Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
BUZZING SOUND / POSSIBLE FAN?
FOUND PART #'S FOR FANS HOW DO I KNOW WICH FAN IS MAKING THE NOISE WITHOUT TAKING OFF BACK OF TV???
  • Samsung Master
  • 19,396 Answers
Well you need to take apart the TV to find out, also the color wheel can make a similar noise.
Posted on Jan 02, 2009
  • Ginko
    Ginko Jan 02, 2009
    To start , not only fans can make noise, however , if you are sere that you are hearing a fan like noise of bearing rotatings, the culprit are always one of the cooling fans bearing, or the color wheel.
    The only way to find out is by taking apart the TV, sometimes just opening the back is not even enough.
    The job should be done by a technician and not by the home user.
  • Ginko
    Ginko Jan 02, 2009
    If the Tv is less than 4 years old, it may be worth calloing Samsung at 800-SAMSUNG , and asking a warranty extention, they start at $85 and will cover the technician visit.
40 inch sony bravia making buzzing noises....any suggestions
There are 2 small 1.5" fans that are located on the top right and left sides of the screen. These fans are of the non ball bearing type, so the bearings may be wearing out. You can either replace the fan or add a couple drops of oil to it. Remove the label on the back of the fan and put the oil there, it should quiet down. This will work for a while but eventually the fan will need to be replaced.
Good Luck!
Rich Lilja
Feb 28, 2015 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My Samsung HLP4663W 46 in was making a buzzing noise for several months. I know it could have been either the fan(s) or the color wheel, but I never opened it up to determine which it was. Now the TV quit...
Great reasoning work! In fact, the lamp will not light if the color wheel does not spin-up. Fans will not stop the process of lamp ignition. Instead, a fan will be detected and a message will appear on the screen telling which fan has stopped. You need to have the color wheel replaced.
Mar 15, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
I have owned a Sony Grand Wega for about 3 years now and for the past few months the TV has been making a very loud noise. I thought the noise was the fan but came to find out it was not the fan and was...
There is a fan beside the lamp chamber in this TV. There should be 4 fans total, and the one beside the lamp chamber might be making some noise. They are all bearingless fans, so the noise should be relatively low-pitched "whirr" if it is the fan. If the noise is more of a buzzing sound, it could be coming from the lamp driver (ballast) or from the lamp itself. Lamps tend to do strange things toward the end of their life.
If you have never changed the lamp, it is about time. They have a 2.5 -3 year life span with average use.
One thing you can try is to turn the TV on from a cold start, and watch inside the vent areas beside the lamp chamber. If you hear the noise before you see the lamp light up, then it is probably a fan. If it starts as soon as you see the lamp light up, it is the lamp or ballast.
Hope this helps you...
Jan 06, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Toshiba 62hm15a
my tv was making a similar sound so i took off the back. There was a bundle of wires that had come loose and were rubbing the fan blades. I retaped them back and no more noise. seriously.
Jan 20, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
SAMSUNG DLP BUZZ ONLY WHENBULB IS ON
A friend of mine does warranty work for samsung ,name is chip call him if you need too! 256-778-0300, most of the time when lamp needs replacing set will not play,the fan behind lamp is there to keep lamp cool when playing ,DO NOT touch lamp if you do this will leave fringer print and lamp will burn your inprint on it when hot!!! then you will have to replace lamp ,they are not cheap.replacing lamp is fairly easy, besides i really dont think lamp is your problem,most likely it would be fan making noise.
Jan 18, 2008 | Televison & Video
Sony Bravia LCD T.V.
It is most likely a fan (there are 2 to 3 of them in the set) that is making the noise. I doubt seriously that the lamp is causing a buzzing noise. The only other buzzing sound can come from the ballast wich powers the lamp.
Nov 28, 2007 | Televison & Video
TV making wierd noise~
sounds like the color wheel is going bad..try this test..while you listen to the set in the back, have someone turn it off, if the sound stops within 1 or 2 seconds it is the color wheel..if it continues, then one of the fans is bad
Aug 16, 2007 | Samsung HL-S6187W 61 in. HDTV
Toshiba DLP fan noise (52hmx95)
i constantly hear complaints about fan noise in dlptvs if you sit in front of your computer you will hear the same noise even in the next room there is no solution to the fan noise problem this product has a huge cage fan and a second and third three inch fans in it.... more than the samsung product it can be noticeable if the tv is on hard surfaces ie wood floors ,inthe corner, glass top etc the vents on the back of the tv allow for proper cooling of the lamp at shutoff so it doesnt shatter the tube its kinda like annealing glass its designed to extend the life of the lamp .... which im sure youve priced call toshiba and tell them your lamp is bad right now and get a new one for an emergency ( warranty if you can do it ) they are also improved this product is known to have short bulb life sometimes the zinging noise you hear is indicative of a bad color wheel in the light engine which would require replacement ( not cheap) toshiba will not piece out the color wheel assembly individually
Nov 30, 2006 | Toshiba 62HM95 62" HDTV
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
23 people viewed this question
Henry  Thomas
Henry Thomas
