Question about Acer Aspire 3680 Laptop
Acer lost its os
Thanks for your reply,have tried the f8 but there is no last good/known configuration link anywhere.I have tried to restore but just keep getting same message,media cable failure and cannot find os.thanks anyway,jue.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Ok sorry that didn't work. If it were my computer then I would take the error at it's face value and basically find someplace or someway to change the cable that goes from my hard drive to my motherboard. Since it says "media cable" failure. I don't know at what level you are but changing it is fairly easy. Just open the case, to see if it is a gray flat cable (EIDE) or a smaller rounder cable (SATA). Then look up "SATA Cable" or "EIDE cable" on the web and buy one and replace it.
    President:
  • 2,692 Answers
Sound like yuou hard drtrive might have bit the dust. have you attempted to reload your system with the cd? If it doesn't reload replace the hard drive then reload the OS. Theire are 55 download available for you notebook including the ISO CD
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com/canada&siteid=7297&areaid=17&formid=3394#results
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=1016&formid=3425&website=AcerPanAm.com/canada&siteid=7297&words=all&keywords=&areaid=17
Posted on Jan 04, 2009
Acer veriton M460 does not boot to desktop.It boots to windows xp and suddenly brings a flash of yellow light then it stops displaying anything on the screen but d syystem remains on without displaying...
There are a couple of quick fixes you can do.
First, boot into Safe Mode (Repeatedly tap the F8 key while the system is booting, before the windows logo appears) A Menu will pop up, press Boot Into Safe Mode. From there you can try a System Restore to a known good date.
System Restore - Click Start -> Control Panel -> On the top right, type "System Restore" without the quotes. Click on "Restore system files and settings from a restore point". You can choose the recommended restore or a specific date.
The other option is to boot into "Last Known Good Configuration". To do this, use the F8 trick again while booting, but instead of Safe Mode choose "Last Known Good Configuration".
Please note that either of these run a risk of some data being lost from the time the restore point was made. You "shouldn't" lose anything but just want to make you aware.
If this helps, please give a positive rating.
Jul 01, 2011 | Acer Veriton M460 Micro Tower Core 2 DUO...
When booting desktop doesn't load
If this helps please give a good rating. Thanks.
Jun 30, 2011 | Gateway Computers & Internet
ACER aspier 5732 will not completely booy up. Get starting windows screen but after that only get black screen and can only see the cursor. Cursor will respond and move acroos the screen when touching...
Jun 24, 2011 | Acer Computers & Internet
Wont boot up after an improper shut down, how can i make it boot up?
Try tapping F8 while booting and go to boot with "last know good configuration" if that doesn't work hit f8 again while booting and go to "safe mode" and do a system restore :) hope this helps thanks
Dec 30, 2010 | Acer Aspire One 10.1" Netbook Computer -...
Aspire 5532. my lapyop keeps saying logging off and wont turn on
Tap the F8 at the time of startup and get to advanced boot options. Select safemode with the arrow keys on keyboard and tap enter. Try to login. If yes, try a system restore. If no, try last known good configuration. If that also is not helping, then try an OS reinstallation.
Dec 21, 2010 | Acer Aspire 5520-5908 Notebook
Help needed for acer aspire one
Please cheek you keypad F8 key. I think its pressed. That's why when you press power button after a while that page comes up. If that's key is perfect & not pressed then select "last known good configuration (your most recent settings that worked)" and run the system. May be some system file are missing or corrupted and you OS wants to restore it. That's why you faced that message. Don't worry. Just do it. Hope you get success. Thanks and waiting for your reply.
Feb 11, 2010 | Acer Aspire One PC Notebook
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
Faced with following message/s: Winlogon.Exe Could Not Locate Component. This Application Has Failed To Start Because Comctl32.Dll Was Not Found. User Interface Failure. The logon user interface DLL...
Without an original OS installation disk, you are probably at an impasse as far as trying to repair the problem yourself. You might try this option to see if you might be able to get into the computer.
Try this first:
You can try to boot the operating system with the Last Known Good Configuration feature. This feature will allow you to undo any changes that caused problems in the CurrentControlSet registry key, which defines hardware and driver settings. The Last Known Good Configuration feature replaces the contents of the CurrentControlSet registry key with a backup copy that was last used to successfully start up the operating system.
To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message "Please select the operating system to start" or hear the single beep, immediately press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
Keep in mind that you get only one shot with the Last Known Good Configuration feature. In other words, if it fails to revive your Windows XP on the first attempt, the backup copy is also corrupt.
Failing this, you will probably have to send / take the computer to a repair facility to get the machine back online. I fix this kind of issue on a regular basis.
Jan 23, 2010 | Acer Aspire 5000 Notebook
Kenapa IBM net viata dengan OS win Xp_SP2 tidak bisa turn off otomatis, tp harus menekan tombol power lama2....thanks,please reply to my email chn88tan@yahoo.co.id
use restore for last best known configuration from restarting the system....and as soon as it starts keep pressing F8 and you will ne diverted to safe mode console......over hear....you can use last good config.....
Feb 19, 2009 | IBM NetVista PC Desktop
Boot-up
dot.gif How to load last known good configuration. Question: How to load last known good configuration.
Additional information: The "Last Known Good Configuration" option was first introduced in Microsoft Windows 2000 and is available in all later versions of Windows including Windows XP. This feature enables a user to load the last working version of Microsoft Windows. This is a great step to try when trying to fix issues with a computer not being able to load into Windows.
Note: Users able to open normal Windows XP mode and who wish to restore their version of Windows to an date before the last known good configuration may also wish to consider doing a system recovery in Windows. Additional information about how to do this can be found on document CH000589.
Answer: To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key. Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP safe mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the safe mode screen.
Please select an option: Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows. Will running the Last Known Good Configuration delete anything? No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Dec 06, 2007 | Computers & Internet
Acer Aspire 3680 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
