Question about HP OfficeJet 6110 All-In-One InkJet Printer
Carriage jam error
Was printing envelopes and it made a screeching noise and an envelope jammed. cleared the jam and it still says "carriage jam". turned it off and on and unplugged. still has error
    Novelist:
    Sniper:
  • 68 Answers
A paper jam
If you've had a paper jam, normally after you clear it, a small amount of paper sometimes gets left behind and gets shunted onto the sidewall of the printer by the carriage, which stops the carriage reaching its full travel and throwing up an error, rendering the printer unable to print or carry out any other function. Simply remove the paper and switch printer off and on and it will reset.
If you have an error of any other kind, many remedies and fixes for these can be found on my website http://www.the-inkstore.co.uk/frame/pages/epson.htm
Regards
Aeronautical
Posted on Oct 25, 2012
Ranglo
  • 1194 Answers
SOURCE: envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Posted on Feb 20, 2010
Khalsa007
  • 79 Answers
SOURCE: Carriage jam error
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7 Allow the all-in-one to re-initialize. This may take a minute or two.
8 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information
Thanks
Posted on Jun 04, 2008
  • 3 Answers
SOURCE: HP 6180 printer
henryandjane,
Look over on the wheel that will feed the paper mybe there is a tiny piece of paper on it and find the sensor for the paper mybe it is stack-up already
Posted on Jul 06, 2008
SOURCE: Carriage Jam
My solution was to simply unplug the unit, with leaving it off for several moments. Voila! It worked!! I had to reset the time and date settings, though. A small price to pay.
Posted on Jul 07, 2008
adonscott
  • 106 Answers
SOURCE: carriage jam error
Here is the document that i want you to follow exactly in order to resolve your issue.
CLICK HERE TO VIEW THE DOCUMENT.==>> DOCUMENT
Please let me know the result after following the document.
Thank you so much. I remain.
adonscott
Posted on Jul 24, 2008
Hi! I have a LaserJet Pro MFP 476nw. When I go to print an envelope using the automatic envelope feeder in the front drop down door, I get the message Clear jam in tray 2.
Go to your menu and pick that cassette out and make sure it is set to the proper size envelope. ten to one it is not os it shows a jam cause it is looking for another size.
Mar 27, 2018 | HP LaserJet Office Equipment & Supplies
I cannot get the envelope fuction to work correctly. The printer tells me I have a paper jam, when in fact I am trying to print an envelope
The printer will stop printing is there is an error, check for any paper jam before printing. Take note of the error message and locate the exact jam.
Use the manual feeder when printing on envelopes. You may click on the link http://bit.ly/rnHp5b to see instructions on how to go about the procedure using the manual feeder.
For further assistance, please call Lexmark Technical Support.
Mar 08, 2011 | Lexmark C532n Color Laser Printer
How do I print envelopes? It just jams when I
when you load the envelop, you should make sure that you adjusted the tray to lock the envelopes in place, or otherwise, they will move and cause a jam
Sep 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper pickup not moving
Have you set the margins?????
If you push the left margin over, it may help.
Jun 08, 2009 | Konica Minolta magicolor 2400 Laser...
HP 7580 Paper Jam made piece pop up in the way of carriage
Please go through the web link given below and follow the instructions to clear the paper jam without damaging your printer.
bc://bt/QUEvVGVybWluYXRvciBTYWx2YXRpb24gMjAwOSBDQU0gWFZJRC1GRUFSLzg4OTg5NDI5OC8zMzQ2MmI4YTEyZDQ4MzIxNDVmOWVkNGQwNTFiZjBjM2ZkNmFiMzZhL1pa
May 28, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Hp l7580 carriage jam - how to fix it
use the back door for printer and you can remove the envolupe
May 04, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Carriage jam message HP D7360
Try opening the top cover again and look into the printer with the help of flashlight or some light. I think you will find that there is paper stuck on one side of the carriage. Do this aspa since if the pape is really there, t will not let the carriage sit over the rubber gasket and will dry the ink out.
303Electronics eBay Stores
http://www.303electronics.com/
Jun 01, 2017 | HP PhotoSmart C4280 Laser Printer
HP 6180 printer
henryandjane,
Jul 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
288 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
