Computer won't turn on
Replaced bad battery, computer won't turn on
  • sgfd Oct 25, 2012
    How did you determine the battery was bad in the first place?
  • Leslie Gray Oct 25, 2012
    there was a memo by the battery indicator stating that i should consider replacing my battery and the battery would not hold a charge for more than a few minutes.
  • 564 Answers
Have you tried removing the battery and just using mains power.
Posted on Oct 25, 2012
Replaced alternator & battery won't start
CHECK BATTERY GROUND AND CABLE TO STARTER ALSO CHECK STARTER WATER IS BAD ON STARTERS AND GET WET AND SHORT OUT MEASY GOOD LUCK
Jul 14, 2013 | 2003 Mercury Grand Marquis
Does the EIS have to be replaced if the key won't turn
If you have the electronic key and it will not turn, either the battery in the key is bad, the key itself is bad (they do go bad often) or possably the sensors in the vehicle are bad, or even the computer.
May 30, 2013 | Mercedes E-class E320 E350 E500 E550 E63...
Key won't turn in ignition on 2006 chevy cobalt
on a lot of these late model computer base cars when battery power get low the computer gets confused. try this disconnect the neg. battery cable. charge the battery. reconnect and try again. my son cobalt battery went bad key was stuck in the igntion. good luck.
Dec 19, 2017 | Chevrolet Cobalt Cars & Trucks
P4P800 - VM BIOS Version 1012 to Upgrade 1018 Now CMOS can't save Date & Time
I'm sorry to have to say this but your CMOS battery connection is bad. There is basically nothing you can do other than replace the whole motherboard if it is too much of a problem.
One of my many computers is like this as well. I'm lucky in that as long as I leave that computer plugged in (it doesn't need to be turned on just plugged in), the CMOS won't reset its self. If you aren't that lucky then I would seek out a replacement motherboard.
Jun 18, 2012 | ASUS P4P800-VM Motherboard
Kindle Touch won't start
Bad battery, needs changed.
Nov 09, 2017 | Computers & Internet
My nuvi 1450 won't turn on and the garmin website updater won't reconize it hooked up to my computer even my computer won't reconize it.
I had the same problem with mine and got it working by doing the following while on the phone to Garmin. Plug your charger cord into the device and your computer (do not use a laptop, you need the higher current from a desktop for this). Hold the power button down for as long as it takes for the Garmin logo to display, this could be as much as 1 minute. As soon as the image shows on the screen, release the power button. If your Garmin isn't completely shot you will see it boot up.
If you have the Garmin Web Updater program on your computer, run it and update the operating system software to insure you have the latest greatest from Garmin. Once that is done, update your XML data files - they'll be on the list of updates if you need them. Once those are done you can update any voice or language files you'd like.
Lastly, leave your GPS plugged in at least an hour or two to give it a charge. Overnight would be better to insure your battery is really well powered up.
At this point your Garmin should function normally. The Garmin tech I spoke with told me some units start acting funky when the battery runs down too low and if it's REALLY dead it won't even take a charge or power up when you hook up your charger cord. Try holding the power button for as long as it takes to get a spark & you should be on your way. If not, call Garmin's support number for your locale & they're do their best to get you back up & running again.
Cheers, Jeff
Sep 01, 2011 | Garmin nuvi 1450 GPS Receiver
My MSI U100 Netbook won't charge. I purchased a new battery, and it still won't charge. So the battery was not the issue. Can the the AC power cord go bad as well and I should replace it? Or is...
Yes the AC Cord does go bad , you can also look at the power jack at the back of the Laptop to see if it is loose when you plug it in. I always start with the plug they are usually cheaper than a battery.
Nov 01, 2017 | MSI Wind U100-030US Laptop
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
Jun 09, 2011 | 1997 Chevrolet Tahoe
ALIENWARE DESKTOP LOST ALL POWER
In a laptop, you can lose power in three ways.
1. Dead battery 2. Dead Power cord. 3. Bad motherboard.
ther first two should be rather obvious, as the battery won't work or it won't hold a charge, but if it won't turn on at all, even while plugged in, chances are that you're going to need a new motheboard. This can be expensive in the M--x laptops, unfortunately.
Sorry for the bad news, mate.
Apr 29, 2011 | Dell Alienware M11x Gaming Laptop Computer...
Computers & Internet Logo
David Payne
David Payne
