Question about DeVilbiss Air Compressor Fan Ac-0108 Craftsman Portrcbl
I have a Craftsman air compressor, model # 919.167320. This air compressor is currently having a recall on the shroud.They have been known to overheat,causing a fire. During the past several years I have replaced the fan several times due to breakage. The fan is easy to replace and only cost $7 so it isn't a real problem although I would like to know why they are breaking. It is used for personal use at home which mainly consist of airing up tires so it isn't used very often. Does anyone know what could be causing the fans to break?
2 Suggested Answers
  • 31 Answers
SOURCE: Secondary air filter for DeVilbiss oxygen
I can sell you one for about $20 plus shipping. Can give you a part# when I get back to the office. Call 850-219-0202 M-F 9am-5pm. Ask for Ray
Posted on Jun 27, 2010
Craftman table saw model number 315-218291 is it on a recall
Craftsman Table Saw Recall. Thousands of Craftsman portable table saws sold exclusively at Sears are being recalled. ... The recall involves about 46,000 Craftsman brand ten-inch table saws. There have been 11 reports of it collapsing, with nine of which causing injuries to fingers and hands.6 days ago
Craftsman Table Saw Recall ' NBC Bay Area
www.nbcbayarea.com/on-air/.../Craftsman-Table-Saw-Recall_Bay-Area-415673483.htm...
craftman table saw Google Search
Mar 14, 2017 | Saws
Air compressor makes loud knocking nois when running
remove shroud and see if fan is broken but may be piston is shot
Apr 10, 2013 | Craftsman 33 gal Air Compressor 6 hp...
Craftsman Air Comp. 6 hp oil-less, 33 gal horz. tank - sounds really loud
Sources of noise from craftsman oil free compressors (could be Made by Campbell Hausfeld or Porter Cable) include loose fan, failing bearing/s on the piston rod and housing, failing seal ring on piston, air filter intake and loose motor mounts. With the housing cover off, check the fan blade for cracks or loose screw. Turn motor by hand till the piston is at top of stroke. Examine the cylinder for scratches close to top. If scratched, air is leaking past vinyl ring making noise and causing longer fill time. If everything looks ok, suspect noise coming from bearings. Hard to tell if bearings are failing by looking at them. I have seen many failures of the piston bearing on the crank (fairly easy to change, I use alternator bearing from auto parts ) , however, the bearing in the housing just behind the crank bearing is much harder to replacable. Good luck with your fix-it project.
Jun 11, 2012 | Craftsman Air Tools & Compressors
I have a 1 HP, 4 gal Craftsman air compressor and it started doing all kinds of sparking from the motor. When I took the shroud off one of the capacitors on the top of the motor is charred and burnt. The...
Go to www.ereplacementparts.com, search for your compressor by model number and you should be able to find a breakdown of your compressor. You can order parts from them if they are still available or use the part number for the capacitor to shop around on the web for prices.
Jan 01, 2012 | Craftsman A4 Avant Wagon Air Tools &...
CRAFTSMAN Air compressor Model: 919167450. IT'S GOT A LEAK" SO FAR SEEMS LIKE AIR ESCAPING AT CONNECTION OF COMPRESSOR TO TANK. THE COMPRESSOR THEREFORE DOESN'T SHUT OFF COZ PRESSURE LIMIT(PSI) IS...
Manual:
http://www.managemylife.com/mmh/owner_manuals/8336/CRAFTSMAN-Air-compressor-L0809089
Schematics:
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fP0040151-00001.png
Parts ordering:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Air-compressor-Parts/Model-919167450/0247/0703000/P0040151/00001?blt=06&prst=&shdMod=
Jan 08, 2011 | Craftsman Air Tools & Compressors
I have a 3 gal/ 1HP Craftsman air comp. When I plug it in and turn it on, I get the sound of current getting to the motor but it does not start. A failed Starting capacitor?
Could be, do you have a capacitor checker? It sounds like you have a compressor locked up. Do you have oil in the compressor? If the compressor is new I would take it back and see if it is still under warranty. before I did any thing to it.....
Dec 19, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have an H1506FWH Husky 6 gal 1.5 hp compressor that won't build air pressure. While running I noticed a change in the sound but it kept running. However, I no longer had much pressure. Now I can't get...
Locate the piston housing and remove the outer plate 4 screws
then tap on the next plate and when you remove it ( its the reed plate) you will most likely see a hole in one or more of the reeds
I am not technical but I have the same peoblem and I am trying to replace the reed plate on mine when I saw this. Good luck
Nov 22, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Setting the max pressure on a Craftsman compressor
The pressure setting for on off of the compressor , and the operating pressure don't have to be the same. You should have two gauges. One for tank pressure, and one for operating pressure. Turn the large knob on the operating pressure, ccw to decrease and cw (clockwise) to increase. You can download a manual for your compressor at:
http://powertool.manualsonline.com/ex/thread/view/idThread/839583
Jul 18, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Converting from 220 to 110 volts
Most brands of air comperssors are built to work on either 220 or 110 v. I believe that 220 v compressors are more efficient and draw less current and run cooler.
The more expensive compressors have a switch allowing for voltage selection. Still others will have a wiring diagram printed on the motor allowing voltage change by changing jumpers. Most all of the sears compressors that I have repaired were of single voltage with no other way to change except change motor. Do not worry however, you have the better motor. It is easier to convert the outlet plug to 220 by isolating the circuit and installing a 220 v breaker. enjoy
Nov 15, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
DeVilbiss Air Compressor Fan Ac-0108 Craftsman Portrcbl Logo
297 people viewed this question
Top DeVilbiss Air Tools & Compressors Experts
JOHN LAPIER
ray gallant
Lawrence Oravetz
Are you a DeVilbiss Air Tool and Compressor Expert? Answer questions, earn points and help others
