Question about Life Fitness Exercise & Fitness
Lifecycle 95R Inspire Pedals/alternator slipping.
Lifecycle 95R Inspire free wheels intermittently while pedaling. Go's from resistance to no resistance with no warning and console indicates the user is not pedaling and starts shutdown countdown, but typically will regain resistance while user continues to pedal and resumes workout. It is dangerous to the user particularly at high resistance and high RPMs. I have replaced the battery with a brand new fully charged battery at Life Fitness recommendation, with negative results, the problem remains unchanged.
SOURCE: Charging idiot lite remains lit.
Check all connections. You may have a loose wire or defective alternator
Posted on Jul 25, 2008
SOURCE: belt slipping on life fitness 9000 also motor making noise
i have a t5 it comes up with 'motor comm error' any ideas?
Posted on Nov 27, 2009
gymtech
  • 18 Answers
SOURCE: The battery in my life fitness 9500hr has died.
What battery?
Posted on Feb 09, 2010
maxtreadmill
  • 832 Answers
SOURCE: How can I determine which Lifecycle I own.. I
On the bottom the bike frame their should be s# plate. If you need to replace the battery you need to: first remove the foot pedals,then side panels.
they sold run about $20.00 to $27.00 plus S/H
Posted on Feb 28, 2010
maxtreadmill
  • 832 Answers
SOURCE: pedals/resistance locked
Was this at a retail store you should exchage it.
If not then you will have to take the side off need to inspect all mechanical attached to the rails. It will be apparent to see the flywheel their eddy current transformer on top of unit or the flywheel itself is one package their should be are wire comming out of trace it back to the circuit unplug the connectors the resistance should be gone now test the mechanical function of unit to see if the pedal are free from any binding then reverse connectors and see if you can adjust the resistance if not the board is defective.
Posted on Mar 03, 2010
Slipping pedals on stairmaster 4400 freeclimber
Start by checking the alternator brushes. Worn brushes are the leading cause of no resistance issues in these machines.
SPORTSMITH LLC
Dec 03, 2013 | Stairmaster 4400 PT Stair Stepper
How do I remove the pedals on a 8500 life fitness recumbent bike
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Using a wrench, you remove the left pedal as you would loosen a normal, left hand threaded bolt. The right side is a reverse thread and would need to be loosened in the opposite direction.
Feb 20, 2013 | Life Fitness Nut Lock, Cranknut, Lifecycle...
Golds gym 380 elliptical is not increasing resistance
follow this steps, God bless you
    • Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
    • Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine.
Nov 14, 2012 | Golds Gym StrideTrainer 380 Elliptical
My Pro-Form 330 elliptical has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried switching the levels, but...
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Oct 27, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
Where is battery located for LifeFitness' Lifecycle 9500HR
The Lifefitness Lifesyscle 9500HR battery location is at in the lower portion of the recumbent bike. This is a 1/2 to one hour task for most do it yourself'er.
In order to gain access to the battery compartment,you has to remove the pedals.
The center cover has to be remove.
Additional reference: Lifecycle Battery 0819-0012 Model Description Terminal Volts AH L W H Lbs Price 0819-0012 Fits Lifecycle Stairmaster series 4200, 4400 - Lifecycle Lifefitness CT8500, CT9100, 9500HR, 95Ci - Star Trac 5300/6300, 5400/6400, StarTrac 6100 Pro, 6200 Elite, ET4600 (0819-0012 replaces the 0819-1006) F2 6 2.5 4.48 1.81 2.75 2 $19.80
Feb 02, 2011 | Life Fitness Exercise & Fitness
Both pedals slipping to floor as if no power was getting to it. screen reads stepper when first plugged in
I would start with checking your brushes in your alternator. If they are worn down, they will not make good contact. The resistance in this machine is provided by the alternator.
Testing Alternator of Stairmaster Steppers 4400CL 4600CL SC916
Sep 09, 2010 | Stairmaster 4600 Cl Cordless Freeclimber
Both pedals slip?
When both pedals slip at the same time, it is more likely to be the alternator brushes than it is to be the hub assembly. Check this link for a brush replacement video. I am also attaching a troubleshooting video for no resistance on a 4600PT.
Stairmaster Alternator Brush Replacement Video
Sep 08, 2010 | Stairmaster 4600PT Stepper
How to use the Proform 515S EKG Elliptical?
To mount the elliptical trainer, firmly hold the handlebars or the T-handle and carefully step onto the pedal that is in the lowest position. Next, step onto the other pedal. Push the pedals until they begin to move with a continuous motion. Note: The pedal disks can turn in either direction. It is recommended that you turn the pedal disks in the direction shown below; however, to give variety to your exercise, you may choose to turn the pedal disks in the opposite direction.
To dismount the elliptical trainer, allow the pedals to come to a complete stop. CAUTION: The elliptical trainer does not have a free wheel; the pedals will continue to move until the flywheel stops. When the pedals are stationary, step off the highest pedal first. Then, step off the lowest pedal.
As you exercise, you can adjust the resistance of the pedals with the resistance knob on the console. To increase the resistance, turn the knob clockwise; to decrease the resistance, turn the knob counterclockwise.
Jun 02, 2010 | Proform Exercise & Fitness
How can I determine which Lifecycle I own.. I purchased it second hand (X-Balley) and other then Lifecycle HR on its side I see nothing else discribing it. The battery is in need of replacement. I...
Feb 26, 2010 | Life Fitness 9500RHRT Recumbent Bike
Stairmaster 4000pt pedals lose resistance during workout
THEIR IS A TRANSMISSION ASSEMBLY IN THIS UNIT THAT CAN FAIL.. TAKE THE SIDE PANEL OF INSPECT THE ALTERNATOR BRUSHES THEY MAY BE WORN THUS ALSO CAUSING THIS PROBLEM THE LATTER WOULD A CHEAPER REPAIR
Feb 23, 2010 | Schwinn Wide Ride Pedal
Exercise & Fitness Logo
114 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
