Question about Addtron AEF 330TX (AEF-330TX-20P) Network Adapter
Need driver for Addtron AEF-330TX-1
Need driver for NIC card
  • Leroy Hicks Jr Nov 03, 2012
    I was already aware of this option and chose not to use it. Instead of investing in this and other options I purchased another NIC card with driver.
  • 3,606 Answers
Hello this is the only driver site i can find:
http://list.driverguide.com/list/company34/index.html
You maybe have to login as a user to download the file.
Or you can buy a new addin card that supports your
windows system.
Make sure the driver is to find.
Good luck
Posted on Nov 01, 2012
On a Gateway GT5028 - appears the ethernet card was damaged by power surge. We installed a new 10/100 NIC card but Gateway reports it has a problem. Any ideas? Do I need to disable the onboard NIC card...
No you do not need to disable the onboard Network Interface Card. I would suggest to first start by inserting the new NIC card in a dif. Spot.
If you do not have any other spots to insert it, i would double check to make sure you have the correct driver for the correct operating system that you are running, If you know the model # of your nic card i could gladly get you the correct driver. Let me know if this helps. Thanks
Jun 20, 2010 | Gateway GT5028 PC Desktop
I am looking for drivers for my Addtron AWP-100 PCMCIA Wireless
Good day Sir, try the link below and hope it will help to your problem.
Driver
thank you.
May 14, 2010 | Addtron AWP 100 Wireless Adapter
Go to the link below:
http://members.driverguide.com/driver/detail.php?driverid=131685
Mar 23, 2010 | Addtron AWP 100 Wireless Adapter
I had an idea to use a working addtron 16 port hub as a cheap and simple way to allow our boys access to the net and have control of their time online as well :>) We have a verizon account with an...
You do what you are describing, attach the hub to the router in any regular lan port. Then just plug everything you need to into the hub. Make sure dhcp is on on the router (it probably is) and just set it to automatically obtain the IP on the computers attached. The router can go through the hub (or switch) to give them IPs.
Aug 12, 2009 | Addtron (ADH-0016) Networking Hub
Network card not detecting in RHEL4 & 5
The solution proposed by user 'Solutions58' seems to be about windows box since he is talking about 'Device Manager'
RHEL4 or 5 detect compatible NIC cards during boot up process automatically. Sometimes NIC may be detected but may not work properly due to lack of proper driver (a.k.a Module - in Linux culture).
Do this -
1. First find out from HP's web site if NIC for your model has Linux support. You can also use Google to find appropriate driver for your NIC. If yes then you need to follow instructions that are provided in the INSATLL file that comes bundled with the driver.
2. Otherwise buy a $10 NIC card which has Linux support. Disable your onboard NIC through your computer's BIOS and boot it. Linux should detect your NIC right away.
3. Following command can help you in your quest
As root
# dmesg | grep eth (Will show your detected NIC)
# service network status (Will also show configured & active devices)
# ifconfig -a (Will also show your network devices and related info)
# system-config-network (will let you configure your NIC via GUI)
(This would be your best choice)
# system-config-newtowk-tui (Will give you a text base interface to configure your NIC)
Aug 05, 2009 | HP Computers & Internet
Have T3624 need drivers for nic card
Try going to eMachines driver support page and see if you can download the drivers for your system.
ALSO TRY:
Here are the drivers for emachines t3624 ethernet: http://downloadfinder.intel.com/scri...nm=PL2KXPM.EXE
Jul 12, 2009 | E-Machines Computers & Internet
LAN automatically disconnects while downloading and starts working only after disabling and again enabling the local area connection
With this issue it could be the Hardware / Software compatibility. The first thing to do is ensure the latest drivers are installed or the NIC. If the latest drivers are installed I would recommend replacing the NIC. They are less than $30 and they come with great drivers, and if the old NIC is onboard it would be advantageous to get it off the Motherboard. It would be best to open up the computer before you run out to get the new NIC and makesure the motherboard can support a PCI card. This card slips into the White slot that is about 3 inches long. If you have a White slot that is about 1 inch long this PCI card will not fit into it the card you will need is a PCI Express x1 NIC. The rest of the information you will need is provided by the NIC Manufacturer.
Mar 30, 2009 | Asustek S775 Intel X38 ATX Audio Lan...
Need windows 2000 server nic driver
Hello sir,
Try this link for Windows 2000 server.
http://www.opendrivers.com/driver/212753/3com-etherlink-server-nic-3c985-3c985b-driver-
windows-2000-free-download.html
Best of Luck
Don't forget to rate the solution.
thanks
Mar 11, 2008 | HP Compaq d220M (829160054797) PC Desktop
Addtron AEF-1004 network hub faulty?
Hey Beastman,
You have a real beast screwing around in that hub. You have choises:
1. Call the animal control department :)
2. Shoot it with a 22 :):)
3. Get another one.
A Hub acting like that has got its marbles juggled. Switching it on and off is the only way of flashing, and if that doesn't work, its jinxed. If you network it, you could spend a lot of time fixing network problems.
Hubs are cheap and not worth the headache.
Good luck.
Feb 21, 2008 | Addtron (AEF-1004) Networking Hub
Addtron AE-200 network card - jumpers setting
hi check this out: http://groups.google.com/groups/search?hl=iw&q=Addtron+AE+200+jumper++settings&qt_s=%D7%97%D7%99%D7%A4%D7%95%D7%A9 good luck
Apr 25, 2006 | Addtron AE 200 Network Adapter
Computers & Internet Logo
301 people viewed this question
Top Addtron Computers & Internet Experts
David Payne
David Payne
Are you an Addtron Computer and Internet Expert? Answer questions, earn points and help others
