TRV218E C:31:23 error code can't play tapes?
my sony camcorder ccd-trv218e pal is flassing c:31:23 code what can i do its not playing my tapes
Sep 22, 2010 | Sony Handycam CCD-TRV218 Camcorder
I have a Sony CCD-TRV308 NTSC that flashes the following fault codes: C:31:40, C:31:22 and C:31:23. I have repeatedly removed the tape and the battery in an attempt to clear this. It will run for a few...
The 4-digit error code consisting of an alphabet and numbers, which blinks at 3.2 Hz is dislayed on the screen when any problems occur. This 5-character display indicates the "repaired by:", "block" in which the problem occurred, and "detailed code" of the problem.
The error code C:31:22 and C:31:23 indicates T reel fault and S reel fault respectively. Load the tape again, and perform operations from the beginning.
The error code C:31:40 indicates FG fault when starting drum. Load the tape again, and perform operations from the beginning.
Furthermore, press and hold the power button for 30 seconds then try using the Camcorder.
If the issue persists then service is required.
Sep 17, 2009 | Sony Handycam CCD-TRV308 Camcorder
Sony CCD-TRV85. Tape Stuck - C31:22.
my guess is that there is a problem with the tape. Does it work with other tapes? Or haven't you tried?
Aug 23, 2009 | Sony Handycam CCD-TRV37 Camcorder
Error Code C:31:00 in a Sony CCD-TRV75 Handycam Camcorder
    This error shows that the problem is in mechanical section of the tape loading path. Please contact an expert for mechanical adjustment
 Thanks for using fixya.
May 21, 2009 | Sony Handycam CCD-TRV75 Camcorder
Jul 24, 2008 | Sony Handycam CCD-TRV37 Camcorder
Old tapes don't play
I have the same problems. Makes me mad. I have a years worth of tapes that I can no longer view. My dog at peed on my old camera which was a digital one.
Mar 03, 2007 | Sony Hi8 CCD-TRV138 Camcorder
Sony Handycam CCD-TR516 Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
