I have a Acer laptop... It needed to repair the start up... Then it gave me options: the one I chose was restore to a previous day. It shut down to restart and now won't turn on. The blue power light just blinks a few times and stops. Cheap computer >:(
    Master:
  • 444 Answers
Call there customor support office if they have one, Most companies are more then happy to try end help you out, I have a (Asus) Laptop that is only 5 months old end had start up problems with it, There customor (Support) Is verry good,
Posted on Oct 25, 2012
  • Patricia Tague Oct 25, 2012
    I can't find who said it, but someone said to take the watch battery out and put it back in to reset it... It worked!!!!
5 Suggested Answers
  • 66 Answers
SOURCE: My computer keeps restarting itself
What operating system are you using? Windows XP? What was the last thing installed? IE7 or regular Windows updates. Assuming Windows 2000 or higher, press F8 every couple of seconds during the initial boot process. Select "Safe Mode". Once at the desktop you have a couple of options depending on your configuration. Attempt "Start", "Programs", "Accessories", "System Tools", "System Restore". Following the prompts, choose the latest date in bold prior to the lastest installed software. If system restore is off, choose "Start", "Control Panel", "Add / Remove Software", remove IE7 or latest installed software.
Posted on Nov 06, 2008
rulds2008
  • 3866 Answers
SOURCE: acer aspire 3000 won't come on just yellow light blinks
Psu failed!! your goingto need that serviced if its under warrenty you need to take it in its hard for us guru's to solve every problem without more details.
Posted on Apr 22, 2009
  • 253 Answers
SOURCE: gateway t 1625 laptop not booting
If u can, try to reformat it, reason i say this simple solution is because u already had the laptop looked at professionally, and due to you're laptop being stuck at the windows screen, i see this happen on HDD swaps a lot. The HDD needs to be repair-formatted or fully reformatted to talk to the new mobo when switched out, try this if all else fails, i personally think giving this simple solution may fix the boot up issue, but do make sure ur friend who looked at your laptop hadn't reset ur C MOS and may of not reconfigured it, this may also be the main cause of boot up troubles so make sure everything looks fine in ur BIOS. Gabriel will have a more proper solution than this but i believe by doing this it may help u bypass ur loading issue
Posted on Jun 24, 2009
  • 61 Answers
SOURCE: blue led power light blinks even after shutdown
What operating system are you using? When the power led continues to slowly blink, that means that the laptop is in standby mode and not fully shut down. In Vista, if you hit the power button on the laptop or the power button under the start button, it is configured to go to standby and not shut down. Make sure to hit the arrow all the way to the right and select shutdown from the list of dropdown options.
Posted on Aug 28, 2009
Windows failed to start
while starting ur window press f8 continuesly (as i dont know when booting ocurs in ur windows) then chose restore/redair if u want back ur previous window . chose safe mode if u just want to see ur files of use internet(in safe mode with networking).
NOTE: if u chose restore some of ur newly installed softwares,drivers, apps will be removed unless and until u don't chose restore after repair.
Jul 03, 2013 | Microsoft Computers & Internet
My acer aspire one 722 wont boot startup repair wont fix it
This is a problem in your BIOS which is a common problem on acer aspire one laptop model. To fix that you need to flash your bios. Please watch this video for a step by step guide on how to do that.
Feb 15, 2013 | Acer Aspire One 722-0022 : 1.0GHz C-Series...
I have problem, forgot my windows 7 password, called acer helpline, they advised to reset computer to factory setting by f10 and alt button on turning computer on. it gave me 2 options. save info and...
I am sorry to hear regarding the trouble.
This is a common problem with Acer. You need to press at the same time the two keys Alt and F10 when you see the Acer logo appearing.You might have to do it twice or thrice. You would be able to see the recovery management screen and then you could follow and restore the same.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 12, 2011 | Acer Aspire Z5700 PC Desktop
My laptop won't turn on. It goes past the logo screen then goes blank.
shut down the laptop and start it again...immediately start hitting f8 key..select option ....safe mode....
if it works go to start .accessories and system tools and restore the system to previous date where in it was working fine..
it should be able to work perfect then
May 30, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
My acer aspire 5520 keeps shutting down on boot. When i switch it on, its shows the boot screen then immediately shuts down. I had previously installed windows 7 on my second hard disk drive and the duel...
Insert your restore CD if errors are found and not fixed by the checkdisk function listed above. Turn your computer off and then back on. You'll beasked to hit any button to boot from your CD; press any key. You will then beasked if you want to install a fresh version of your OS or "Repair" acurrent copy. Choose the "Repair" option.
Dec 24, 2009 | Acer Aspire 5520-5908 Notebook
I have acer aspire 5920 vista when i shut down laptop i pressed acer arcade button then it started up and shut down again now it will not start up !all im gettin is restore settings .they dont work to...
tell me, are you able to get to the menu when you computer starts up (F8 options )
if so just go for the option last knowing good configuration.
it will start up as normal. if it does try to do a system restore from a few days ago.. restart again and it will work .
in case the F8 menu does not show up.try removing the battery for at least 3 days so the CMOS resets to default.
hope it works
Oct 07, 2009 | Acer Aspire 5920-6727 Notebook
ACER Aspire 5100 powers down at will
When you turn the laptop on hit f8 until the menu comes up, try use the last good known configuration. If that does not work tap f8 goto safe mode and then to system restore and restore it to an earlier time. Let me know if it works.
Apr 15, 2009 | Acer Aspire 5100 Notebook
Computers & Internet Logo
145 people viewed this question
David Payne
David Payne
