I just bought a dane-elec usb portable memory stick and transfered some files to it, went to transfer them to another computer, then wanted to save some more files to it and up pops a message saying it is write protected, and to remove write protection.
I did not use the "safely remove hardware" option on my computer because I didn't know about it and there is no warning to do so on the package that the USB stick came in.
How can I fix this so I can use it again?
Pu *** into you rown pc again and format it. when it is done formatting reboot your pc and let usb in while rebooting. when its done you can use it again but when used take it out with "safely remove hardware" option.
hope this helps otherwise they have a return and guaranty service at least
sorry for grammar but im not english
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this helps you
Click permissions
hope this helps you
