Question about NetGear N300 Wireless Router
Cannot connect to internet through netgear n300 wireless router
My router doesn't seem to be broadcasting a signal. I can hook my computer directly to the modem and get on the internet but when I hook the router to the modem I get nothing - not on my desktop or wirelessly
  • 2,878 Answers
They are pretty straight forward. Connect the ISP modem to main uplink port. Then connect pc to any other port. Done!
Try resetting it by holding the reset in till it cycles through. This will clear all custom setting and try again.
I normally don't suggest firmware upgrades, but try updating.
192.168.0.1 Defual login if you cleared custom is User: admin Password: admin
http://www.downloads.netgear.com/files/DGND3300v2_UM_14Oct10.pdf
Other than that the unit is damaged / defective.
Posted on Oct 25, 2012
bee2busy
  • 51 Answers
SOURCE: Netgear Router WGR614 will not connect to internet
Looks like when you reset the router you have lost all yur configuration and back to the default factory settings.
Bridge the 5100 first.
1. In your web browser browse to »192.168.0.1 This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. Select Advanced from the blue buttons on the left.
4. Click the PPP locations button.
5. The modem may ask your for the Modem Access Code again. If so type it in again and click continue.
6. Select the radio button labeled, "Bridged Mode (PPPoE is not used)"
7. Click Save Changes.
8. A "PPP Location Warning" page will come up. Click "Change PPP Location."
9. A "Restart Needed" page will come up. Click "Restart"
10. Reboot your computer and and then connect the router
11.Configure the router for PPPoE using your ISP uid/pass
12.Configure your wireless using WEP
13.Desktop : Using Dell wireless client configure the client using the same SSID ,wep as configured in the router
Laptop : follow the same as desktop
(by default dell wirelesss client takes over the wireless configuration in dell pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Posted on Feb 26, 2008
JonwVBFL
  • 56 Answers
SOURCE: netgear wireless wpn824
Sounds link you need to setup PPPoE on your router. Not knowing who your ISP is, Netgear has this website that lists a lot of ISPs support on setting PPPoE up. that is located here: Netgear
If you can't find the info there, basically what you need to do is on your router, typically the main page, you might see an area that lists: DHCP, Static, PPPoE (or something similar). What you need to do, is select the PPPoE option and put your ISP login information (that is on your DSL modem now) there should be a connect or login button once your finished. Once that is done, your router does the logging in, instead of the modem.
Posted on Feb 03, 2008
TBlessed 1
  • 61 Answers
SOURCE: Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Posted on Dec 01, 2008
SOURCE: Can't connect my Netgear WGR614v7 to Time Warner Cable Internet
I have just bought a Netgear WGR14 v9 and I was wondering if anyone knows how to set it up with Time Warner. We just swithced from Bellsouth to Time Warner and I don't know how to set it up?
Posted on Apr 08, 2010
govinda123
  • 2260 Answers
SOURCE: I can not connect to internet through my Netgear
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on May 17, 2010
Although i have an internet connection my netgear n300 has suddenly stopped sending a wireless signal
Logon as the administrator and check the wireless setup to make sure it is still enabled.
Oct 08, 2013 | NetGear N300 Wireless Router
Netgear N300 is slowing down my internet connection
The router limits the data speed to the wireless reception.
802.11 G speed (maximum) is 54Mbps.
Jul 17, 2013 | NetGear N300 Wireless Router
Frequent loss of internet connection
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Sep 01, 2012 | Belkin Share N300 Wireless Router
Netgear n300 will not connect to internet
There should be a little red button that you can push. It is the reset button. Hold it down for around 10 seconds, and try again.
Jul 04, 2012 | NetGear N300 Wireless Router
Dropped internet
1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedrop outs and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the otherside of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
Mar 10, 2012 | NetGear WirelessN 300 USB Adapter WNA3100
N300 dgn2200 no internet connection
How to Troubleshoot a Netgear Wireless Router Print this articleA Netgear wireless router attaches multiple devices to your Internet connection, either by ethernet cable or wirelessly. If you can't connect to the Internet, the problem can be anywhere along the chain of devices and technologies that connect your computer to the Internet. Knowing how to troubleshoot your Netgear or other wireless router is an essential part of determining where the problem is and fixing it.
Instructions
1Click your "Start" button, and choose "Run." Type "cmd" in the text box (without quotation marks), and click "OK." A command prompt will open. Type the following: ipconfig /all. Press your "Enter" key. A list of numbers and other networking configuration information will display.
Find your network adapter in this list of headers. If you use your computer wirelessly in many different places, you may have to scroll through a lot of different options to find your adapter. If you connect to the Internet using a cable, look for a header that begins with "Ethernet adapter Local Area Connection." If you connect wirelessly, look for a header that begins with "Ethernet adapter Wireless Connection." You will usually only see an IP address displayed under one header in either category.
3Record your IP address and default gateway on a piece of paper or in a text file. If your IP address is 0.0.0.0 or begins with 169.254, unplug your Netgear router from its power source. Unplug your cable or DSL modem as well. Be sure to unplug both devices; turning them off with a power switch may not have the same effect. Wait 20 seconds before plugging the modem in again. Wait for the lights on the modem to light up. Plug in your Netgear wireless router again. Wait for two minutes. Use "ipconfig /all" again. You should have a different IP address now.
