LEGACY PROPANE HEATER MODEL RMC LC30LPTF DOES IT HAVE A ON/OFF SWITCH FOR THE BLOWER FAN BC WE DONT HEAR THE FAN COME ON
SOURCE: Century Dyna-Glo Propane Construction Heater, fan stays on?
The heater is designed to continueously run the igniter , so as if there is a flame-out ,it will reignite the burner,and not dispurse unburned gas into your enviroment.
Posted on Jan 17, 2009
  • 188 Answers
SOURCE: propane heater has spark but wont light
ODS/Pilot may be clogged make sure you clean it out according to the instructions in your owner's manual. If you need a copy of the manual let me know and I will try to find it for you. If it is still not working it could be the gas regulator or the ignitor cable. For Glow warm parts contact Master Parts at 800-446-1446 or you also can find them online at www.masterparts.net. I hope this helps you!
Posted on Jun 30, 2009
  • 24 Answers
SOURCE: Pilot will not stay lit. No instructions or parts catalogue
home depot
Posted on Sep 30, 2009
hiltonjug
  • 612 Answers
SOURCE: I have Legacy ventless propane heater 15,000btu.
Try to take pilot assembly apart and clean real good. This will work most of the time. If it does not work for you, you will need to replace the gas valve. It's expensive but I'm about positive that cleaning it will fix it. Gas burns dirty and after a couple seasons a scale builds up that causes this problem. It's pretty common and nothing to worry about after it's cleaned. Good luck.
Posted on Oct 17, 2009
SRF518
  • 232 Answers
SOURCE: Dyno-Glo propane heater Model RMC-FA100DLX. It
find the thermostat and jumper out the two wires if it shifts into high heat, replace the thermostat.
Posted on Oct 26, 2009
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Ao appears after ignigtion
Either the fan is not working, or the fan prover (pressure switch) switch is stuck. If you can hear the fan going strong, it is most likely the switch. You may try to just clean it out, but you may need a replacement.
This error is produced when the blower prover switch does not close after the blower starts, the control will stop the ignition and go into lockout. Automatic reset is immediate after the blower prover switch closes.
If you keep having this problem, contact a reputable service company, especially if it's under warranty.
The link to the owners manual is below, it references fault codes, etc..
Hope this helps.
http://74.125.95.132/search?q=cache:4mAdY7bLfoQJ:www.haywardnet.com/products/Manuals/pdfs/Manual227.pdf+hayward+AO+error
Dec 30, 2010 | Hayward H Series Pool & Spa Heater 400k...
I have a Dyna Glo propane heater can not find the owners books and the fan don't run when I plug it in. Can you tell me where to get parts for mine? It is a model RMC-FA40
Have you checked to ensure the fan can turn freely, is not jammed/blocked/stuck, rubbing against the sides, or have bent blades? Is the electrical cord damaged? Are you sure the circuit breaker isn't tripped and the heater is getting electrical power?
You can obtain copies of heater manuals online from the GHP Group Inc, by clicking here. The manual for the RMC-FA40 models (a few different ones) can be downloaded by clicking here.
The manual will contain wiring diagrams & exploded views of the heater with parts identified for replacement. To order replacement parts, contact your local authorized service center, or if you don't have one, contact the GHP Group at: (877) 447-4768.
In the Troubleshooting section of the manual (page 7 of the manual), the first item is:
Fan does not turn when electrical connection is made.
It then lists the Possible Cause and Corrective Action, up to replacing the motor.
I hope this will help you get your heater up and running in short order.
Dec 19, 2010 | Heating & Cooling
Need a control knob for: dyna-glo pro propane heater. model: # rmc-tt30dgp-01, # rmc-tt30dg, # rmc-tt30gd. this is the off/low/med/hi temp. control knob.
I AM TRYING TO FIND A PROPANE REGULATOR FOR A DYNA-GLO PRO. THE MODEL # IS RMC-TT30DGP. THERE IS A NUMBER ON THE OLD REGULATOR. THAT # IS S2NTT0002-2.THANK YOU.
Dec 17, 2010 | Heating & Cooling
I have a Dyna-Glo RMC-50LPT propane heater that is about 5 years old and I can't get rid of the yellow flames when it operates. I have tried: - removing the heater and blowing everything out with a...
Dennis easy fix what is your out going gas you will need a manometer to verify it accurately or adjust your gas valve til your blue flames are gone. Let me know what you find!
Dec 16, 2010 | Heating & Cooling
Jan 11, 2009 | Century Tool 2320I Heater
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
