Question about Motorola Mobility H300 Wireless Headset
Can't connect motorola headset to Instinct phone
I have entered the pass key 0000 several times and it keeps saying "The key didn't return during pairing" Any ideas?
Thanks!
  • 321 Answers
Turn off headset
then press and hold on button untill the light stays on
not blicks i mean stays on on
then run your other bluetooth discovery
on your laptop
Posted on Mar 10, 2010
I recieved a repacement phone and I don't know what my pass key is. What is a pass key?
The pass key is a number the bluetooth headset uses so it can connect to the cell phone. The pass key for the headset should be 0000...Hope that helps.
Nov 07, 2009 | Motorola Mobility H700 Wireless Headset
Need generic pass key for H700
open boom on ear piece
turn on bluetooth on phone and go to paired devices
hold button on ear piece till lite turns purple
under paired devices click connect
0000 is the pass key
should work
May 28, 2009 | Motorola Mobility H700 Wireless Headset
Blue tooth compatible Car stereo ..and LG Voyager wont pair
The pass key is the password the bluetooth accessory has. So your car stereo manufacturer has a code that you enter on your phone, so that someone nearby with a bluetooth cell phone won't be able to hook to your stereo - it's usually in your owners manual for your stereo or bluetooth speaker system.
Most bluetooth headsets have a passcode of 0000, and it's the same for Motorola headsets, plantronics headsets etc. You may be able to lookup the passcode for your bluetooth speaker system in a manual online, if you no longer have it.
Mar 25, 2009 | LG VOYAGER VX10000 Cellular Phone
Can't sync H12 from LG Cell Phone to New Blackberry
took me a minute, but i figured it out on mine.  Without using the alt button, type 0000 then hit enter.  Hopefully this will work for you as well.
Mar 04, 2009 | Motorola Mobility Motopure H12 Bluetooth...
Need a pass key for a motorola h300 in order to pair it with a samsung sphm 540
the pass key is 0000
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit. (The light will flash while you
hold the Call button.)
If the indicator light is flashing or does not
remain steadily lit, turn off the headset and
repeat step 1.
Before you can use your headset, you must
pair (link) it with your phone.
Step A - PUT HEADSET IN PAIRING MODE
Note: To turn off headset, see "Turning On and Off" on the
reverse side of this guide.
PAIR
Your Phone
Select (Menu) > Settings > Connection >
Bluetooth Link > Handsfree > Look for Devices.
The phone lists all Bluetooth devices it finds.
Select Motorola H300.
Press OK or Yes to pair (link) the handsfree
device.
Enter the passkey 0000 and press OK.
Note: Passkey cannot be changed
from 0000.
Step B - SET THE PHONE TO LOOK FOR
YOUR HEADSET
When your headset is successfully paired
Jan 22, 2009 | Motorola Mobility H300 Wireless Headset
Pass key
pass key 0000
for more clear instructions go here
http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf
repeat step 1.
PAIR
Your Phone
device.
from 0000.
YOUR HEADSET
Jan 13, 2009 | Motorola Mobility H300 Wireless Headset
Forgot pass key
almost blue devices pass key set on 0000 but if you are anable to access with this code then reset your device and use this code.
http://www.blue-devices.com
Dec 31, 2008 | Mad Catz PS3 Bluetooth® Headset Wireless...
Wont hook up to PS3
Alll it says in the manul under Pairing: Charge for 2 hours before use
Step1: When the headset is off, press and hold the mutlifunction button until the headset indicator turns on permantly
Step2: Perfrom device scan from the PS3 in this case.
Step3: Confirm Motorola HS820 in the list discovered by ps3 and confirm.
Step4: When requested to enter Passkey enter:0000
Pairing is successful when the headset indicator flashes rapidly.
Jan 06, 2008 | Motorola Mobility HS820 Consumer Headset
Connectivity problems with my Nextel Blackberry 7100i
I am not sure this is what solved my problem but it worked after I did this. When you enter the 0000 code, make sure to hit the enter key and not push the trackwheel. That made the connection work.
Oct 29, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H300 Wireless Headset Logo
63 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
