Question about Mtd Snowthrower Snowblower 5 24" Parts Manual Tmo-35275b 315-555-088
Snow Blower MTD - Mtd Snowthrower Snowblower 5 24" Parts Manual Tmo-35275b 315-555-088
  • 5 Answers
SOURCE: oil change
if this model has a fill tube on it- turn the unit on its side to drain.
Posted on Feb 06, 2009
rwvanlue
  • 486 Answers
SOURCE: MTD YARD MACHINE SNOW BLOWER DOES NTO SHIFT INTO
Many times moisture attacks the hexagon shaft that the friction disc assembly slides on. It slides from side to side on the shaft to create Reverse 1 & 2, and the other end creates 1-6 forward. With a wire brush and sandpaper, clean the rust from the hexagon shaft, at the same time lubricate the friction disc bearing with penetrating oil and with a soft hammer, tap gently until the assembly starts to slide on the hexagon shaft. After all the rust is removed and disc assembly is sliding, apply a light film of graphite grease on the shaft. You may want to re-lubricate on a yearly basis.
Posted on Nov 22, 2009
SOURCE: I have a mtd snow blower for my 1042 cub cadet
The manual that I received with my blower was the Cub Cadet version and very incomplete. You can find an excellent manual from MTD, the maker of the blower, here:
http://www.snowblowerguide.com/snow_blower_manuals.php
Posted on Dec 27, 2010
SOURCE: how to adjust a 9460897 mtd snow blower auger
On the handle end (usually) of the cable is a curved metal connector. Attached to the connector is a threaded rod with a nut. Attach a pair of pliers to the threaded cylinder that the threaded rod goes into. Loosen the nut. Turn the threaded cylinder into the threaded rod to tighten or out to loosen. When you have the correct adjustment, tighten the nut back down onto the cylinder. To be correctly adjusted, pull the cover off the auger belt and push down on the handle. The spring attached to the cable at the pulley end should stretch out when the handle is fully depressed. Spring tension keeps the belt tight. iaff801.jpg
Posted on Feb 15, 2011
bcharais
  • 278 Answers
SOURCE: mtd snow blower 8 hp oil capacity
What engine do you have? Tecumseh those are usual 18-21oz Not sure with briggs, but will be around a 1/2 qt (16oz) start there. Add a little at a time to bring level up. get back if you have and need more specifics.
Posted on Nov 03, 2012
Where can I get parts for it.
I recommend eBay.
Jan 12, 2016 | Garden
MTD Snow Flite model 316230500. Where can I get belts?
I have already answered you twice with this information!
They have there own forum.
http://www.snowblowerforum.com/forum/mtd-snowblowers/1397-mtd-snow-flite-snow-blower.html
You don't need the part number, you just need to measure the length, or you can phone and say;
I have a snow flite brand snow blower model.316230500. Serial no.811262, send me a belt for it.
All the belts are here
http://www.jackssmallengines.com/equipment/mtd/snow-blower/belts
and here
http://www.mtdparts.com/equipment/mtdparts/parts/machine-types/snow-throwers
Dec 24, 2015 | Garden
MTD SNOW BLOWER WON'T RUN WITHOUT CHOKE ON
If it will only run on full choke you have an air leak somewhere
Jan 21, 2013 | Garden
Mtd snow blower 8 hp oil capacity
Oct 30, 2012 | Mtd Genuine 9460897 Snow Blower Auger...
Troy Built Snow blower won't start.
Cleaned out caruretor and blew out presumed dirt via compressed air. Thanks for your support.
Jun 20, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Mtd Snowthrower Snowblower 5 24" Parts Manual Tmo-35275b 315-555-088 Logo
52 people viewed this question
Top Mtd Tools & Hardware - Others Experts
Ted Maxwell
ray gallant
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Mtd Tool and Hardware - Other Expert? Answer questions, earn points and help others
