Question about ASUS Eee Pc 1005 Ha 10.1 250 Gb 1.66 Ghz Blue Netbook
The original battery for my Asus Eee PC 1005 PEB failed and the computer stopped working. I replaced the battery and the computer still won't come on.
My pc battery was 2 years old when it began to fail. I replaced it as soon as I could. The computer stopped working completely just before the battery arrived. Even after replacing the old battery, my Eee PC does not come on. The blue power light, the right side power button lights up and the red battery light flashes, but the computer does not boot up. After holding the power button down for several seconds, the blue lights go out and the red battery light continues to flash.
  • ASUS Master
  • 32,281 Answers
The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Oct 25, 2012
3 Suggested Answers
SOURCE: What to do with Asus Eee PC Seashell 1215N-PU27-BK-D525 blue power indicator light and power button, with flashing red light at battery charge indicator light? Computer will not come on.
try this
take out battery completely
plug into the ac adapter only
turn on computer
if that works, let it run for a few min then insert battery while still running
Posted on Jun 14, 2012
SOURCE: Asus Eee pc 900 can't boot (blank screen)
Just had the same thing happen, and I thought it was the motherboard. Then a tech friend removed the battery and held the power button down. Then he replaced the battery, and it booted up fine! Good luck...
Posted on Oct 29, 2009
Re: hp compaq 6910p laptop start button stays lighted, as does volume indicator, and sometimes two colors on he ethernet plug-in. The start will not turn off. And it will not start computer. And...
Hi, please try first by unplug charger and then remove battery, after about 10 minutes, insert battery again and plug it charger, only the battery charging indicator should light on, if the status of other indicators keeps in the same way, maybe the motherboard is faulty and needs to be replaced, in such case, don't worry about your data, it can be recovered since hard disk can be taken apart from your computer to be connected to another one to access your data.
Nov 07, 2017 | HP Compaq 6910p Notebook PC PC Notebook
Gateway ZX4300 - power adapter problem
Verify all specifications of your previous charger and new chargers/adaptors.
Jun 24, 2013 | Computers & Internet
Bios page won't function. I'm trying to Setup with F2 but none of the functions work. I'm using an EE pc 1005 HB.
Hello wmalvinx.
in the manual they say press F2 twice.
first press will show then post screen
sec. press open the bios.
mfg Gue
Feb 26, 2013 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
Finding a new replacement battery for my laptop
The quality of the battery determines the life of the battery.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Feb 09, 2013 | Affinity Technologies ZT Affinity...
ASUS netbook 1005 HA charger won't stay in to keep charging battery
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Aug 08, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Need to find a way to reboot an Asus eeePC 1005 PEB-RRED01S
What is the problem? Why won't it reboot? Does it get power and try to reboot? Give us more details and we'll get it booted.
May 19, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My Asus Eee PC battery light flashes orange all the time. The battery does not charge. What does this mean.
Well it simply means that youre battery needs replacing. Youre netbook can detect it if it flashes on youre indicator and the power is actually going in youre battery but it simply won't charge because it has passed its usable life.
Sep 24, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I have a Eee Pc series 1005. I need to know if it have a bluetooth.
Sorry, but the Asus Eee 1005 series does not have bluetooth capabilities.
Jul 10, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My battery on my ASUS Eee PC 1005HAB died. Also, the Battery Charge Indicator stop working, I since replaced the battery with An ASUS 7200mAH battery. I ran it down till it was drained and tried to...
Check the voltage at the pins of the adapter. If present accordingg to the specifications then connect to the laptop and remove the battery from behind. Now check the voltage at the battery terminal of the laptop. if there is low or no voltage to the desired level then there are problems within the main board as this insufficient voltage will not charge the battery makeing it go down below level.
Jul 09, 2011 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
ASUS Eee Pc 1005 Ha 10.1 250 Gb 1.66 Ghz Blue Netbook Logo
576 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
