Question about Canon DC310 DVD Camcorder
Dropped camera disc cover jammed - Canon DC310 DVD Camcorder
Hi Officer, currently a CD is dropped inside the player, however it does not hinder the disc rotation and the playing but i can hear the sound of the CD when rotating disc. i am afraid one day it will...
First of all remove any disks that are in the tray and then unplug the power cord for the unit.
Use a Philips screwdriver to remove the dozen or so screws from the sides and back that hold on the top cover. There will be many other screws there as well, but try to just remove the ones securing the upper casing cover to the lower casing frame.
Once the screws are out, just remove the top casing cover and then you should have an unobstructed view of the internal components and of any disks that may have accidentally fallen inside the case.
Now just remove the offending disk and then replace the cover and the screws.
Job complete. Just plug the unit back in and enjoy that long lost CD again.
I hope that was helpful to you, good luck and take care.
If you choose to rate this solution by clicking on the YES THIS WAS HELPFUL icon, I thank you very much for your time and consideration.
Joe.
Aug 02, 2011 | Sherwood CDC-690T CD Player
I dropped my olympus 540 zoom camera and lens cover is jammed
The problem you are describing is a problem with a sensor in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $73 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 18, 2009 | Olympus SP-350 Digital Camera
We dropped our canon ixus 50 digital camera and lens jammed
You didn't mention what exactly is the problem. But please review the posts on the following blog, as they cover the most likely problems to result from a dropped camera to include lens errors, shattered LCD's, and non-starting cameras:
http://camerarepair.blogspot.com
Feb 02, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Dropped camera jammed zoom lens on nikon 28-85 lens
You have impact damage, the gears in the lens are out of alignment.
www.cameradr.com
he is a friend of mine who can fix this for you.
Jan 08, 2009 | Nikon Coolpix S210 Digital Camera
Snap picture button jammed
If you have some jewelers phillips screwdrivers (very small tips) you can take off some screws and maybe pop a cover back in place. The zoom lever has 3 screws holding it in....2 at the bottom of the battery compartment and one in the compact flash card area. Go here for pictures....
http://menthol.hit.bg/E18.html
May 25, 2008 | Canon PowerShot A75 Digital Camera
Dropped camera now it will not power up or anything battery is charged
You probably blew a fuse. Maybe the lens jammed and the motor could not overcome the jam so it shut itself down to protect itself. I dropped my first camera, under AMEX warranty and it came back with 3 fuses repaired, no physical damage-just wouldnt turn on.
Feb 22, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens cover issue
Check the Fuji Web site - but I fear it will be new camera time when you see the repair price
Aug 03, 2007 | Fuji FinePix F10 Digital Camera
Canon DC310 DVD Camcorder Logo
26 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