4Ping your default gateway. At the command prompt, type "ping 192.168.1.1" (substituting your default gateway address for 192.168.1.1). You should receive four responses, all of which will begin with either "Reply from" or "Request timed out." If you receive "Request timed out," unplug your Netgear wireless router from the power source for 20 seconds, and plug it in again. Wait two minutes before using "ping" again. If you receive "Reply from" responses, check to see if your Internet connection is working again.
5Open a Web browser. In the address bar, type "http://192.168.1.1" (substituting your default gateway address for 192.168.1.1). Press "Enter." If you have password-protected your Netgear router, you will be prompted for a username and password. The default username for a Netgear router is "admin." When you have successfully entered the username and password, your Web browser will show you the configuration page for your Netgear wireless router.If your Web browser never loads a Web page or prompts for a username and password, you're not communicating with your Netgear router. Double-check the address you typed into your address bar. If you've typed it correctly and your connection is wireless, either your wireless card has a problem or your Netgear router is not correctly sending a wireless signal. Make sure your wireless card is enabled (using Windows' built-in Network Connections applet or the third-party software that came with your wireless card). Make sure your connection settings (SSID, security type, and key or passphrase) are correct for your network. Look at the lights on your Netgear wireless router. The wireless indicator light should be green. If it's orange or not on at all, your router is not sending a wireless signal.
6
Make sure all the settings on your Netgear configuration page are correct. Most Internet providers use a dynamic IP address and DNS server addresses. Some Internet providers require a login, and some do not. To be sure, refer to the configuration information your Internet provider gave you when your Internet access was installed, or call your Internet provider's technical support number.
7Click on "Wireless Settings" on the navigation bar on the left-hand side of the page. If you were not able to reach the configuration page wirelessly and had to connect to your Netgear router with an ethernet cable, make sure these settings are still as you defined them when setting up your network. If not, either change the settings to suit you, or change the configuration of your wireless card to match these settings. Be sure to click the "Apply" button if you make any changes.
8Click "Router Status" on the navigation bar on the left-hand side of the page. Under "Internet Port," check your IP address. If the address begins with 169.254, you're not communicating with your cable or DSL modem. Unplug your cable or DSL modem from its power source for 20 seconds, and plug it back in. Wait two minutes, and refresh this page.If your IP address still begins with 169.254, there is a problem either with the cable connecting your Netgear wireless router to your cable or DSL modem, or with the modem itself. If your IP address is 0.0.0.0, there is a problem with your Internet connection, and you should call your Internet provider's technical support.
9Record all your configuration information before trying to reset your Netgear wireless router to the factory defaults. Resetting may fix your problem, but it will wipe out all your configuration information, and you will have to reconfigure your Netgear router from scratch afterward. To reset most Netgear routers, use the tip of a pen or an unbent paperclip to press and hold the reset button on the back of the router until the test light blinks. Release the button, and wait two or three minutes. Connect to the router's configuration page in a Web browser. Log in with the default username and password, and configure your router. You may have to connect to the router with an ethernet cable to perform this initial configuration.
Tips & Warnings
You can use the "ipconfig /all" command on almost any computer that connects to a network or the Internet. If "cmd" doesn't open a command prompt, you can use any method your operating system allows to open the prompt or shell. If your Netgear wireless router is not sending a wireless signal even after you've powered it off, waited 20 seconds and powered it back on, you can use an ethernet cable to attach a computer directly to the router to continue troubleshooting.
Jan 07, 2012 | NetGear Computers & Internet
Have NetGear N300 wireless router (wnr 2000v2)fed by motorola surfboard modem. N300 Port 3 output feeds OOMA internet phone system, Port 4 output feeds HP Touchsmart desktop pc (windows 7). PC will not...
hi,
go straight from your motorola to each wired computer to see if its a wire.can you can login to the router through your wired computer(touchsmart) in the settings and see if all your wired devices are listed, look at the parental controls, reset the whole router to default if you can, if your DSL. try a different jack in the house, get everything off that line but the motorola. go straight from the service jack outside the house(in the grey box) if you have to
jm
Jul 04, 2017 | NetGear N300 Wireless Router
Issue with router and ethernet cables
I imagine you reset/unplugged all of your routers, switches, and computers, starting with your modem, then router, and then each system?
There is a setup disk that need to be used to program your router with the ISP settings, passwords, and protocols for port forwarding, etc. I imagine you tried that.
Did you try all of your cables to make sure they weren't defective?
If you tried these,and the problem persists, the issue is a defective router. By default, the unit should transmit a wireless signal, and be ready to act as a routing switch for your other systems.
Mar 26, 2009 | NetGear WGR614 Wireless Router
Plz solve
need more information - do you have cable? DSL? Are you able to connect when you put the Ethernet cable directly into your computer and bypass the wireless router? The wireless signal is only indicating that your router is "broadcasting," but does not mean you have a usable Internet connection.
Feb 17, 2008 | NetGear WGT624 Wireless Router
NetGear N300 Wireless Router Logo
413 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
